Old 06-10-2009, 09:41 PM   #1
slk
Elk River , Minnesota
Value of 1972 Safari 23'
I am looking at a 23' Safari 1972. The owner does not know if the fridge, stove, heater, or much of anything works in this trailer. The hot water heater is not there. He bought it a couple of years ago to fix up and he has lost interest. The tires are somewhat checked. I don't even know if the brakes work. The interior is OK. The skin on the outside is in very good shape for a 72. All windows work. The floor seams to be solid. He is asking $6000
Tell me what you think
slk is offline   Reply With Quote
Old 06-10-2009, 10:23 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings slk!
While the 23' Safari is a desirable coach, there are too many unknowns to support the asking price. It could easily take in excess of $3,000 to get the coach ready for camping:
  • If the refrigerator doesn't work $1,200 for a new Absorbtion-type refrigerator
  • If the air conditioner doesn't work $700 for a replacement
  • If the furnace doen't work $700 for a replacement
  • If the water pump doesn't work $200 for a replacement (assuming PAR)
  • If the range isn't safe to operate $700 for a replacement
  • Known need of new water heater -- $700 for replacement
  • Updating LP tanks to OPD regulations -- $125
  • If the LP Regulator isn't safe to operate -- $100
  • If the Univolt doesn't work -- $300 to replace (assuming new replacement)
My estimation would place a reasonable value in the range of $3,500 to $4,500. If you are very interested in this coach, you might ask the owner if you could have it inspected by an RV dealer -- the dealer wouldn't necessarily have to be an Airstream dealer as the appliances are typical of many RVs of various manufacturers.
Kevin
Kevin D. Allen
AIR #827
Old 06-11-2009, 06:28 AM   #3
slk
Thanks Kevin
Those figures are just about what I was thinking. I hate to low ball someone, but it should be his responsibility to know what is working or not. If he dosent know then he should expect someone to shoot low with an offer. The trailer does have some very good points. No dents, no leaks, and a sound floor. Seat/bed cushions are in good shape too. Only 1 of the cabinet roller faces has come apart. All of the slats are there. I presume you can order some of that material.
Steve
Old 06-11-2009, 07:22 AM   #4
CanoeStream's Avatar
St. Cloud , Minnesota
See Price vs. Condition - Airstream Values.
That's a good post by overlander64. Tires are reliable maybe 5 years after manufacture. There are codes on the sidewalls that give this date but checked tells me you don't have to look any further. New tires will be needed. Axles too if you look into it -- axles hold up better if they've had regular use.
If it has a Suburban furnace, those were recalled for carbon monoxide risk caused by composite material in the plenum that didn't hold up. Some people have fixed those but a new furnace is good insurance IMO.
At $6K it sounds like the PO is trying to support his paying too high a price or thinking he can profit from his added value when he didn't add much, if anything.
And ... they all leak.
5 meter Langford Nahanni
Old 06-11-2009, 07:46 AM   #5
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 183
Greetings Steve!
Thanks Kevin
Steve
The tambour material is available from at least two sources. It can be had as either laminate (as used originally by Airstream in the 1970s) or as solid wood or wood veneer. The only possible issue could be if the roller-track is broken or missing -- it is possible to find replacements, but it can be time consuming. It may also be possible to repair the original tambour door if all of the pieces are there -- it can be carefully removed by detaching one of the roller-track assemblies then the slats can be rearranged -- then either muslin or fine burlap can be cut to 1/2" narrower on each side (to keep clear of roller-track) and glued onto the back of the tambour.
Good luck with your investigation/negotiations.
Kevin
Kevin D. Allen
AIR #827
New 23' FB Safari CanyonCrazy 2008 Safari SE 68 01-14-2010 06:56 PM
1972 Safari 23' tandem axel slk Buyer Guidelines 1 06-08-2009 03:15 PM
'71 23' Safari LY and we 2 pansy Member Introductions 6 05-06-2008 10:40 AM
'73 23' Safari Haoleman Axles 1 06-24-2007 05:27 PM
Doing research-19' Bambi-Safari OR 23' Safari-WHY? ernesto ca Member Introductions 9 04-06-2006 06:33 AM
