Go Back   Airstream Forums > Airstream Community Forums > Dollars & Cents > Title, VIN & Registration
Old 04-18-2008, 11:19 AM   #1
1968 28' Ambassador
GRAND JUNCTION , Colorado
VIN Number
This is probably the wrong place to ask this but I didn't see a general question area. I have a 69 Ambassador that I need to get inspected and titled in Co. I can not locate the VIN plate anywhere, any ideas.
AZAL55 is offline   Reply With Quote
Old 04-18-2008, 11:39 AM   #2
1959 22' Flying Cloud
Escondido , California
If you can't find it anywhere you can always try the frame rail. Airstream sometimes put it on the top of the frame rail at the front of the trailer. Mine was on the left hand side (facing the trailer) at the very edge of the trailer under multiple layers of paint. I have a 59 and I don't know how consistant they were about putting it on.
Gilbert
2bkidfree is offline   Reply With Quote
Old 04-18-2008, 11:47 AM   #3
SteSpot's Avatar
1982 24' Airstream 240
Ventura , California
Our 69 Overlander
Our 69 Overlander had the vin # on a plate to the right of the front door......pj
Paula & Ed
WBCCI # 8252 Air#13593
1982 24'Motorhome (82Ste P)
SteSpot is offline   Reply With Quote
Old 04-18-2008, 11:50 AM   #4
Zeppelinium's Avatar
1973 23' Safari
1977 23' Safari
2018 25' Flying Cloud
Palmer Lake , Colorado
It's a 2x3" plate below the front window on the street side, just above the tongue as it goes under the shell. It's also imprinted on the Airstream plate immediately in front of the door. The number has no resemblence to a modern VIN. Also, the first letter is usually a letter "I", not the numeral "1". You will most likely find that this was previously registered with a leading "1".
Zep
Zep@Charmedquark.net
Old 04-18-2008, 03:08 PM   #5
1968 28' Ambassador
Thanks, Ill start looking
Old 04-18-2008, 03:58 PM   #6
1969 29' Ambassador
orange Park , Florida
Your profile says 68 and your post says 69, do you now have 2 A/S? I have a 69 Ambassador and the vin is on a plate, curb side under the window in front of the door. Zep is right on as to being titled with a 1 instead of an I as mine was also done this way.
69AmbassFl is offline   Reply With Quote
Old 04-18-2008, 04:23 PM   #7
vhord's Avatar
Images: 96
Did Airstream lose their "I"?
Zep
I understand that it is suppose to be an "I" but Airstream put a "1" on both of my name plates and my title states the same. Maybe they lost their "I" stamp.
vhord is offline   Reply With Quote
Old 04-18-2008, 11:55 PM   #8
1973 23' Safari
1977 23' Safari
Wow, usually that first character is just a vertical slash, like a small "l", so it's indeterminate. I know others can't wait to comment on this...
Zep
Old 04-19-2008, 06:42 AM   #9
Retired.
. , At Large
Zep
Ours is definitely an "I":
Old 04-19-2008, 07:56 AM   #10
SteSpot's Avatar
Not sure if you are asking me but
We had a 69 Overlander that was salvaged by the insurance company. We now have a 68 Ambassador that is being recreated by Uwe (www.area63productions.com) update or blog. One Airstream is enough for us.....we have to store it 40 miles from our home. paula
Paula & Ed
Old 04-19-2008, 11:47 AM   #11
goransons's Avatar
1963 22' Safari
2020 27' Globetrotter
State of , Washington
Send a message via MSN to goransons
I'd clean up the top curbside tongue rail, should be stamped there, probably burried under lots of coats of paint and check to see if it is an "I" or 1 in that location, ours was really easy to read after a few minutes with a wire brush on a drill.
goransons is offline   Reply With Quote
Old 04-19-2008, 01:33 PM   #12
centennialman's Avatar
2016 23' International
Centennial , Colorado
Sometimes the vin number will "fade" out with time even though it is still on the plate under the window.
If you have such a plate, whether rubber/plastic or metal, you can rub a little cooking oil over it and the numbers will show themselves easier.
Mine were all but gone and I tried that method. Worked like a charm!
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 06-04-2009, 06:33 PM   #13
MaxAB's Avatar
1977 31' Sovereign
1985 25' Sovereign
South Central Rockies... , "...'Stream'n the Dream" thru the USA
Mine's probably not the only mix-up! I've got a title from the PO that clearly has the numeral "1" as the first character, but my coach displays the letter "I" (India) as the first character in the VIN string.
Can't get it registered in my state, and the AS is from out of state. Very frustrating, any suggestions would be appreciated....
Thansk!
Art - W0ABX
High Desert Country of the Rockies
'85 Sovereign 25'er
WBCCI: 2197; AIR #: 36503; TAC #: NM-5
MaxAB is offline   Reply With Quote
Old 10-15-2010, 03:58 PM   #14
Vin Number
About to buy my first airstream tradewind 1968 ... how can i check from the vin number who the owner is ... it appears to be only 12 characters ... is that right ... advice thankfully recieved
Robert Burns is offline   Reply With Quote
Old 10-15-2010, 04:38 PM   #15
SteSpot's Avatar
It should be on the badge that is to the right of the door.
Can you post here what you can read? paula
Paula & Ed
Old 10-16-2010, 06:20 AM   #16
MaxAB's Avatar
1977 31' Sovereign
1985 25' Sovereign
Suggestion: Get a digital photograph of the VIN plate. You'll find it on the street side forward low. The number also appears stamped into the "Airstream Placard" on the curb side forward near the "Tradewind" logo. Take the photo to your Department of Motor Vehicles (or equivalent in FL) and do a search on it. Its always cleaner to have the registered named person on the the VIN search MATCH the seller's name. Then, make sure the seller's title VIN MATCHES exactly the VIN on AS Placard.
Since I didn't go through the drill above, I paid extra $'s to have a state-certified VIN inspector inspect my rig and write a report to the DMV. A fairly major hassle that can be avoided on the front end.
I'm good to go now, all registered with my "new" VIN and title.
Good luck and happy trails!
Art
Abu Dhabi (until next August)
Art - W0ABX
'85 Sovereign 25'er
VIN number help mrmossyone Argosy Motorhomes 10 10-26-2007 11:45 AM
VIN Number Silver Threads 1959-69 Tradewind 23 10-20-2007 09:18 PM
Vin Number? chapparel Title, VIN & Registration 12 12-01-2006 02:14 PM
VIN Number BWard Title, VIN & Registration 5 04-14-2006 11:48 AM
VIN number deeinva Our Community 1 08-11-2003 09:04 AM
