Old 08-18-2005, 06:30 PM   #1
Canuks's Avatar
Damage to window guards
While cleaning my AS lately I noticed that I have damage to both right and left side front window covers. The right suffered a nasty stone chip. It looks like a big spider and its the size of a loonie. I'm just happy that the guard was there to protect the glass.
On the left side there is a four inch crack from one of the upper corners running into the panel.
Has anyone had to replace these parts? It looks like it may be easy to do myself. I know a plastics supplier that I might be able to get the plastic from. Is it Lexan? I thought I could just use the old ones for a template and cut two new ones. It seems to be less than 1/16 inch thick. Probably be cheaper for me to buy a sheet. I could zip it out with my router and a pattern bit. Please help with brand of plastic if possible
Does anyone know if the left one with the crack might be covered as a manufacturing defect? My closest AS dealer is a four hour drive and if I call them they will just want me to bring it in to look at it. If they tell me its not covered I have wasted the whole day plus two tanks of gas...
Canuks is offline   Reply With Quote
Old 08-18-2005, 11:22 PM   #2
desi arnaz's Avatar
do not , i repeat go to tap plastics..........$9.50 sqf i found a company in sacto that has the same lexan for $4.50 a sqf
the problem is getting the bend right.
desi arnaz is offline   Reply With Quote
Old 08-19-2005, 08:06 AM   #3
Canuks's Avatar
Was it a major job to replace? I would think Lexan (if thats what the factory uses) at that thickness would bend like cooked noodles.
Old 08-19-2005, 09:05 AM   #4
AYRSTRM2's Avatar
1966 22' Safari
Armada , Michigan
The trouble you'll have is telling the guys in America what a "Loonie" is
John
AYRSTRM2 is offline   Reply With Quote
Old 08-19-2005, 09:24 AM   #5
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
I knew what he meant...
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 08-19-2005, 09:25 AM   #6
desi arnaz's Avatar
a gold color canadiain coin with a loon on the front $2 i think?
Old 08-19-2005, 09:26 AM   #7
AYRSTRM2's Avatar
1966 22' Safari
Armada , Michigan
Oh, I thought it was the thing that came out of the middle of donuts made by a hockey player!
John
Old 08-19-2005, 09:27 AM   #8
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Some think it is the way a canuk would say loogie......
Brett G
Old 08-19-2005, 01:14 PM   #9
Craftsman
Guest
Posts: n/a
Looks like the thread got sidetracked and the question wasn't answered. My window covers are also damaged but the frames are just fine. If anyone knows: what is the material, what thickness and can it be replaced? Has anyone actually replaced the ( Lexan?) and what were the results.
Old 08-19-2005, 01:36 PM   #10
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
I replaced the rear canopy on my two-place glider with a Lexan sheet. The original plexiglass canopy had a slight (1/2") crown, but I figured a flat curve would serve for a 1970s era glider. I don't remember the thickness I used, but I had no problem bending the material to fit the frame. The required inverted "U" curve was far tighter than would be required for an Airstream stone guard.
The replacement canopy worked fine for the several years that I owned the glider before selling it.
John W. Irwin
WBCCI #9632
Old 08-19-2005, 01:44 PM   #11
Alden Miller's Avatar
1993 34' Excella
, Maryland
I've got a couple cracks also
In my window guard that is...
If I do replace it I think I am going to get a sheet of lexan and cut it myself. The 4' x 8' sheet is what I would have to get to be able to cut a piece that fits. I think that the curvature would be taken care of by the aluminum frame.
With the cracks that I have, I have drilled 1/8" stop cracks at the end of the crack. This has helped keep them from extending any further. As long as they stay this way it will be a while before I replace the guard.
-Alden
1993 34' Excella 1000
2005 Dodge Ram 3500 Diesel
(No it doesn't have a HEMI in it)
Alden Miller is offline   Reply With Quote
Old 08-20-2005, 09:35 AM   #12
Canuks's Avatar
I guess that I will track down the material and see how it works. I finally have a digital camera so maybe I will post some pics.
Old 08-20-2005, 04:33 PM   #13
jimmickle's Avatar
2000 31' Land Yacht
With the failures that you discribe, the material is NOT polycarbonate (Lexan). It most likely is acrylic (Plexiglass). One problem to be aware of with polycarbonate is that cantact with any hydrocarbons will make it craze. However, it is much stronger and impact resistant than acrylic. It is also much more expensive.
Jim Mickle
jimmickle is offline   Reply With Quote
Old 08-20-2005, 10:19 PM   #14
1973 25' Tradewind
1964 19' Globetrotter
Centerville , Utah
How about replacing it with aluminum?! Someone oh this forum has a rock guard made of aluminum...looks quite cool. Only downside is the opaqeness (sp?).
tclay
Stormy Weather is offline   Reply With Quote
Window latch dilemma maxandgeorgia Windows & Screens 5 05-18-2018 10:35 AM
1974 Excella front window docu post john hd 1973-1974 Excella 500 22 08-06-2004 01:53 PM
Minuet Front Window Rock Guards overlander64 All Argosy Trailers 54 12-01-2003 09:13 PM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
