Go Back   Airstream Forums > Airstream Community Forums > Dollars & Cents > Buyer Guidelines
Old 11-21-2008, 01:37 PM   #1
jackson , Mississippi
Inspector in Louisiana?
Hello,
Is there anyone available to inspect an AS in Bogalusa, Louisiana?
The unit is a 1990 30' Excella.
I have seen the unit and like it but would like someone with some experience inspecting these things to take a look and see what all I am missing.
Bogalusa is near the La/Ms line...southwest of Hattiesburg, MS.....east of Fluker, LA.....right near nowhere.....
Any takers? I'll buy the beer.
Eric
erichatten is offline   Reply With Quote
Old 11-21-2008, 02:56 PM   #2
1998 28' Excella
Dolores , Colorado
Eric;
If you would use the search mode and type in Inspectors it will bring up several threads. You will find a thread dated 7/3/08 that talks about inspectors in the Lousiana area.
Welcome to the forum and good luck.
Member Four Corners Unit/CAC
WBCCI # 10105
AIR # 28748
dogpound is offline   Reply With Quote
Old 11-21-2008, 05:08 PM   #3
InsideOut's Avatar
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen , Colorado
Images: 108
You may also want to look for folks by searching the "Members List" for people in the area of your trailer. To do this:
> Go to the "Member Search" section. (look for a link in the left hand column under "Quick Links")
> Select the state nearest to the location from the drop down tab (in this case do two searches, first in LA then in MS)
> Click on the round button in front of "Trailers Only" under "Inspector Type:" (or whatever)
> Scroll down and click on "Search Now"
Then you can PM or email the names of those that come up to see if they would be willing to help. It's a good idea to contact them somehow, because not everybody checks in on the forums daily.
Currently there are 10 volunteers in Louisiana and 5 in Mississippi.
Shari
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Hello from South Louisiana beaubayou Member Introductions 29 03-29-2024 05:57 PM
GREAT campgrounds in Louisiana emo59 On The Road... 55 04-20-2015 04:18 PM
inspector in louisiana needed bluegabs Dollars & Cents 7 11-21-2008 04:49 PM
Boondocking in Louisiana? J&C Boondocking 2 04-26-2007 09:28 AM
Skin Replacement in SE Louisiana? MarkExc500 Ribs, Skins & Rivets 10 05-13-2006 07:49 AM
