Old 02-07-2012, 11:18 AM   #1
Frankiefiveo's Avatar
1966 26' Overlander
Weeki Wachee , Florida
AIR Number
I have a 1966 Airstream Overlander and there is 2 AIR numbers on it. the number easiest to read is 16872 and the number hardest to read appears to be 12932.
why would a new number be put over an old number? how can i find out who those numbers are connected to?
Frank
Frankiefiveo is offline   Reply With Quote
Old 02-07-2012, 11:25 AM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Are you sure they are "Air Numbers" and not WBCCI numbers?
Most likely, they are WBCCI numbers and they are membership numbers that go with the people as members rather than the trailer. So that would mean that your trailer was previously owned by two different members. People usually put the new numbers over the old ones because traditionally they go over the window front and back. In some cases, a new WBCCI member can obtain the old numbers if the old numbers are no longer used by the previous member for at least two years. If they are still in use, a similar number can be requested to cover up the old numbers substuting 3's for 8's, etc.
As far as finding out who the numbers were originally assigned to goes, there are several people here online that have old WBCCI membership directories and can look them up for you. Check out this thread to see who does this sort of thing.
AirForums numbers are a relatively new thing - it is highly unlikely that your trailer would have already had two previous owners that would have displayed their Air numbers.
Shari
Removing privacy curtain so air conditioner can be removed saltrm1 Furnaces, Heaters, Fireplaces & Air Conditioning 5 04-11-2013 05:26 PM
Air Forums Culture Ridgerunner3 Off Topic Forum 35 01-25-2012 06:25 PM
Can you run both Air Conditioners with the Genset? Keyair Classic Motorhomes 4 08-26-2011 05:32 PM
