08-19-2013, 10:36 AM
Johns Island
, SC
So Many 25s with Twin Beds
Am I in trouble trying to find a 25 ft with a double or queen bed instead of the twin bed setup? I'm not wedded to any particular model or year. Are these quite desirable/rare?
08-19-2013, 10:42 AM
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson
, Missouri
The reasons are many. Most of us old pharts are restless sleepers, and the bride (sooner or later) says, the queen is not big enough for both of us…go sleep out on the couch!
Seriously though, we like the twin beds because is gives one the sense of having a larger trailer in the almost 26 ft length. Storage is pretty much the same inside, and I believe you get a bit more on the outside.
08-19-2013, 11:14 AM
2016 27' Flying Cloud
Labelle
We converted our twin Safari 25ft to full/queen. I know most go the other way....guess the wife likes the heat I put out on cold nights. It is not that difficult to modify twin to queen or queen to twins. Find what you are looking for other than that and make the change. The only part that is a bit difficult is dealing with a storage door going into empty space. I will eventually replace a piece of aluminum on the inside and put a piece of insulation from the outside ad leave the door locked. I am not going to eliminate the door on the outside.
Bill
2016 Flying Cloud FB
2014 Ram 3500 4x4 extended cab
08-19-2013, 11:16 AM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
If you were to view the Colonial Airstream dealer's website (Airstream's largest stocking dealership), you would see very few twins in inventory or on order. They are almost a special order item.
We special ordered our 2014 27FB Classic to preclude the usual dealer installed options we did NOT want and the one item in addition to the twin beds we did want (second AC and 50 amp service). All other modifications such as a solar and inverter systems will be installed by a third "qualified" party which unfortunately our dealer does not make that list per our experience with the existing unit.
A twin installation gives you external access hatches on both sides to half of the space under the twin beds, the other half is inside access storage. Plus, you get a front access hatch to space under the heads of the twin beds and under the center night stand.
08-19-2013, 11:18 AM
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown
, Tennessee
In the older trailers The twin bed models seem to be far more common than doubles.
I am not sure why. Our preference has always been a double. We do quite well with the 48 inch wide bed in our 61. All our trailers are doubles except the 64 and that will change if I ever find time to rebuild it.
Of course we are only in our 70's. Maybe if we were older we would see it differently
Doubles and queens may be more common in the newer trailers with rear bedrooms
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
08-19-2013, 11:50 AM
2012 25' Flying Cloud
Battle Lake
Personal choice, we like the queen bed, may change someday but not yet.
The newer trailers have queen beds in most models that are quite comfortable and accessible for two. There are some tradeoffs, queen vs twin, but not enough for many.
If you are looking at an earlier model a conversion may be the best bet; good overall trailer condition is far more important and harder to correct if not.
doug
08-19-2013, 11:51 AM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
Originally Posted by RickDavis
In the older trailers The twin bed models seem to be far more common than doubles. I am not sure why.
Maybe back then Wally thought that the average Airstreaming couple was too old for any hanky-panky that would require a double…
08-19-2013, 11:57 AM
Battle Lake
Wally's (old) clients didn't have the benefits of modern medicine. Not many twin beds being sold since that came out.
doug
08-19-2013, 12:02 PM
Puyallup
when we upgrade from our FC 19 we are going for a 25 twin bed so our lab can sleep on the floor between us
and we're old farts too!
08-19-2013, 12:13 PM
Colonial Airstream NJ
1961 16' Bambi
1997 19' "B" Van Airstream 190
Millstone Township
, New Jersey
We have 21 Airstreams with Twins beds in stock or on order and are planning on ordering more. They have recently became very popular.
Patrick Botticelli - Colonial Airstream 595 State Hwy 33 Millstone Township, NJ 08535 - 1-800-265-9019 www.colonialairstream.com
08-19-2013, 12:29 PM
Johns Island
, SC
Thanks so much everybody! My dream is a current 25 Flying Cloud FB, but that's not going to happen financially. We'll be going older, and I'm not seeing many without the twin setup. Glad to know it might not be too hard to modify.
08-19-2013, 03:02 PM
2014 25' Flying Cloud
Cuddebackville
, New York
We are thinking of moving to a 25' twin- or as I call it, the "Ozzie and Harriet" model.
08-19-2013, 03:08 PM
2016 25' Flying Cloud
Sunnyvale
After looking for a long time, and following the Forums for years, I think the availability on the market sort of ebbs and flows.. At times they are all "Queen's" and people want Twins, and then it reverse, and all the listings are for Twins.. As noted, some have converted, but it creates "issues" with underbed storage compartments and access in older units.. With patience, you will find the model you are looking for, but maybe not right away, and maybe not in your backyard...
Condoluminum
08-19-2013, 03:50 PM
St. Catharines
, Ontario
We purchased a 25' FB twin bed unit and had Can-Am make up a folding platform and order a mattress to fill the space between the twins. We store the bedside table top for now. It makes a wonderful king size + bed. When our family comes with us it will fit our kids and our two granddaughters or grandsons comfortably and allows us to use the two pull outs for ourselves. The kids also use it as a giant lounge for watching movies on a rainy day. The best of both worlds with one trailer.
08-19-2013, 03:54 PM
Battle Lake
In the best spirit of making do, making the trailer fit the situation. Good job.
doug
08-19-2013, 04:06 PM
2012 30' Classic
Wildwood
, Missouri
We had a 1975 Excella 500 with twin beds and loved them - so much more room and storage. We now have a 2006 30 ft. classic with queen bed configuration. I so want to go back to the twin beds! It was much more comfortable and much more storage. And, we are not old parts (yet anyway). Good luck!
08-20-2013, 08:52 AM
Johns Island
, SC
I can't tell from photos - is there usually a partition/sliding "door" that closes off the bedroom area?
08-20-2013, 09:43 AM
2014 31' Classic
Apache Junction
In the 25FB, 27FB, 28 and 30 models, there is a collapsing slide out door in a niche behind the toilet. It shows as a small wavy line. There is also one beside the galley in some models so there is privacy for a shower.
Note that Colonial Airstream web site has a link to download the 2014 Airstream catalog.
http://colonialairstream.com/Airstre...el_trailer.pdf
08-21-2013, 08:32 AM
Battle Lake
This is a pretty slick deal on some of them and worth looking for as you shop. Ours has two partitions, one that closes off the bedroom, and another by the galley that closes off the bath and bedroom together. Can be used different ways, including a large private bath and dressing space.
doug
08-21-2013, 09:08 AM
Johns Island
, SC
Thanks I appreciate that!
