Old 09-03-2015, 01:10 PM   #1
1978 24' Argosy 24
Santa Barbara , California
New Thread on Trailer Value Guide
The stickied Trailer Value Guide on the Dollars & Cents Sub-Forum was started in 2005 and the thread is for the most part a bit dated. I have been on the market for another Airstream trailer so it would be helpful to me at least to have an updated discussion.
It look like the Vintage Trailer Guide was last updated in 2010:
Price vs. Condition - Vintage Airstream
From the prices I have been seeing on Craiglist, ebay, Airstreamclassifieds, etc., it seems quite out of date and that the prices are much higher.
Also I thought Mixter gave a very useful breakdown in another thread (http://www.airforums.com/forums/f36/...-139925-2.html)
Originally Posted by Mixter View Post
My personal value guide is:
Stage 1: $1k-$3k for Unused trailer thats been sitting. Smells like "old trailer", old everything and clearly hasnt been used in a while. Some things "work", but most everything needs upgrading or replacing. Trailer likely has rusty frame damage, and floor rot around the perimeter. Double pane windows are surely full of junk. May have the hardware for an awning, but it is likely not functional and if its there, the fabric is in bad condition. Significant amount of work to bring up to being solid. Likely a full monte, shell off restoration candidate.
Stage 2: $5k-$8k for a trailer thats "usable". Although everything is old, and still stinks, everything appears to work. Floors are likely rotten around the perimeter, and frame damage is likely, but not fatal. Double pane windows are probably full of junk. Awning should be there, but possibly has a broken part on it, and fabric condition is old. Axles are likely to be needed. Fresh paint inside, and perhaps some floors could freshen up the place and camping can be had. Problems will likely arise, where the can of worms opens up, and then you're back to Stage 1.
Stage 3: $8k-$12k for a trailer thats still old, but clearly has been kept well. Perhaps even kept under cover. Might not stink as bad, possibly painted with new floors. Some of the double pane windows have issues, and may still have junk in the vista views. Awning is in good working order, but probably old. Everything works as its supposed to, but probably needs axles.
Stage 4: $12k-$20k for a trailer that has been updated and cared for. New axles, new appliances, walls clean or painted, possible new cabinets or countertops, new floors, led lighting. May also be polished. All windows are clean and clear. Vista views have been fixed. Awning is in good working order with new fabric. This is the next best thing to a full monte/ shell off restoration.
Stage 5: $20k-$40k for a trailer that has had full monte/ shell off resto. Everything is new including frame welding (or replacement), subfloor, axles, wheels/ tires/ brakes, cabinetry, flooring, led lighting, plumbing lines, gas lines, fuse box, inverter, water pump, holding tanks & valves, windows all clean and re-tinted, new seals everywhere, bathroom rebuilt or scratch new, polished, new ac & vents, and new awnings all the way around. Quality of materials is average to above average, but not high end. might not be from a particularly skilled craftsmen, but definitely can be obtained by a passionate DIYer who loves projects and takes time to learn to do things right.
Stage 6: $40k-$100k+ for all of Stage 5, but completely custom with high end quality of materials and workmanship by skilled craftsmen.
There..... kinda did that for myself... interested to see if ya'll agree.
CoreyH is offline   Reply With Quote
