04-08-2012, 09:19 PM
#169
2012 25' FB Flying Cloud
Gig Harbor
Originally Posted by Bruce B
Somebody correct me if I am wrong but when we picked up our new Airstream a month ago the dealer said that the red light between the two hot water switches would illuminate if there was a problem with the hot water heater when running on propane. You may have no problem at all. I have seen it illuminate briefly when there is no a/c and the propane is in the process of lighting. As soon as there is ignition it goes out.
Congratulations on the new stream! Pictures???
Bruce
This must be true because I have run the heater on propane and elec and the light has never come on. This seemed odd to me though as I would have thought the light would indicate when the unit was heating. I'll look in the manual.
Dan
TAC
Hope is not a plan.
04-08-2012, 09:27 PM
#170
Gig Harbor
Dan
On second thought I think tha† light is an indicator for the potable water pump.
Dan
TAC
Hope is not a plan.
04-08-2012, 09:49 PM
#171
"CLOUDSPLITTER" (tahawus)
I'll know where I am when I get there.
, "Niagara Frontier" NY
On ours when the propane lights the red indicator goes out.
If it should blow out and doesn't re-light it will come back on...red indicates, you should check for leaks and why it went out.
04-09-2012, 07:44 AM
#172
Weldon Spring
, Missouri
On the newer ones, the light flashes when either source is selected (unless the water is already hot enough from previous use, or there's a problem); it does not stay on through the entire propane start cycle like the old ones. This little change hasn't found its way into the owners' manual yet (typical of the RV industry). If the light never even flashes, but everything works OK, try swapping the two connections on the back side of the light...since it's an LED, polarity matters, and some of them get connected backwards on the production line.
04-09-2012, 08:00 AM
#173
"This little change hasn't found its way into the owners' manual yet (typical of the RV industry)."
Why are we still the last to know?...crank-up the old mimeograph machine and add a page.
04-09-2012, 02:45 PM
#174
Weldon Spring
, Missouri
Right...it's as if the boss at the Atwood plant said: "Guys, let's go ahead and use up these old manuals first..."
04-09-2012, 07:09 PM
#175
2012 30' Flying Cloud
Grand Rabbits
, Michigan
I just went out and checked it because it's parked next to the house at the moment. I flipped on the propane switch for the water tank and no light came on even though the propane fired up. I also tried the electrical switch for the water heater and, alas, no light comes on.
Admittedly, I seem to have found only one flaw at the moment of the entire trailer. I'm pretty impressed...
I still think we should put together a group of private investors and by Airstream from Thor industries. We could make a better product and take over the world!
Hibby
04-12-2012, 07:02 PM
#176
2012 19' Flying Cloud
Oak Ridge
, North Carolina
Help - my husband raised the bed to access the storage under the bed. Now we cannot lower the bed - makes sleeping difficult. Help!!!
04-12-2012, 07:34 PM
#177
Grand Rabbits
, Michigan
It's probably just difficult to push down. At first, I thought I was going to break the bed, but after moderate pressure the gas lifts released and it lowered easily. Try placing your hands on the mattress directly above the point where each lift attaches to the wood sheeting that the mattress sits on. Gently apply pressure and gradually increase to see if they just need to pop loose and allow you to lower the mattress!
Hibby
04-12-2012, 08:24 PM
#178
2008 25' Safari FB SE
Crawford
Hibby is correct, although you could try to get in the bed and ride it down.
Gene
04-13-2012, 05:06 AM
#179
Oak Ridge
, North Carolina
Hibby and Gene, thank you very much!
04-15-2012, 05:18 PM
#180
Grand Rabbits
, Michigan
Thinking through this carefully, I think Gene has the right approach...
Hibby
04-17-2012, 09:22 AM
#181
Crawford
You may need to tie yourselves to the bed before you ride it down or you may roll into the wall. This also may be an opportunity for other things best discussed on the "Sex in an Airstream" thread.
Gene
04-17-2012, 06:33 PM
#182
Gig Harbor
You can push down hard on the bed. Body weight should do it. However don't try this approach on the mirror in the bathroom. It has a keeper on the left side hinge as my wife found out when she pushed hard and it blew out and fell on the floor. Amazingly it didn't break the glass and the dealer fixed it. He also fixed the screen on my emergency exit window and didn't engage the locks and we were on I-5 doing about 60 when I looked back and saw the window flapping in the wind. Luckily we found a pull over stop and locked it. When I told the service mgr about it he chuckled and said it happened all the time, which made me lose what little patience I had at that moment and I unloaded on him. The last time I called for service he was no longer there.
Dan
TAC
Hope is not a plan.
| Thread Tools |
| Display Modes |
