Old 05-23-2006, 09:00 PM   #1
1964 26' Overlander
Spring , Texas
Images: 12
New to Airstream and need help with VIN
Hi, My husband and I are new to Airstreams. We have just bought what we believe is a 1964 Overlander. I can find any info that predates 1969 VINs. We are needing to immediately buy vent covers and I want to make sure we are purchasing the right ones. This will be a full restoration. "Dorothy" is a diamond in the rough. Here are a couple of photos of our VIN. Any ideas?
Name:	<a title=1964 Airstream Overlander 012 sm.jpg Views: 245 Size: 154.9 KB ID: 21599" style="margin: 2px" />
Name:	<a title=1964 Airstream Overlander 050 sm.jpg Views: 178 Size: 102.3 KB ID: 21600" style="margin: 2px" />
Name:	1964 Airstream Overlander 051 sm.jpg
calredcoat is offline   Reply With Quote
Old 05-23-2006, 09:15 PM   #2
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Welcome. I can't decifer your whole serial number but can tell you the '4' is for '64, the 'S' is for Santa Fe Springs, and the 6404 is for April of 1964. So yes, you have a 1964 Overlander. It will need the 14" x 14" vent covers and a 25" x 14" AstroDome or SolarDome, depeding on where it is purchased, for the front rectangular vent. Dorothy looks to be in good shape externally, what's the inside look like? She just needs your TLC and she'll be a beauty!!
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 05-23-2006, 09:34 PM   #3
1964 26' Overlander
Spring , Texas
Images: 12
Inside is a complete do over
Well, It looks like a bomb went of in it. Click image for larger version
Name:	1964 Airstream Overlander 021 sm.jpg
Name:	1964 Airstream Overlander 023 sm.jpg
Name:	1964 Airstream Overlander 024 sm.jpg
Old 05-23-2006, 09:36 PM   #4
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Lots and lots of TLC. I think it was more than one bomb. I say, if its loose, take it out. Even if it isn't, consider taking it out.
FF
Old 05-23-2006, 09:50 PM   #5
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
FF
I agree with Brad, I think that it all needs to come out. That way you can fully inspect the floor and replace what is needed in addition to adding any tanks.
Bill
Just my personal opinion
Old 05-23-2006, 10:53 PM   #6
1969 31' Sovereign
Elizabeth , Colorado
My suggestion is gut it , throw in some army cots and go to the nearest VAC rally you can find. That is where the people who have already done it can be found, You will get help with suggestion, supplies, and some ingenious answers to those questions you don't even know about yet. Good luck. You may not want to take the trailer at this time but get to the rally, Sat noon to 3:00 is normally "Open House" you can visit and inspect most of the units in attendance. It is a great way to start, that's what I did and it made the job a whole lot easier.
stagecoachbill
WBCCI #5345
62 Globe Trotter 19'
69 Sovereign 31'
04 E-350 Van 6.0 diesel
stagecoachbill is offline   Reply With Quote
Old 05-24-2006, 12:50 AM   #7
1964 26' Overlander
Spring , Texas
Images: 12
Inside and VIN
We will definitely gutting the inside of this trailer. Nothing is salvagable. Still wondering if someone can help me with my VIN. We do know that it was built in Santa Cruz, CA. All the numbers are there in the pics. Also, someone suggested going to a rally. We live in Spring, TX (north of Houston) how does one go about finding where the nearest rally is?
Old 05-24-2006, 04:55 AM   #8
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
A picture is worth a thousand words
I think this is the same coach that we were discussing a couple of days ago. From the description, we got an entirely different idea of what you had, the photos help a lot. I agree with the consenus, it is going to need to be virtually gutted. I would try to save the air conditioner, though, as it looks like an early Armstrong unit, and if you can make it work, it will do a great (albeit noisy) job of keeping your trailer cool. Also, it should have only a small hole in the roof for the fan driveshaft to run through, and the smaller the holes in your roof, the better.
Other things I noticed from your pics:
The fridge looks intact. Does it work? If so, you will save a ton of money by not having to replace it.
The range is toast. A brand-new one can be had for $400.
The countertop where the sink is, looks relatively decent, maybe build new cabinets under it.
The rest of the stuff, I can't really tell form the photos, except that if you are going to throw away the divider curtains, I would like them for our Overlander.
Old 05-24-2006, 04:58 AM   #9
CanoeStream's Avatar
St. Cloud , Minnesota
A normal reference is the Airstream FAQ section on VINs: http://www.airstream.com/product_lin...e/faq.html#vin
Dunno, looks like they changed format fairly often back then. Brad is closer than I can get!
5 meter Langford Nahanni
Old 05-24-2006, 05:02 AM   #10
Well Preserved
1993 21' Sovereign
Yes, the serial number format seems completely different from our 1963, only a year different!
Old 05-24-2006, 05:04 AM   #11
Question: your 2nd photo shows a black California badge just to the right of the Land Yacht plate. It starts S5215.... That appears more promising! Can you provide that sequence? Thanks.
I'd guess 142 is the production sequence number.
Old 05-24-2006, 05:09 AM   #12
Well Preserved
1993 21' Sovereign
Bob, I think that is just a sequential certification number issued by California at the time the coach was built, not really anything to do with the trailer, per se.
Old 05-24-2006, 05:20 AM   #13
At least the format is more conventional...
We're muggier than Florida this morning. Go figger!
Old 05-24-2006, 05:14 PM   #14
1964 26' Overlander
Spring , Texas
Images: 12
More pics - California plates
Here is the California name plate. It's a little hard to read. I think this is what it says. M-4 S-5215 3778 A-90965
Name:	1964 Airstream Overlander 062sm.jpg
Name:	1964 Airstream Overlander 067sm.jpg
Name:	1964 Airstream Overlander 063sm.jpg
The inside of the fridge is scary. I think it has to go. It was both gas and electric power. We are not to concerned about tackling most items. However, he memtion that all the wiring would have to be replaced. Does anyone know where I can find resources that would show the wiring diagram of the trailer. I don't the that the a/c is salvagable. This camper has been sitting for about 10 to 15years and was being used as a tool shed. (that alone out to be a crime! )
Name:	1964 Airstream Overlander 052sm.jpg
