Go Back   Airstream Forums > Airstream Community Forums > Dollars & Cents > Title, VIN & Registration
Old 06-13-2009, 06:29 AM   #1
Profile:  1968 26' Overlander
Durham , North Carolina
VIN Number decipher please
Can someone decipher this VIN for me?
1268J175
Pete
goswick is offline   Reply With Quote
Old 06-13-2009, 07:30 AM   #2
Profile:  1974 31' Sovereign
beautiful downtown Aurora , Ontario
Send a message via ICQ to Aage
Probably the first character is the letter "I".
International
26'
1968
made in Jackson Center, IL
#175 off the line, twin bed
Maybe. I'm no pro at that.
The road to a friend's house is never long. (Old Danish Saying)
Aage is online now   Reply With Quote
Old 06-13-2009, 07:44 AM   #3
Thanks....
Pete
Old 06-13-2009, 09:19 AM   #4
Well-Preserved
overlander63's Avatar
International
26'
1968
My Captain Power Decoder Ring agrees with you.
Old 06-13-2009, 09:33 AM   #5
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 62
My ring says, "Drink more Ovaltine".
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 06-13-2009, 11:56 AM   #6
BIGED52's Avatar
Profile:  1967 22' Safari
MILAN , Illinois
I need to ID these Argosy Vin #'s
I have located two Argosy trailers but would like to know more about them. Here is the info I have but the windows are all covered so I cannot tell what floor plans look like. One trailer only says Argosy on the end caps, the other has Argosy 24 plate near entrance door.
Argosy vin# 26D50132
Mfg Date 9/74
GVWR 6200 lbs. This is a larger trailer than the 24' below and has a Zip Dee awning. Both have tandem axles this one has had the axles replaced and aluminum wheels added. The entire exterior paint color is (beige/sand/ tan).
-----------------------------------------------------------------------Argosy 24 vin# 24T4V1015
Mfg Date 6/74
GVWR 5800 lbs. This is a 24 foot that has been sitting in the same spot for 9 years and has never moved. It has a Carefree awning on it that appears to be the type that the arms can detach from the bottom mounts and be used like patio poles. This one has 4 original hub caps that look like my Airstream hub caps but the color of the squares and the backgroud color appear to be tan to match the lower exterior color. The upper half is white.
-----------------------------------------------------------------------I also found this Airstream
Safari vin# L23T2-S1170
It has the ghosted WBCCI number 3880 on the end caps. Can someone Id these trailers for me and is the first one a '75 model year build? I think the Airstream is an early 70's model Safari. It has two small D shaped windows on either side of the front window. Thanks, Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004
AIR#7110
"My tire was thumping, I thought it was flat!
When I looked at the tire... I noticed your CAT!"
Burma Shave
BIGED52 is offline   Reply With Quote
Old 06-13-2009, 12:32 PM   #7
Phoenix , Arizona
Images: 62
Argosy vin# 26D50132 - This VIN is a little strange, but in the Airstream world that is not uncommon. I would say it was a 26 foot 75 Argosy with the Double Bed layout. It does not indicate the plant it was built in.
Argosy 24 vin# 24T4V1015 - This would be a 74 Argosy with twin beds, made in Versailles, Ohio.
Safari vin# L23T2-S1170 - This would be a 72 Safari (22 foot) with twin beds, made in California with the standard Land Yatch trim.
Richard
Old 06-13-2009, 04:07 PM   #8
BIGED52's Avatar
MILAN , Illinois
Thanks Richard, I knew someone would help me out! I have to do more searching on this trio. The 24 foot has a made for Elmer and Mary Langel or Lancel brass plate by the door. The one that interested me the most was the Argosy that doesn't say the length anywhere on the trailer. Could the ZERO in the 24 foot vin # be an "O" for Ohio? Ed
AIR#7110
Burma Shave
Old 06-13-2009, 05:55 PM   #9
Well-Preserved
Ed, that strange serial number may be a California Argosy. They did make a handful there.
Old 06-13-2009, 11:37 PM   #10
BIGED52's Avatar
MILAN , Illinois
Thanks, I'll drop by where they are parked and see if I can find and more info on it. Ed
AIR#7110
Burma Shave
Old 07-05-2009, 05:42 PM   #11
West Richland , Washington
This is so close to the original request, I hope yall don't mind me tagging on. Could you help out with my VIN number. Its I268-S718-2754. I follow the information up above but it seems I have a few more digits than Pete describes. So whats with the last 4 digits?
I just registered because I'm soon to be the owner of this trailer. I've been lurking in the shadows for a couple of years trying to line out the necessities for owning an airstream (like where to park it and a proper tow vehicle). This is a sweetheart deal but the inside of the trailer will require a lot of work. Its been sitting unocuppied for 5 years or more.
I've been thru a lot of the threads on the forum and I'm really looking forward to refurbishing it. I've followed the Airforums long enough to know you guys really know your stuff and are more than willing to give lots of advise, which I know I will soon need. Thanks in advance guys & gals.
By the way, that guy Andy rocks!
JIMandPJ is offline   Reply With Quote
Old 07-05-2009, 06:40 PM   #12
richinny's Avatar
Profile:  1994 34' Limited
Westchester Cty. NY , & Miami FL
welcome aboard! we have at least three andys here... and they all rock!
Ricky
Ingrid - my unofficial '"World's Oldest Airstreamer"
January 1909 - October 2008 R.I.P.
Old 07-05-2009, 07:28 PM   #13
Mikethefixit's Avatar
Profile:  1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Aage
One small correction, ITS Jackson Center,Ohio NOT Ill. It appears you could use a tour.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336
Mikethefixit is offline   Reply With Quote
Old 07-08-2009, 10:09 PM   #14
Originally Posted by Mikethefixit View Post
Aage
Whoops! At least I didn't call it Jacksonville again, as I did in another post a while back.
And to think I was within an hours drive of it on the way to FL last February. SWMBO wasn't interested though.
Decipher VIN - think it's a 1960 Safari gardener Title, VIN & Registration 8 06-09-2009 05:01 PM
VIN Number AZAL55 Title, VIN & Registration 12 06-04-2009 07:33 PM
VIN Decipher Code? Picture of Plaque captmorgan Title, VIN & Registration 4 04-19-2009 11:09 PM
VIN Decipher Code??? captmorgan Title, VIN & Registration 1 04-14-2009 08:02 PM
Vin Number? chapparel Title, VIN & Registration 12 12-01-2006 03:14 PM
