06-13-2009, 05:29 AM
1968 26' Overlander
Durham
, North Carolina
VIN Number decipher please
Can someone decipher this VIN for me?
1268J175
Pete
06-13-2009, 06:30 AM
Ottawa
, ON
Probably the first character is the letter "I".
International
26'
1968
made in Jackson Center, IL
#175 off the line, twin bed
Maybe. I'm no pro at that.
“Courage is being scared to death, but saddling up anyway.” ...John Wayne...........................
06-13-2009, 06:44 AM
1968 26' Overlander
Durham
, North Carolina
Thanks....
Pete
06-13-2009, 08:19 AM
Retired.
, At Large
International
26'
1968
My Captain Power Decoder Ring agrees with you.
06-13-2009, 08:33 AM
2002 25' Safari
Dewey
My ring says, "Drink more Ovaltine".
Richard
06-13-2009, 10:56 AM
1967 22' Safari
MILAN
I need to ID these Argosy Vin #'s
I have located two Argosy trailers but would like to know more about them. Here is the info I have but the windows are all covered so I cannot tell what floor plans look like. One trailer only says Argosy on the end caps, the other has Argosy 24 plate near entrance door.
Argosy vin# 26D50132
Mfg Date 9/74
GVWR 6200 lbs. This is a larger trailer than the 24' below and has a Zip Dee awning. Both have tandem axles this one has had the axles replaced and aluminum wheels added. The entire exterior paint color is (beige/sand/ tan).
-----------------------------------------------------------------------Argosy 24 vin# 24T4V1015
Mfg Date 6/74
GVWR 5800 lbs. This is a 24 foot that has been sitting in the same spot for 9 years and has never moved. It has a Carefree awning on it that appears to be the type that the arms can detach from the bottom mounts and be used like patio poles. This one has 4 original hub caps that look like my Airstream hub caps but the color of the squares and the backgroud color appear to be tan to match the lower exterior color. The upper half is white.
-----------------------------------------------------------------------I also found this Airstream
Safari vin# L23T2-S1170
It has the ghosted WBCCI number 3880 on the end caps. Can someone Id these trailers for me and is the first one a '75 model year build? I think the Airstream is an early 70's model Safari. It has two small D shaped windows on either side of the front window. Thanks, Ed
1967 Safari Twin "Landshark" w/International trim package
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
06-13-2009, 11:32 AM
2002 25' Safari
Dewey
Argosy vin# 26D50132 - This VIN is a little strange, but in the Airstream world that is not uncommon. I would say it was a 26 foot 75 Argosy with the Double Bed layout. It does not indicate the plant it was built in.
Argosy 24 vin# 24T4V1015 - This would be a 74 Argosy with twin beds, made in Versailles, Ohio.
Safari vin# L23T2-S1170 - This would be a 72 Safari (22 foot) with twin beds, made in California with the standard Land Yatch trim.
Richard
06-13-2009, 03:07 PM
1967 22' Safari
MILAN
Thanks Richard, I knew someone would help me out! I have to do more searching on this trio. The 24 foot has a made for Elmer and Mary Langel or Lancel brass plate by the door. The one that interested me the most was the Argosy that doesn't say the length anywhere on the trailer. Could the ZERO in the 24 foot vin # be an "O" for Ohio? Ed
06-13-2009, 04:55 PM
Retired.
, At Large
Ed, that strange serial number may be a California Argosy. They did make a handful there.
06-13-2009, 10:37 PM
1967 22' Safari
MILAN
Thanks, I'll drop by where they are parked and see if I can find and more info on it. Ed
07-05-2009, 04:42 PM
1968 26' Overlander
West Richland
This is so close to the original request, I hope yall don't mind me tagging on. Could you help out with my VIN number. Its I268-S718-2754. I follow the information up above but it seems I have a few more digits than Pete describes. So whats with the last 4 digits?
I just registered because I'm soon to be the owner of this trailer. I've been lurking in the shadows for a couple of years trying to line out the necessities for owning an airstream (like where to park it and a proper tow vehicle). This is a sweetheart deal but the inside of the trailer will require a lot of work. Its been sitting unocuppied for 5 years or more.
I've been thru a lot of the threads on the forum and I'm really looking forward to refurbishing it. I've followed the Airforums long enough to know you guys really know your stuff and are more than willing to give lots of advise, which I know I will soon need. Thanks in advance guys & gals.
By the way, that guy Andy rocks!
07-05-2009, 05:40 PM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
welcome aboard! we have at least three andys here... and they all rock!
Ricky
07-05-2009, 06:28 PM
1977 27' Overlander
Trotwood
, Ohio
Aage
One small correction, ITS Jackson Center,Ohio NOT Ill. It appears you could use a tour.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
07-08-2009, 09:09 PM
Ottawa
, ON
Originally Posted by Mikethefixit
Aage
Whoops! At least I didn't call it Jacksonville again, as I did in another post a while back.
And to think I was within an hours drive of it on the way to FL last February. SWMBO wasn't interested though.
07-08-2009, 09:49 PM
Corona
The last four numbers are production code numbers that has nothing to do with the serial number.
07-08-2009, 10:13 PM
Moderator Emeritus
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna
Greetings Ed!
The Argosy 24 has a fairly logical VIN for a coach late in the model year.
24 = Measurement in Feet (Rounded According to Airstream Method)
T = Center Twin Bed Floorplan
4 = 1974 Model Year
V = Versailles, OH
1015 = Sequential Production Number
I don't have all of my information at hand as I am on the road in Southwest Wisconsin, but if my memory is correct the 1015 is the coach's position within the entire production sequence for Argosy RVs in 1974.
The Argosy 26 VIN also is basically as one would expect for a coach manufactured in the first month of the model year.
Argosy vin# 26D5?0132
26 = Measurement in Feet (Rounded Using The Airstream Method)
D = Center Double Bed Floorplan
5 = 1975 Model Year
? = Production Plant (V=Versailles, OH/S=Cerritos, CA)
0132 = Sequential Production Number (August would be first full month of production for 1975 models).
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
07-08-2009, 10:21 PM
2005 22' Safari
Gresham
, Oregon
International
26'
1968
Right or wrong that is pretty impressive.
07-08-2009, 10:26 PM
2005 22' Safari
Gresham
, Oregon
Originally Posted by overlander64
Greetings Ed!
4 = 1974 Model Year
V = Versailles, OH
5 = 1975 Model Year
Kevin
Again, pretty impressive.
07-09-2009, 06:51 AM
Iwannagocamping
Rineyville
, Kentucky
OK, so I could swear I found a chart or flow sheet somewhere to decipher this..
But then here is this active thread with knowledge just all over it, so..
I31-A9J-2485
I get the "international 31 foot" and guess the 2485 is its sequence number. but the A9J ?
but I also have a set of numbers/letters on the top half of the serial number plate that are:
A-153 and what appears to be: OJ .
Thanks for help with the parts I don't understand.
Mark
See our blog here on how two RV/AS rookies tackle a 1979 Sovereign resto!!
Just the photos.. (sometimes you don't need the blog, just a picture worth a thousand words..)
1979 Sovereign International
2004 Ford Expedition Eddie Bauer
2 Golden Retrievers
Air # 36788
TAC# 3179
WBCCI # 1265
07-12-2009, 05:28 PM
Corona
I31-A9J-2485
Mark
The A9J is part of the serial number.
The "A" is for a center bath twin (if I remember correctly).
The 9 is the year (1979)
The J means it was made in Jackson Center, Ohio.
