Old 01-12-2012, 11:30 AM   #1
supergg's Avatar
1969 31' Sovereign
middleboro , Massachusetts
vin help
I would appreciate any help with understanding my vin number. The number is J180fh131t92179. The trailer is a 31' 1969. thanks
supergg is offline   Reply With Quote
Old 01-12-2012, 12:27 PM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Your VIN# is: I31T9 ? 179
I - (it's an "I" not a #1) It means you have the International package
31 - 31' long (Sovereign)
T - Twin Beds
9 - 1969
2 (?) - Are you sure this isn't a "J" or a "S"? "J" would indicate it was made in Jackson Center, OH & "S" would indicate it was made in Santa Fe Springs, CA
179 - 179th one made
Check out this, it should look familiar.
Not sure of the code for the numbers before the VIN#.
Shari
Old 01-12-2012, 12:47 PM   #3
damonbeals's Avatar
1998 31' Excella 1000
1979 23' Safari
Mooresville , Indiana
Airstream has decoder here.
Airstream, Inc :: Serial Numbers
But you do have some extra stuff on the beginning of the s/n that isn't a part of the s/n.
Damon
damonbeals is offline   Reply With Quote
Old 01-12-2012, 04:30 PM   #4
supergg's Avatar
1969 31' Sovereign
Thanks for the help. It seems as if the first set of numbers is a serial number. It all makes sense now.
Old 01-12-2012, 04:49 PM   #5
CanoeStream's Avatar
St. Cloud , Minnesota
Serial number? Not so sure about that. Was J180fh on a separate line on the badge to the right of your door? Something tickles my memory about how that defines something different...
The 179 is called the sequential production number. This sets it aside from other similar length/bed configuration models made that year. And therefore InsideOut's post best defines what actually is the VIN of your unit.
Does I31T9?179 actually show up on your title? A 2nd location of the VIN can sometimes be found stamped on the right side of the A-frame up front.
5 meter Langford Nahanni
Old 01-12-2012, 05:05 PM   #6
supergg's Avatar
1969 31' Sovereign
I have not checked the a-frame. I will give it a look tomorrow.
Old 01-12-2012, 06:11 PM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I31T9S179 would be a 1969 Sovereign, center twin beds, rear bath, built in Cerritos (Santa Fe Springs)California, 179th unit off the line.
Where is my VIN? MAbdala 1967 Overlander 11 05-17-2012 07:36 AM
VIN questions on old trailer gnowlin Airstream History 9 05-03-2012 08:47 AM
We can't locate the original vin# on our 1966 Tradewind Adams Family 1959-69 Tradewind 9 01-14-2012 11:55 PM
Looking for VIN Melinda Title, VIN & Registration 4 09-27-2011 07:05 PM
VIN doesn't match Airstream guidelines casa3805 Title, VIN & Registration 1 04-02-2011 12:49 PM
