Old 01-02-2011, 11:11 AM   #1
1975 31' Sovereign
brewster , New York
Newbe
I have the opportunity to buy a 1972 27' airstream.Needs T.L.C.Body damage and broken window.Is $2000 a good price for a fixer upper?
blumob is offline   Reply With Quote
Old 01-02-2011, 11:21 AM   #2
1978 28' Ambassador
Savannah , Georgia
That is a very hard question to answer. There is a forum here that goes into detail and provides a check-off sheet to evaluate some of the potential costs of repair. Do not hesitate to pull up edges of carpet and inspect for hidden problems. Alot also depends on how long the trailer has been out of use. Good luck with your new adventure.
Skamper1 is offline   Reply With Quote
Old 01-02-2011, 11:26 AM   #3
1975 31' Sovereign
brewster , New York
Thank you, I only got a look from the outside while traveling through Del.I might go back and do a full inspection.They went fro $3500 to $2700 and now $2000.It is part of a estate sale.
Old 01-02-2011, 12:18 PM   #4
1978 Argosy 27
Lacey , Washington
Images: 8
We got a 27' 1978 Argosy that looked great but ended up putting over $4k in it. If I had to do over again I would figure that all the appliances do not work or are ready to be replaced and the AS leaks and the leak needs to be found and repaired (can be spendy). So if they are now asking $2k add another $4k (low ball price figure). We lucked out and the axels and brakes were good as was the floor. We repainted it and that sealed any leaks. So go figure what you can put into it and then go in and negotiate from there. jjustice Good luck
jjustice is offline   Reply With Quote
Old 01-02-2011, 02:38 PM   #5
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
Search the forums for "Full Monte"
DanielB is offline   Reply With Quote
