Old 02-04-2016, 09:06 PM   #15
Imperial Beach , California
Piggy Bank, thanks for your input. I am having a hard time with that bathroom wall. I miss the window at both ends. I guess a good nights sleep could make up for that though
TeeTaylor is offline   Reply With Quote
Old 02-04-2016, 09:07 PM   #16
Piggy Bank's Avatar
2017 25' Flying Cloud
2015 22' FB Sport
Kansas City , Missouri
Yes but note that the 22 bathroom window opens for ventilation. A big plus IMHO.
Piggy Bank
Piggy Bank is offline   Reply With Quote
Old 02-04-2016, 09:10 PM   #17
Cannonball's Avatar
2014 22' FB Sport
San Antonio , Texas
2014 Sport 22 FB. We really like the layout. 2 Adults, one dog person.
Cannonball, Deep in the Heart of Texas!
WBCCI #4387, Air #84080
Cannonball is offline   Reply With Quote
Old 02-05-2016, 03:19 AM   #18
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
Hi Tee
Just to confuse you completely think about the 23 FB instead. Compared with the 20 it gives you a tandem axle, walk around queen bed, dry bath, ducted heat. It actually tows better than the 20 does. For someone 6'3" tall it is a huge difference in livability with no real downside.
The reason I suggest this is your Airstream is a long term purchase, we have several customers that have owned the same Airstream for 30 years and 15-20 is quite common. Your tow vehicle you won't likely have anywhere near that long especially when it is 12 years old to start with.
There are two ways to go with towing, one is to make a couple of changes to your 04 Pathfinder. Tow ratings really have nothing to do with what a vehicle will tow it is largely just marketing. You could try towing a 2000 pound square box trailer and find it almost impossible, a 5000 pound boat with surge brakes on one axle would be dangerous to stop and not be very stable but an Airstream connected properly can be well over 5000 pounds and be very stable and safe with good performance.
Your 3.5 Litre is a great engine connected to a bullet proof drivetrain but the large tires to make your SUV look tough rob a great deal of its power. The wheelbase is relatively short on your Pathfinder but the overhang is also short which helps but again the big tires have huge sidewall sway making it much less stable than it could be. The live rear axle is not ideal but the suspension is firm which helps make up for it somewhat.
Back in the day we set up a lot of these. To turn them into a good tow vehicle changed the tires from the stock 245/65 17" to 235/55 x 17" performance tires. Bridgestone Comp's work well. You need to replace your shock absorbers with a premium shock such as a Bilstein.
We would always use a welded ball mount on this vehicle to keep the overhang as short as possible and it needs to be set up properly. That may sound like a given but only about 5% of Airstreams are actually set up optimally. It is not rocket science just don't think it will automatically happen. I can't remember if 04's had factory transmission coolers but if not you will need to add one, if you have not done so in the last 30,000 miles you should change the transmission and axle fluids and upgrade to synthetic oil. If the Radiator is original likely it is a good idea to replace it at the same time.
Once this is done your Pathfinder perform and handle very nicely with a 23' and take you anywhere you want to go.
The consideration though is do you want to spend this much on a 12 year old vehicle. If you are over 100,000 miles I would consider changing it.
The 05 -2012 Pathfinders are substantially better tow vehicles, they are only slightly larger but have a considerably longer wheelbase, independent rear suspension and a great 4.0 Litre engine also they have a 5 speed transmission. We did many of these and I have never had a customer not be completely satisfied with it. Many are towing 30' Airstreams with them. You can still improve the tire size when the time comes but it is not as critical as with the 04 (most SUV's and trucks suffer from tire envy so this is not uncommon on most of them). You might be able to trade up to a good one for not a lot of money and that might make more sense than putting dollars into the old one.
I hope this helps.
Andrew T
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Old 02-05-2016, 07:34 AM   #19
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
One other item, the 22 sport is the easiest towing Airstream (easier than the 16')because of its reduced aerodynamic drag which matters for more than the weight difference.
Andrew T
Andrew Thomson
London, Ontario
Old 02-05-2016, 01:18 PM   #20
Andrew T
Thanks Andrew! That is a wealth of useful information. You are right that perhaps an upgrade to a few years newer TV would be prudent. We are new to all of this and it is scary when safety is involved, I know better than to assume it will be done right but its hard to know what "right" is as a newbie. your post helps tremendously.
Thaks everyone for you wonderful and insightful input!
Old 02-05-2016, 01:33 PM   #21
B00merang's Avatar
2010 20' Flying Cloud
Hailey , Idaho
IDRoba is correct...my 20ft FC has heavy wood cabinets...always wondered if they really need to be this solid. But its quality workmanship...and they don't EVER open by themselves. That...and like others have said....extra battery, bumper, etc. Whatever you'll end up getting, you'll have a great time. Jon
As an aside, I'm 6'6" and can walk through my FC without ducking, or sleeping curled up in the bed.
