Old 08-18-2011, 09:12 AM   #1
1965 22' Safari
Asheville , North Carolina
Help-Looking to purchase first Airstream
Hello, I am looking to purchase my first Airstream this year and quite overwhelmed with all of the different makes and models available. I am interested in a vintage model...'65-'80...probably around 22-28 ft, able to sleep 2 (queen bed) with a kitchen and bath/shower. It looks like the Overlander is a good option but wondering if any veterans out there have any advice or opinions. Many thanks!!!!
jjkitt is offline   Reply With Quote
Old 08-18-2011, 09:30 AM   #2
DJW
DJW's Avatar
2004 25' Safari
Lafayette , California
Your post would be much more valuable, and more likely to get a response, if you actually include what you need help for, in the subject line.
DJW is offline   Reply With Quote
Old 08-18-2011, 10:18 AM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings jjkitt!
Finding a coach in the age range that you specify is going to be challenging. During that time a doule-bed was about the largest bed offered. I don't believe that the Overlander was ever offered in a rear bedroom configuration which would have been necessary for a queen size bed. Starting in the mid-1970s, it was possible to find a few Airstream models with rear bedrooms (mostly 28', 29', 30', or 31' models. Even then, most of these were offered as either twin or double. The rear bedroom queen models didn't become popular until the wide-body coaches were introduced, and even then, they tend to be somewhat scarce.
If you are willing to consider Argosy, the 28' and 30' rear bedroom coaches (approximately 1975 through 1979) offered the panoramic rear windows in the rear bedroom coaches, and it wouldn't be extremely difficult to convert one to a queen bed (RV Queen-size) . . . but be prepared for a tight fit. I suspect that if you wish to remain in the pre-1980 model range, you will be looking at modifying a double or twin rear bedroom coach to conform to your queen size bed requirement.
Good luck with your investigation!
Kevin
P.S.: You can find floorplans and additional information about Airstream trailers of the 1970s at this link.
Kevin D. Allen
AIR #827
Considering a used Airstream purchase kmb1966 Buyer Guidelines 11 08-30-2011 05:09 AM
