Old 10-10-2004, 06:24 PM   #1
I love Airstreams...
leefields's Avatar
1989 29' Land Yacht
Haines City , Florida
Cool Tag says 22T-0102 958 9-7-58 is it worth $900.???
about 3 blocks away is this coach Tag says 22T-0102 958 9-7-58
it is being used for storage..i went in and everything is still there ...fridge...heater...sink....beds....couch.....sho wer and mode.....even a radio in front.....all piled up with boxes and whatnot.....floor feels fine....
outside...everything is perfect...no oxidation....no scratches....no broken windows....everything looks fine.....ok...pull out step is rusted....thats all
he wants 1000. offered less....came to 900. am i right or am i wasting money..
i want to clean it up and use it........on the weekends.....
i just need to find 900. maybe i can borrow it.
if i was rich like you guys......i could change the world
leefields is offline   Reply With Quote
Old 10-10-2004, 07:04 PM   #2
RichardT's Avatar
Get it before someone else does. Whats there to think about?
RichardT is offline   Reply With Quote
Old 10-10-2004, 07:18 PM   #3
leefields's Avatar
1989 29' Land Yacht
getting 900.00 together....he has title and everything....i want to close deal before he starts digging around on ebay or something trying to find a higher price....
Old 10-10-2004, 08:33 PM   #4
leefields's Avatar
1989 29' Land Yacht
What tire and wheel do I need?????
the current owner just called and said that i would need a rim and tire to go on the drivers side....he said a 6 post 15 inch tire from walmart would do....
do you guys know what i need?
thanks
Old 10-10-2004, 08:42 PM   #5
norbert's Avatar
1993 30' Excella
chicagoland , north of cheddar curtain
Images: 24
$900 Duckets....
Illegitimous noncarborundum(dont let the bastards wear you down)
The only true nobility is found through giving good food to your friends- Anton Careme
beauty is in the eye of the beerholder-cosmo fishhawk
if something is too good to be true, its usually gone before i get there-mister boffo
norbert is online now   Reply With Quote
Old 10-10-2004, 09:53 PM   #6
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings leefields!
thanks
The safest means of getting the correct rim replacement for a Vintage single axle coach is to take an existing rim to either a trailer parts store or tire dealer and have it matched. If your original rims are split-rims, (as they were on my '64 Overlander) you will likely find that you will need to replace both rims in order to have prospects for ease of service down the road. My Good Year dealer was able to do this with my '64 Overlander insuring that the replacement rims had the correct offset, bolt pattern, and center hole diameter (all dimensions that need to be correct for the fit to be proper in addition to diameter and width). You will also want to be sure that you have trailer rated tires (ST designation) with a weight capacity appropriate for your coach - - according to the nearest Vintage listed on Airstream Weights and Measures for a '61 22', you will be looking at an empty weight of approximately 2,900 pounds and a loaded weight in the vicinity of 4,000 pounds.
Good luck with your coach!
Kevin
Kevin D. Allen
AIR #827
Old 10-10-2004, 10:07 PM   #7
leefields's Avatar
1989 29' Land Yacht
i knew it was likely to much
it is too much isnt it??? maybe i should just let it pass and keep my eye out for a nicer one a little bit cheaper.....thanks for opening my eyes...i thought maybe 900 was too much.
Originally Posted by norbert
$900 Duckets....
Old 10-10-2004, 10:28 PM   #8
North Central , USA
"Ditto"...
RivetED is offline   Reply With Quote
Old 10-11-2004, 07:04 AM   #9
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I'm no vintage follower, but I have to say $900 and it has all the orig gear.
Hell, even if you didn't want the unit to rehab, there are prob a fleet of folks that would pay top dollar for some of the things inside that are hard to find and/or mod to get a new item in place.
If the $900 is an issue, then pass, but if you got the $$$.......
Old 10-11-2004, 07:53 PM   #10
aztlanco's Avatar
El Paso , Texas
Send a message via AIM to aztlanco
Nowdays $900.00 bucks dont go too far. It seems like a good price for a vintage trailer and it would make a nice project. If it's all there and he body is in good shape, I say buy it!
Ernie
'58 Traveler 18ft.
aztlanco is offline   Reply With Quote
Old 10-11-2004, 11:55 PM   #11
leefields's Avatar
1989 29' Land Yacht
Brought it home tonight.....few hours ago
i live in florida...warm, muggy, damp....i knew i had to clean the trailer and that there maybe cockroaches involved...i could live with that
a few minutes after starting cleanup i saw 2 cockroaches the size of mice...so i thought it was a good time to bomb the coach, i put in 3 bombs and waited a half hour...roaches everywhere, running like there was no tomorrow...i stepped on enough roaches to make the pavement look like an Iraqi battlefield....
then i saw them 3 spiders up in the corners...about the size of my outstretched palm, these spiders must have been 6 inches across...and they were just looking at me....i backed up and promptly put another 3 can bombs in the trailer...everyone disappeared and waited....half hour and the spiders looked like they were enjoying it.....
man, i hate spiders.....but the coach is in great condition....
Ernie
'58 Traveler 18ft.
Old 10-12-2004, 03:55 AM   #12
RichardT's Avatar
If it is in the shape you say, I will give you $1450.00 if you tow it to me. I am in Bat Cave NC zip 28710, about 8 hours from the FL border, I will even put you up for the night in your own house.
Email me a few pictures if you are interested and I will give you directions.
Old 10-12-2004, 05:49 AM   #13
leefields's Avatar
1989 29' Land Yacht
o, your p.m. was talking about this 58...no we will be keeping this one...but i am going to take a good look at the 1948 we bought this week and have to decide if we keep that one or not.
Tag axle checkup Inland RV Center, In Airstream Motorhome Forums 25 03-22-2013 01:39 PM
what's the tag axle for? maznblu General Motorhome Topics 1 04-16-2004 07:54 PM
Tag axle brakes for 350 classic Marshall Walters Airstream Motorhome Forums 1 08-29-2003 05:42 AM
Tag Axle Brakes cooperhawk General Motorhome Topics 1 06-23-2003 12:48 PM
Motor Home Tag Axles - winner General Motorhome Topics 0 05-25-2002 04:56 AM
