Go Back   Airstream Forums > Airstream Community Forums > Dollars & Cents > Buyer Guidelines
Old 11-09-2015, 06:15 AM   #1
Baton Rouge , Louisiana
First Airstream
We are looking to buy our first Airstream trailer.
We are going to look at a 1986 Sovereign 25
What are some of the things I should be inspecting on a trailer this old
Jack
jcm14246 is offline   Reply With Quote
Old 11-09-2015, 06:32 AM   #2
1955 22' Safari
Laredo , Texas
Leaking windows
Freeze damaged plumbing
Rotten floor
Boiled batteries
Rusting frame
Where is the trailer located?
55AS is offline   Reply With Quote
Old 11-09-2015, 07:08 AM   #3
First Airstream
I noticed that the weights of the older, mid 80's, trailers are lighter than the newer models.
Has the construction changed drastically
Old 11-09-2015, 07:13 AM   #4
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
In a word, yes. The vintage trailers' (ie., from the 60's) claim to fame was their light weight. Airstream went to great pains to keep them as light as possible. As time has moved on, and tow vehicles have become more capable, and owners have developed a taste for wider trailers and more solid construction (ie., solid wood cabinetry) they have gained weight. Some of the smallest new trailers available today weigh approximately as much as some of the largest trailers from the 60's.
good luck with your search!
Old 11-09-2015, 07:15 AM   #5
Belegedhel's Avatar
Houston , Texas
Download the buyer's inspection checklist from the link below. If you go all the way through it, you will have hit all the usual issues.
http://www.airforums.com/forums/f138...ist-43294.html
good luck!
First airstream- first post Cullenwruth Member Introductions 9 11-06-2014 08:15 PM
First post. First Airstream. Psyched! Stressed! Confused!!! gomotomoto Our Community 33 09-24-2014 05:55 PM
First time Airstream owner & first mistake gurrd80 Member Introductions 2 05-20-2008 10:20 PM
My first vintage airstream and first problem m00d Our Community 5 08-23-2005 03:56 PM
First Big Trip, First Time Float Tubers :eek: Rhodie On The Road... 14 08-11-2005 02:18 AM
