Old 12-29-2008, 09:59 AM   #1
Silverwanabe's Avatar
1967 26' Overlander
Winston Salem , North Carolina
Images: 107
Location of 67 VIN on A frame
Hi Folks,
Where is the VIN on the 67 frame?
I have been removing paint and have not found the VIN.
I did find a small plaque riveted on the curbside frame mentioning battery polarity.
One poster said there was not one there on his 67.
Greg
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
Silverwanabe is offline   Reply With Quote
Old 12-29-2008, 10:08 AM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Hi Greg. There's not a badge to the right of the door? Not a sure thing depending on what the previous owner did...
The VIN will have the format seen in the upper left corner of this webpage - 67Overlander
VINs on the A frame seem hit and miss for older units. On my '74 Argosy they were about 1/2" high numbers on top of the curbside box frame just behind the LP tanks. Tanks, antisway setups or just plain paint can block these -- if they're there at all.
5 meter Langford Nahanni
Old 12-29-2008, 10:15 AM   #3
1967 26' Overlander
Images: 107
Thanks for the quick response.
The plaque by the door with the VIN is there intact.
Greg
Greg
Winston Salem, NC
WBCCI 5218,
Old 12-29-2008, 10:20 AM   #4
Originally Posted by Silverwanabe View Post
Hi Folks,
Greg
The serial number is stamped into the frame near the LPG bottle rack, usually on the curb side.
Remove all the paint. Carefully inspect both sides of the A-frame for the serial number.
Also, look for marks from a grinder. Back then, people would steal the trailer and remove serial numbers.
How do I know??
I was with the Insurance division of Airstream, which was called Caravanner Insurance Company.
What is the serial number as posted on the plate near the door?
VIN Number Location trogers713 Title, VIN & Registration 8 01-16-2014 05:41 AM
VIN # Location ??? tops Title, VIN & Registration 2 01-03-2005 08:50 PM
Vin # location JNB Title, VIN & Registration 2 11-15-2004 04:11 PM
VIN # location on '89 Excella rfield54 1987 - 1989 Excella 3 08-08-2004 07:24 PM
P30 VIN location dienst1 Airstream Motorhome Forums 5 01-14-2003 03:11 PM
