Go Back   Airstream Forums > Airstream Community Forums > Dollars & Cents > Title, VIN & Registration
Old 02-02-2011, 07:39 PM   #1
1971 27' Overlander
Naming Nomenclature
I just bought a 1971 Overlander Twin Bed. I am trying to figure out what the model name of this trailer is. Is it an Overlander or International Land Yacht or International or Land Yacht? Pardon my ignorance but I am confused... The VIN starts with a "1" on the title. I am guessing this is a mistake based on what I have been reading i.e. I for International and L for Land Yacht.... Can somebody explain to me what the difference is between a Land Yacht and an International model is, if any? Also, what does the number above the "Land Yacht - a Travel trailer" name plate correspond to? Mine ends with FJ. Thanks for your help. I am already loving the airforums...
lmassa is offline   Reply With Quote
Old 02-02-2011, 07:47 PM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
First VIN reference offered -- see upper left corner at 71Overlander
At some point going back in time 'International' related to units equipped for both 120 volt AC & 12 volt DC operation. I'm not sure where in the 50s, 60s or 70s that still held ground. Seeking any informed responses...
My first take is that you certainlyl have an Overlander.
5 meter Langford Nahanni
Old 02-02-2011, 07:48 PM   #3
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
I had the same question some time ago. Never got an answer. The vin says mine is an Excella and the Land Yacht thing is not in my vin, the the Airstream plate on mine (with the vin on it) says Land Yacht.
So maybe it is a Land Yacht in one sense, but not in another?
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 02-02-2011, 09:27 PM   #4
InsideOut's Avatar
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen , Colorado
Images: 108
Okay, so here it is in a nutshell...
Airstreams in the 50's...for the most part, were named based on their length & interior layouts. A 16' trailer was a Bubble or Caravel, a 22' trailer could be a Safari, Flying Cloud, Caravanner, etc. a 26' trailer was an Overlander or a Cruiser and 30' were Liners or Sovereign of the Road. Also, things were not real standardized - you could get a lot of "one off" builds.
In the 60's...the names still indicated the length - much like in the 50's except, things started to get more standardized. There were two different factories, so there were still slight differences between the models - but they tended to be a bit more consistent. They also introduced levels of finish within the models and more lengths. There could be a "Land Yacht" package which was the basic model or the "International" model which had more features like different wood, upholstery, padded fabric walls at the beds, etc. things that would make them more comfortable for longer trips or on caravans to foreign lands.
In the 70's this pretty much remained the trend...more standardization and features. They also added the Excella line which was another level of finish much like the CCD vs International vs Flying Cloud's of today. The thing that's different about the 70's is one year trailers would be "odd numbered" lengths, and another year they would be "even numbered" lengths...oftentimes the shell didn't change, they just changed what they called it - I suspect for marketing purposes.
Another thing that constantly comes up is a faulty document that roamed around in the Airstream archives for years, which mistakenly indicated a "0" (zero) as an "O" (letter). It stated the "O" stands for Overlander when in actuality it is intended as a "0" (zero) which is just a placeholder when the "Land Yacht" level of finish is present. "I" was used for "International" finishes.
One of the best places for information online to help you compare the differences of the vintage rigs can be found in the Photo Archives...
Fast forward 25-30 years...the confusion really sets in, Airstream started recycling the old names. The same names which used to be used to determine length, now mean a level of finish. And a Land Yacht could be a fiberglass motorhome...
If you want to confirm your model/year/finish package and sometimes layout - post your VIN number and someone will help you decipher it or look it up in the Photo Archives link...
Shari
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 02-02-2011, 10:00 PM   #5
Ottawa , ON
That's a great answer, Shari. Thanks!
Old 02-02-2011, 10:50 PM   #6
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
Lookie here:
Airstream, Inc :: 70s
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Old 02-03-2011, 06:02 AM   #7
1971 27' Overlander
Thanks everbody for pitching in! I think that I got it....almost.
My VIN number (on the IL Title) reads: 1 27 T 1 J XXXX. I tried to match it with my VIN plate and was able to decipher all the letters and numbers EXCEPT the first one that is too faded to read (any idea how to revive it by the way?)
So following the documentation you guys were kind enough to point me to, here is what I can make of it:
1- mistake - should read I for International Model
27 - 27 Ft
T - Twin Bed (indeed)
1 - 1971
J - Made in Jackson Center
XXXX - sequential number
Am I on the right track here?
Old 02-03-2011, 06:22 AM   #8
Always learning
Lance M's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Lance M
lmassa,
You have it correct. My '72 Ambassador has an I for the serial number indicating International. On the title it is listed as 1. I told the DMV clerk it should be I and she said that I is not an accepted character for a VIN. She explained to me when the DMVs all went digital and instituted VINs instead of serial numbers some letters were not allowed to be used to avoid confusion (I,O)
Confusion avoided?
Lance
Lance M is offline   Reply With Quote
Old 02-03-2011, 06:35 AM   #9
Addicted
exthemius's Avatar
1971 27' Overlander
Currently In: Skowhegan , ME
Images: 16
27 - 27 Ft
1 - 1971
You basically have the sister A/S to ours....we have the '71 27' Double/Double model (where we have another gaucho in the rear rather than a set of double twins -- and the wardrobe across from it).
-Shawn
TAC OK-42
Visit our crazy full-timing blog (us,kids and dogs living the dream): https://www.airstreamingdreaming.com/
Join us at the TAC Walt Disney World Rally, November 4th - 10th, 2012: https://www.theairstreamersclub.org/rallies/tac-fw-wdw
exthemius is offline   Reply With Quote
Old 02-03-2011, 07:11 AM   #10
Silverhobby's Avatar
Greeeneville , Tennessee
Going back to the day when we used typewriters instead of computers, the lower case L was used in place of a one on the type written numbers. This has led to a problem as time has passed by.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
model, names
