Old 06-26-2014, 03:44 AM   #1
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Numbers on an Airstream
I noticed a used Airstream apparently from a WBCCI member and the outline of the numbers could be seen after they had been removed. Does this affect the resale value of a specific trailer if it has the evidence of numbers having been removed? And, is there a way to restore the surface so as to improve the appearance?
After a search I could not find this issue discussed on the AIR FORUMS.
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 06-26-2014, 05:54 AM   #2
78SovIntl31's Avatar
1978 31' Sovereign
Paris , Ontario
If I was puchasing, I would not be concerned about the outline of the numbers, some may disagree. I look at it as that is the history of the trailer.
When I joined WBCCI I requested the number that was ghosted on the top of my trailer.
Josh Nicholson
WBCCI# 30183
78SovIntl31 is offline   Reply With Quote
Old 06-26-2014, 07:19 AM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
I suppose it depends on the age of the trailer. If it is a vintage trailer, and the clear coat is pealing anyway, then the outline of the numbers won't be the worst thing about the finish. Ultimately, the owner might strip all the clear coat and shine it up anyway, so the numbers will go away. Now, if it is a newer unit, with a milled/brushed finish and intact clear coat, then number outlines may be more distracting, and less correctable. Still not as much of an issue as hail damage or a nice scratch, in my opinion.
Airstream ID Numbers camdwilson Our Community 5 04-29-2010 01:05 AM
Airstream Production Numbers Streamer1 Title, VIN & Registration 1 09-19-2006 05:02 PM
AirStream numbers.... SilverToy Community Polls 9 01-06-2006 11:23 AM
Airstream numbers? krowsea Our Community 4 08-17-2004 08:09 AM
I need numbers, Part numbers that is. thenewkid64 Airstream Motorhome Forums 1 07-19-2003 10:51 AM