B00merang is offline   Reply With Quote
Old 02-05-2016, 08:20 PM   #22
Andrew T
Andrew, One more question if you can. I really love the floor plan of the 20 FC. That would be my first choice. How is it to tow? If drag trumps weight, would this be a possible option with the upgrades [equptment or new TV] you suggested? The salesman said no because of the weight. It seems that on occasion, however, they are a wee bit mistaken about stuff.
Thanks again!
Old 02-05-2016, 08:24 PM   #23
Thanks for the insight! The 20 FC is by far my favorite floor plan. I love the larger kitchen. My Hubby's vertical build means that I have to take bed length into considerations too. Marriage is a compromise sometimes!
Old 02-05-2016, 09:40 PM   #24
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Everyone has their favorite floor plan. We moved to the 23FB to get the dual axle and if we only wanted a single, we would turn to the 22 sport. However, there are lots of folks that really, really like the 20. There is a series of threads on the 20. Spend some time and find those to get a better idea on the advantages. You need to go to a dealer with lots of trailers in inventory and sit/compare/consider all the options. You will find the one you want/need. We talked to a couple this weekend. They have a 19 that they find perfect. If the 20 is your rig, you will find a way to make it work.
A trailer weighs one weight dry and one weight loaded with full tanks. If you take care in how you load your trailer it is not necessary for it to weigh full gross weight. An aluminum LPG tank saves a few pounds. Paper plates weigh less than china and are faster to clean up. You get the idea.
Good luck with your search. Travel Safe. Pat
Old 02-05-2016, 11:29 PM   #25
2008 22' Sport
Bar Harbor , Maine
We have a 2008 22' Sport. We chose it as we have a Honda Pilot. The combination is great but you get to the max tow wt (4500) without much extra gear and also to max TV wt with the tongue wt plus two passengers and gear. We pack a lot so added a 2013 Serria with cap to carry more water, gray tank, more battery etc. we still use the Pilot fie a weekend sometimes and to turn the Sport around in our tight yard. The pickup truck has a poor turn radius.
Mainely Fish is offline   Reply With Quote
Old 02-07-2016, 05:14 AM   #26
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
You can tow the 20' with either your current Pathfinder with the few changes or a next Generation Pathfinder. On the 20 I like to change the tires to 16" rims with 225/75R x 16" LT tires. It is a little too heavy for the 15" rims. Your dealer should be able to do this change for you quite easily. The stock 15" will be fine for a spare. It is extremely unlikely you will ever get a flat with the Michelins and the size is close enough for a spare.
Andrew T
Andrew Thomson
London, Ontario
Old 02-10-2016, 08:47 PM   #27
Cypress , California
We have a 2015 Toyota 4Runner and we are considering a 22 ft. sport or a 19 ft. trailer. Any recommendations on towing with this vehicle--I am a newbie.
Thank you
jmatson is offline   Reply With Quote
Old 02-17-2016, 01:56 PM   #28
CruizinDux's Avatar
Eugene (Tracktown USA) , Oregon
Originally Posted by TeeTaylor View Post
Hello everyone, I am new to the forum and loving it!
My hubby and I are shopping for our first trailer. Our TV is rated to tow 5k. We feel like we could go up to a 19 or 22 at the 4500 lb loaded wieght rating. My question is this. Why is the 20' flying cloud 500 lbs heavier than the 22' sport? It is listed at 5000lb loaded. I love the layout of the 20' and that would be my choice but I don't feel comfortable pulling at total capacity of the TV. I am just wondering if anyone know why the shorter trailer weighs more.
TeeTaylor, you make want to read the 20 footers thread. Tow discussion is all over that map as a general rule.
We love ours and we just returned from a 19 day maiden voyage to San Diego...2 dogs (one lg and 1 small) and 2 bikes.
http://www.airforums.com/forums/f516...rs-127845.html
Hard to make a bad model decision w Airstream. good luck
p.s. Seems I read (IDROBA maybe) that the 20 frame is 5 inch vs 3 or 4 of other models.
CruizinDux is offline   Reply With Quote
From the Noob desk: weight vs. weight distributing TINLOVE Hitches, Couplers & Balls 5 10-12-2014 10:10 PM
1980 Excella (31 Ft) Gross Weight/Tongue weight? jnichols 1981 - 1983 Excella 9 07-23-2011 01:54 PM
Tongue weight and weight distribution Bex Hitches, Couplers & Balls 8 06-06-2010 12:11 PM
Total Weight & Tongue weight of 24' Argosy woody_strohm Our Community 3 12-21-2008 10:25 PM
Refined TV weight numbers = required weight distribution? flyfishfred Hitches, Couplers & Balls 4 01-12-2008 08:13 PM
