Old 05-28-2014, 05:57 PM   #1
Wichita , Kansas
Thoughts on value
wanting to purchase vintage airstream. Have found one listed as excellent that an inspector gives 'good' rating too. There appears to be a panel replaced above the wheel well. Asking price is 16950 for 1961 tradewind. there are a couple of rusted out places as well. Thoughts? Value? Any help would be so appreciated. We want to make the smartest purchase possible....and also realize we are buying something very old. Floor appears in good shape but there is wood over a laminate and inspector finds two weak spots as well.
Jkfalkner is offline   Reply With Quote
Old 05-28-2014, 06:15 PM   #2
SteveH's Avatar
Common Sense , Texas
I DO NOT claim to be any sort of expert on the values of vintage Airstreams, but it seems to me $16,950 is sort of steep for a 1961 model with soft floors. Maybe if everything else is excellent?
Hopefully some of the vintage experts will chime in here.
Regards,
Steve
Old 05-28-2014, 06:25 PM   #3
falcon-N-Air's Avatar
1995 34' Excella
Dalton , Georgia
I sent you a PM.
Eric
Eric & Michelle Shuler
1995 34' Excella
2003 Chevrolet Silverado Z71
WBCCI # 7096
falcon-N-Air is offline   Reply With Quote
Old 05-28-2014, 06:51 PM   #4
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
Proceed with great caution. Soft spots on the floor indicates leaks that, at least at one point, were not fixed. Rust is a different matter. Is it showing on the axle, which is exposed to the elements and would be expected to have some rust on a 50+ year old trailer, or the A frame, which could be problematic, or the frame, which could also be problematic. Also, was it your inspector? I agree SteveH.
DryFly is offline   Reply With Quote
Old 05-28-2014, 07:35 PM   #5
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Way to much! Keep looking.
Old 05-28-2014, 08:27 PM   #6
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
They are all listed as "excellent." $16k might not buy you a perfect trailer, but it should get you one with no major problems. Without more detail, it is hard to tell, but it sounds like you are looking at a trailer with some superficial sprucing up, but still some very fundamental issues.
So here are some of the red flags of a trailer being "flipped:"
Does it have an RV style fridge, or a cheap electric only dorm style fridge?
Has it had grey water tanks retro-fitted?
Have the axles been replaced?
Is it polished?
"Yes" answers to the above are worth something.
There are plenty of Airstreams out there--be selective.
good luck!
Old 05-28-2014, 08:45 PM   #7
Wichita , Kansas
yes, the inspector was ours and again I wish I could post some pics but can't figure out how. the inspector does not do many if any vintage airstreams but figured someone looking it over if we can't was the best. I am most concerned truly about the section over the wheel which is a riveted panel that is different than the rest of the body....down to 15800.
Old 05-29-2014, 08:13 AM   #8
Belegedhel's Avatar
Houston , Texas
To post pictures, just reply to the thread. When the dialogue box opens up for you to type, look at all the little formatting icons above your text box, and you will see a little paperclip icon. Click on this, and it will allow you to upload pictures from your computer.
Pictures would help, but again, ~$16k should get you a trailer that is ready to camp, no repairs required, all appliances "RV" style, and working, 50 year old axles replaced, etc.. There are plenty of folks out there that pick up an old trailer pretty cheaply, spend a few hundred on superficial touch-ups, but no real refurbishment, and then flip it with a high price tag, thinking that these trailers are such a hot commodity that someone will bite. For every one of those, there is an inexperienced buyer who is entranced by the shiny aluminum, who ends up spending way too much on a trailer that still requires thousands of dollars in repairs and hours of time.
good luck!
Old 05-29-2014, 08:24 AM   #9
Belegedhel's Avatar
Houston , Texas
Is the trailer you are considering the one on the Airforums classifieds? If so, it does look like it is in pretty good shape, and a lot of work has been done--the soft spots in the floor are still a concern, though. I didn't see the patch you were describing, though the pics in the ad don't show the street side wheel.
Old 05-29-2014, 09:38 AM   #10
Wichita , Kansas
Yes, the one on the classifieds. Inspector said one very small spot under dinette 4" by1' but he went around whole inside tapping with hammer. Click image for larger version
Name:	ImageUploadedByAirstream Forums1401377880.792913.jpg
Old 05-29-2014, 10:25 AM   #11
Belegedhel's Avatar
Houston , Texas
Oh my....That is some patch job. Do you also have pics of the "rusted out places?"
Old 05-29-2014, 10:58 AM   #12
Wichita , Kansas
Yes, here is the only other defect.Click image for larger version
Name:	ImageUploadedByAirstream Forums1401382570.569494.jpg
ID:	213123. Other than those two things which I couldn't see on initial picture the airstream is a really good condition. Interior is all intact and original although it has been painted and new flooring. New ac, all plumbing and electrical running. In has a very beautiful interior,new awning...really looks great and these are the only things we are concerned about....
Old 05-29-2014, 11:10 AM   #13
87MH's Avatar
1978 31' Sovereign
Images: 292
Step Rib?
That's a nasty patch job if it is looking at the rib that the steps are mounted on.
This should require a bunch more inspection prior to paying big bucks for the trailer.
The condition of this rib indicates more underbelly damage.
If you are still interested in purchasing, I would recommend taking it to a certified repair shop for an accurate estimate to fix everything on the bottom side.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 05-29-2014, 11:16 AM   #14
Wichita , Kansas
Name:	ImageUploadedByAirstream Forums1401383624.771191.jpg
ID:	213124Click image for larger version
Name:	ImageUploadedByAirstream Forums1401383667.621443.jpg
ID:	213125Click image for larger version
Name:	ImageUploadedByAirstream Forums1401383762.580507.jpg
Kelly Tires for MH....any thoughts? ViewRVs Airstream Motorhome Forums 6 02-22-2004 09:05 AM
Thoughts on end of camping season yukionna Our Community 34 09-30-2003 08:31 PM
Thoughts on flat screen tv yukionna Off Topic Forum 15 09-16-2003 08:40 AM
Thoughts on quality and prices ipso_facto Our Community 4 04-29-2003 08:04 PM
