Old 10-14-2016, 11:29 PM   #1
Continents Collide
1985 32' Excella
Spring , Texas
Should I buy this?
My wife and I are in the market for an Airstream. This will be our full time home, traveling across the country with two dogs (50 and 70lbs). With that being said, we would be looking at a larger airstream, upwards of 27ft in size.
We have been searching and found a 1969 Sovereign that we went and looked at tonight. One forum member has been calling/texting me through the process which has been AWESOME but I wanted to ask your opinion as well. I don't want to tell you the price, I just want opinions on what you would pay for it.
Keep in mind that we will be putting in new cabinets, counters, beds, couches and everything cosmetic but want to stay away from MAJOR projects (don't mind doing some SMALL wiring/plumbing/axle work)
The pictures with green flooring are under the couches in the living area. The blue tank is the fresh water tank. There didn't seem to be too much damage to the sub-floor although it was a little dry.
Two of the front wing windows are plexiglass.
Someone combined plumbing of grey and black lines which now the BLACK tank has a leak.
The video is my wife gently rocking on the back bumper to show any separation.
How much would you pay for this 31ft, 1969 Sovereign?
ID:	273530   Click image for larger version
ID:	273532   Click image for larger version
ID:	273534   Click image for larger version
ID:	273536   Click image for larger version
continentsco is offline   Reply With Quote
Old 10-15-2016, 12:59 AM   #2
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Three to five thousand.
Old 10-15-2016, 06:37 AM   #3
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Find one that doesn't need all that help, even with a new one there is always something need ing a little adjusting
Old 10-15-2016, 07:35 AM   #4
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
Always assume it needs a lot more work than what you can see.
When shopping for our safari 5 years ago we looked at a '71 sovereign that was 100% original asking $2,700. It needed a lot of restoration but there was nothing the previous owner had messed up that needed to be corrected.
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is offline   Reply With Quote
Old 10-15-2016, 07:48 AM   #5
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Your in for a long ride
This is a 1969. This is an odd year with way to many peculiarities. The wing windows come in two versions....both are very expensive, if available at all. The 69 also usually had rot all across the rear hatch floor and the water heater door....and, of course, the main entry door corners. A 69 will need new axles. Tires. It will need an AC in Texas. I can go on......I think you need this cheap and with a realistic plan for the real work involved......which I feel like you don't fully appreciate.
Old 10-15-2016, 08:37 AM   #6
1973Argosy's Avatar
1973 Argosy 24
hartselle , Alabama
I would pay no more than 3000. That unit needs a bit of work. If it's the one you love snatch it up and get to work! While bringing this unit up to par will not be cheap it will bond you to the trailer if doing the work yourself. My outlook is that even a brand new trailer is going to have problems arise, if you recondition a vintage unit yourself at least you know what to do when something breaks on the road.
1973Argosy is offline   Reply With Quote
Old 10-15-2016, 08:44 AM   #7
Continents Collide
1985 32' Excella
Spring , Texas
As far as AC and Tires go - they both work well and it was freezing in there when we went to look at it. Tires have good tread and were covered. The owner has also replaced the axles so they won't need messing with. We will also be spending almost zero time in Texas as we will be traveling around the country - North in the summer, south in the winter - thats the plan anyway.
Old 10-15-2016, 08:45 AM   #8
Continents Collide
1985 32' Excella
Spring , Texas
What brought you to this conclusion?
Old 10-15-2016, 08:47 AM   #9
Continents Collide
1985 32' Excella
Spring , Texas
Good to know! Thank you. Hard to know.
The owner is giving up a equalizer hitch with it as well. The hardest part is this owner genuinely seems honest about it and doesn't know a whole lot about it. Which is fine, but not at the same time - ha!
Old 10-15-2016, 09:07 AM   #10
Continents Collide
1985 32' Excella
Spring , Texas
Here are a few more pictures!
This is under the couch that runs along the front window of the trailer
You can see someone has changed the floor plan at some point
This is under the black tank. It is leaking and this is the styrofoam covering it.
Old 10-15-2016, 10:34 AM   #11
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
It looks like some refurb has taken place--can you list the things that the previous owner has repaired or replaced?
Old 10-15-2016, 10:39 AM   #12
1973 23' Safari
1970 27' Overlander
Boerne , Texas
We recently sold a 1970 31 footer for 3700 and I was very happy to get that. It did not have new axles; did have some rear floor rot; otherwise was in OK shape for that age. I would agree with the 3000-5000 range. If it did not have new axles, I would say pay no more than $3000.
Greg
Greg1410 is offline   Reply With Quote
Old 10-15-2016, 10:42 AM   #13
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
I concur $3-5000 at most....from the pictures, it's in "as found" to "average" condition.
This may help...Price vs Condition
Good luck on whatever you decide! Sounds like a fun adventure taking life on the road!
Shari
Old 10-15-2016, 10:49 AM   #14
Continents Collide
1985 32' Excella
Spring , Texas
1) two new torsion axels with electric brakes 2) a new electric water heater 3)a new airstream front window protector 4) a new kitchen sink 5) a new 10 cu ft electric refrigerator 6) all new pex hot and cold water lines 7) All new hand made curtains 8) All new hand made cushion covers 9) All new flooring 10) New hand made twin bed covers 11) New kitchen counter tops.
This is all from this owner. Plumbing and couch was done before him - and probably more.
Should I buy or should I run away ddruker Ribs, Skins & Rivets 16 04-15-2012 11:35 AM
Should we or should we not Angel73 Floor Finishes 12 03-18-2007 09:48 PM
Should I buy and How much? kraxa General Interior Topics 8 05-18-2003 11:50 AM
30 landyatch why should I buy one. poqn2slots Our Community 1 03-03-2003 12:28 PM
1980 Airstream Land Yacht - Should we buy? cbird01 Airstream Motorhome Forums 0 08-03-2002 10:06 AM
