Old 10-24-2005, 01:09 PM   #1
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Does anyone use this lock?
I saw this item in a flier I got from CW.
http://www.campingworld.com/browse/s...m?skunum=17213
Has anyone used one, what do you think of it?
Richard
Old 10-24-2005, 01:21 PM   #2
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
I Do.
When I am trailering. It works great. The only problem I have with mine is that it requires that you have a allen head wrench that fits the screw.
There is a small allen head screw that you have to back out once you have removed the keyed barrier.
I guess you would have to see it to fully understand it.
smily is offline   Reply With Quote
Old 10-24-2005, 01:23 PM   #3
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
Check Sizing
We used one occasionally on former boat trailer... Will work with sheet metal stamped hitch, but not some of the other versions. It is very sturdy and will keep someone from hitching up and driving off, but may not easily fit 2 5/16ths ball receiver.. Somewhat of a pain to screw locking plug in and out after unlocking with key, but it does work...
John McG
Condoluminum
Condoluminum is offline   Reply With Quote
Old 10-24-2005, 01:27 PM   #4
Levon's Avatar
1985 27' Sovereign
1981 22' Excella II
Colbert , Georgia
Images: 168
I like mine. Even when it seems like extra work to put it on and off....I think of the reason....makes it a lot harder for someone to rip your trailer off....
Levon is offline   Reply With Quote
Old 10-24-2005, 02:36 PM   #5
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I use one on our boat trailer and though it does take an extra step, it is in fact a very great tool.... though there are others out there too.
On our 2004 the ends of the receiver are kind of stamp bent upward, so in some applications this may not work well. I have yet to try with the Airstream , but from looking at the one on the boat trailer where the receiver has got a flat skirt like metal around the lip allowing this to slide on, it appears to possibly be an issue for a newer coach, but again, I have yet to test that out.
Old 10-24-2005, 05:07 PM   #6
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
I don't use a coupler lock (other than a Master pin through the coupler tongue on top) on the Airstream, but I do use one on the Scamp as at 2600 lbs it's light enough to be pulled away by anything. After returning to the trailer and repeatedly finding folks walking in off the street to touch and look at it, I decided something was in order for security. I use a Master locking pin through the coupler tongue on it, but I also use a Master ball lock. They're available at any number of sources; I bought mine at Wally World.
http://www2.northerntool.com/product-1/200172024.htm
Although a tongue lock won't stop a determined thief with a tow truck from dragging the trailer away, it'll make it more difficult for some dumb crook to steal on a whim. The downside is that they're only good for up to 2" ball couplers. I don't know if they make a 2 5/16" version.
Roger
On edit: Here's the 2 5/16" version!
http://www.etrailer.com/Merchant2/me...tegory_Code=CL
Old 10-24-2005, 06:16 PM   #7
CanoeStream's Avatar
St. Cloud , Minnesota
Unhappy
I have a Bulldog TL-33 (http://www.rjays.com/Rjays_tlr_locks/Locks_Main1.htm) at Pahaska's recommendation. It is easy to use. None of these will stop a crudely equipped thief if you boondock at the end of miles and miles of road. I find many campground situations that I trust, such that I use it only some of the time.
Maybe I should review meth statistics before I continue that foolhardy attitude...
5 meter Langford Nahanni
Old 10-24-2005, 10:07 PM   #8
cammur's Avatar
Roseville , California
I tried that one but it wouldn't fit on my 2005 25' Safari. The coupler flarges out wider that the lock can accomodate. I finally found one made by Husky at a local non-AS RV dealer that did the job, but wasn't cheap - about $50, I think.
On edit, this is the one I got, only I paid more:
http://www.pplmotorhomes.com/parts/r...iler-locks.htm
cammur is offline   Reply With Quote
Old 10-25-2005, 01:02 AM   #9
7751
Torii's Avatar
1975 25' Tradewind
Huntington Beach , California
I use place a spare ball in the coupler and then place a lock on the coupler pin on top. I don't know if its as good as these other solutions but it is better than nothing at all.
Torii is offline   Reply With Quote
Old 10-25-2005, 07:25 PM   #10
T-man -- That works. Just mess up the threads or cut off the shank. We're only slowing them down anyway. They truly wouldn't have to actually access the ball hitch to hook up a chain, hike up the tongue and mosey on at slow speed. That's why I've liked my Argosy -- a stealth Airstream that non-millionaires would tow....
Old 10-31-2005, 08:52 PM   #11
alfalsetto's Avatar
1982 31' Airstream 310
Longview , Washington
I have a Motor Home so I don't need Coupler lock. Just a good door Key! LOL
alfalsetto is offline   Reply With Quote
Old 11-24-2005, 08:42 AM   #12
Lock durability
I know that 59toaster's trailer received some ballistic testing. I think he's lucky there was such a thing as 'vintage' ammo: http://www.theboxotruth.com/docs/bot5.htm
Old 11-24-2005, 09:20 AM   #13
2002 25' Safari
Dewey , Arizona
Images: 62
Follow up
The lock I asked about does not fit on my TT. The lip around the ball area is too large to fit into the grove in the lock......
Canoe stream,
That testing looks like fun! I wonder if I could get Master Locks to send me a box of locks for more testing. I have a Ruger P89, maybe multiple rounds will get it done.
Richard
310 door lock parts joepospisil General Motorhome Topics 8 10-02-2012 11:14 AM
That @#*# Lock niftypkg Doors & Locks 16 11-20-2005 02:28 PM
Entry Door Lock Set Hunt ends at Inland Grady White 1959 - 1965 Ambassador 3 12-16-2004 09:08 PM
Broken Travel Lock Charcigar Doors & Locks 2 06-08-2004 08:23 AM
Door Lock replacement? 3Ms75Argosy Doors & Locks 2 08-15-2002 11:12 PM
