I recently found Airstreams on the web and i fell in love with them. I'm currently in school, full time job, and part time Military. I don't want to buy a home or rent an apartment and i figured an Airstream is a great alternative. I visited a few dealers but i'm very overwhelmed with the kind of information they are giving me. They also told me financing can be difficult if my credit is not as good. What should i know about buying... how should i finance? Are there any additional costs i should know? I've been reading the posts here and hopefully i can get more insight. Any help will be appreciated. Thank you!
Don't burden your self with an expensive Airstream at this time. Finish the schooling, do the Military duty and get yourself a reasonable Airstream. Make it your fun, make it your home. Keep your eyes open all the time for that one special one too. If I were you I'd look for an early 80's Excella.....25 footer.
Welcome to the Forums. We're glad to have you with us.
Living by yourself in an Airstream is very doable, and can be afordable. This first thing that I would do is check out campgrounds in your area. Pick the one that you like the feel of, and get prices for a long term stay. See waht's included, cable, wifi, etc. Take a look at some of the prices for a gently used Airstream that you think would be suitable. Crunch the numbers and see if it works for you financially. If you want to travel some in your Airstream, a suitable tow vehicle is also a consideration. If travel is a part of your plan, you might consider going with the smallest Airstream that you think you could live in.
If you are in the active military reserve or National Guard, you have access to the campgrounds on military bases. Our son is an E-7 in the Army Reserve, and takes his 19' Bambi on training assignments. He camps on base, and still draws his perdiem. He also stays on bases on vacation. The price is usually really good.
Brian
__________________ SuEllyn & Brian McCabe WBCCI #3628 --- AIR #14872 2005 25' Safari FB (Lucy) with HAHA 2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
One other item. Dependent upon where you are stationed, an Airstream may not be suitable for 4 season use. Consider that once you get significantly under freezing temps, insulation is marginal, windows are single paned, you do have issues with condensation, and you will burn a ton of propane, assuming you will be using the furnace to keep the under floor areas thawed. Add to that the issues of water and sewage, you will lose your fondness of your Airstream fairly quickly.
Now if you can stay out of hard winter, then go for it.
Jack
Jack Canavera
STL Mo. AIR #56
'04 Classic 30' S.O.,'03 GMC Savana 2500,'08 Vespa GTS 250
I'm sorry, here's some additional information. My SUV can tow a max of 5000lbs. One dealer told me i can probably tow up to a 23". Also, i asked the dealers about used models but they quickly suggested otherwise. They also suggested i put 20% down (i questioned this, which is why i'm trying to inform myself). I did check around post (Fort Irwin, CA) and i will be able to rent a space for a moderate amount of money. The temperatures here range from the low 40's in the winter and over 100 degrees in the summer. I do plan to do some traveling but not on a regular basis. I figure i can afford about $700-800 a month for living expenses. I must say, thank you for all your input. I know now that a used model will be my best bet. Again, thank you so much!
Keep in mind all the new shine of a fresh-off-the-dealers-lot unit takes a huge dip in value, the 20% down could very well be the total value lost as soon as the trailer is titles as "sold".
That 20% might buy a reasonable used unit outright...
__________________ Hi Ho Silver RV!
Vernon, Sarah, Mac the Border Collie - 'Epiphany' the 29' Airstream and a honkin' long 34' named AlumaTherapy
This is a great time to find a nice Airstream. Lots going on the market. Check out ebay, craigslist, and your local papers... but also check on the classifieds here! Compare the prices, look at pictures, kick the tires... you will find one you like! The last year I worked I lived in a 5th wheel while hubby was at our home... it was a piece of cake...enjoyed it alot. Not a lot to clean and take care of, but enough room to do all I needed!
The vintage airstreams are lighter in weight, just FYI. Ask any and all questions here on the forums about any 'streams you see. Take 2Air's advice and pick up the books, you will learn alot!
Mrs. NorCal Bambi traveling in S Tardis ~ from the Great State of Jefferson
One caution to be aware of is living in an Airstream near Fort Irwin. It will be quite hot and the air conditioner will run almost continuously and loudly trying to keep cool in the 100 degree plus temps there, much like it would in Riverside.
Don (KD6UVT) & Gail Williams
What do you want to be in life, a spectator or a participant?
Fort Irwin is also the site of one of the top 10 road signs that I've ever seen. Leaving the main gate the cautionary sign there says "ABSOLUTELY NOTHING - Next 22 Miles" and that statement is spot on.
__________________ Crusty "If you come to a fork in the road, take it." Austin, TX "Rancho Deluxe"
