Old 03-28-2015, 03:41 PM   #1
canton , Massachusetts
what is the right price
Just looked at a 1975 31' excella the exterior shell is in perfect condition less one small dent at the floor line. Everything is original, I can't tell about the subfloor, it has been sitting for the last 5 years and has seen limited road time over it's lifetime, the water hasn't been on for 5 years, the interior is very tired but all there, the cushions are torn and there is some mold from lack of ventilation. The owner has used it for overflow sleeping only,the Ac probably doesn't work and the refrig is shot. It's a rear bathroom unit. He's looking for $10,000, a couple of dealers tell him they can get him that and maybe more.
Everything I read and see tells me it's $2000 to $4000. I'm looking for a total gut and rebuild, so this would be a great one to play with. I don't what to overpay but I want to be fair. What is the right number. The fact that it's local is a big plus and worth something.
oldredhead52 is offline   Reply With Quote
Old 03-28-2015, 04:08 PM   #2
1994 34' Excella
Warren , Manitoba
If it has had little road use you can plan on replacing axles and tires right away. Fridge and A/C are probably gone or ready to go. Hot water tank is beyond it's lifespan. You could have plumbing issues, bad floor issues, and several other hidden things. Curtains and upholstery sound like they are ready to replace, and flooring as well. If everything was replaced by the PO, $10K would be a good price. The way you describe it, you are correct at $2-$4K. You could put $10-$12K into it so fast if things need replacing. I wouldn't touch it at his asking price. Been there, done that!!! Chris
WBCCI #7394
2002 Chev 2500 HD Duramax
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Right sealants on the right sections BoldAdventure Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 11-22-2014 11:09 AM
2010 23d Int. Does this price sound right? Jezibels Buyer Guidelines 8 10-12-2009 06:49 PM
Right Rear Tire Wearing on Outside & Right wheels Closser together than left wheels Tnsawdust General Repair Forum 7 04-10-2009 07:49 PM
The right acid works with the right applic got polish Cleaning, Stripping & Polishing 1 07-17-2008 08:50 PM
The Price Is Right asherkobin Off Topic Forum 1 05-17-2007 04:43 AM
