Old 01-06-2013, 10:52 AM   #43
Protohyp's Avatar
1977 31' Excella 500
Los angeles , California
Send a message via AIM to Protohyp
I wouldn't worry too much about leaks. If you're going to do a worthy remodel you will find them all and take care of them. Youlle need to take off the interior skins anyway to rewire. Mold should come off the vinyl fairly easily although mold in the floor is different story. The rear bumper seems to have a small gap above storage door that would indicate rear end separation so it would probably be a good idea to replace that portion of the floor if not all of the floor
Protohyp is offline   Reply With Quote
Old 01-06-2013, 12:53 PM   #44
1988 32' Excella
Robbinsville , New Jersey
Some will disagree but if the window with the A/C in it doesn't leak I would leave it that way till most of the renovation is done since the window unit could be used on a 20 amp circuit more easily then the roof mounted one. Of course I don't like working in the heat that much.
Old 01-06-2013, 01:26 PM   #45
2008 16' Safari
Destrehan , Louisiana
Just got to look at your posted pics. I nice shot of the whole trailer would be good and a good shot of the front and rear end.
This looks as good as our first AS, in fact, better.
Ours had a complte interior and the AC worked but your shell and undercarage look better. This looks like a great place to start. We ended up by repairing or replacing almost everything inside the trailer. I tried to keep it as original as possible. (more work than it was worth)
You get to start with a clean slate and build it the way you want it.
With most of the inside gutted you can get to the wiring, power panels, gas lines and plumbing very easily. Be sure to inspect all of the holding tanks for cracks or damage. It will never be easier than now to get all of the basics sound before moving on to a finished interior.
Are there any good carpenters in your family?
Or do you plan on learning by doing?
dlb435 is offline   Reply With Quote
Old 01-06-2013, 01:31 PM   #46
Protohyp's Avatar
Yeah I think at one point they mentioned roadworthy. Pretty sure a window mounted AC isn't the best thing for the road. I think the way to think about it is most of the demo work is done so you're a 1/4 of the way there. If its a viable option clean it up and find a place to park it with facilities and start living in it and saving up money for the real work at the same time gather a notebook with a plan and bookmark or subscribe to all the threads on here that are doing what you plan on doing. Take your time and ask lots of questions
Old 01-06-2013, 02:43 PM   #47
1988 32' Excella
Yeah I didn't say anything about leaving the window A/C when done just for the bulk of the work, until they are close to getting it on the road.
Old 01-06-2013, 02:49 PM   #48
Protohyp's Avatar
I hear you but at some point that trailer needs to get on the road to get to where they are. If that AC stays in and bounces out there is a potential that it could damage the window/exterior skins/window ribs let alone kill someone on the road. That's why I mention that they give a small " delivery deposit" so if the trailer arrives in any other condition then they could have a bargaining chip unless the seller is honest and would reimburse. At this point it just doesn't seem that the trailer is roadworthy so it's transport will require some thought.
Old 01-06-2013, 02:59 PM   #49
SteSpot's Avatar
1968 28' Ambassador
1982 24' Airstream 240
Ventura , California
Who is going to empty the contents?
Will the trailer be delivered empty? If that stuff is going to stay inside when it is being moved....things will move around a lot, I would think. paula
Paula & Ed
Suite Spot
WBCCI # 8252 Air#13593
1968 28'Ambassador
2011 GMC Yukon Denali
1982 24'Motorhome (82Ste P)
SteSpot is online now   Reply With Quote
Old 01-07-2013, 06:00 AM   #50
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Photos look good. $1,200 for a "delivered" Airstream storage trailer, with a/c, is really pretty cheap. Plus it is movable if you don't like it where you initially put it. Have you priced an 8x30 storage unit? You are getting a bargain.
Dan
TouringDan is online now   Reply With Quote
Old 01-07-2013, 08:21 AM   #51
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Around the bumper section. You should seal the top of the bumper and the bottom of the shell all the way across. With or without rear end separation that area needs to be sealed up tight. Water wicks its way between the floor/frame/ shel causing floor rot, and rusting out the frame. Most RV parts places have Non-silicone sealers that you can use.
Silverflames is offline   Reply With Quote
Old 01-07-2013, 08:28 AM   #52
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Do you get all the stuff that in currently in it also?
Old 01-07-2013, 08:42 AM   #53
debary , Florida
Hey guys! No he will empty it all out before bringing it and we aren't going to touch the window until everything else is done...we were think of replacing it with Plexiglas? We won't be able to work on it for possibly three months because we want to save around 7,000 dollars and then take a month off possibly from work and get the bathroom and kitchen done. My father has don't so many houses its insane and I was there when he remodeled our houses. So he knows about wood work etc. And my husbands father knows about wiring etc so that's not an issue and everybody knows everybody from where we are lol. But one thing that has crossed our mind is how to remove the skin and how to replacement it, can we use the old skin again? I searched. The internet but it wasn't much help at all.
jerr1955 is offline   Reply With Quote
Old 01-07-2013, 09:27 AM   #54
1969 29' Ambassador
You can remove the old inside skin by drilling out the pop rivets. You will want to keep all of the inside skins, clean and reuse them. Some folks replace them with sheets of aluminum, but if they are in halfway good shape, reuse them. Another great source of info is the VAP pod cast. All kinds of repair topics.
Old 01-07-2013, 12:24 PM   #55
debary , Florida
Well that's good news! And I will have to look into that!
Old 01-08-2013, 09:59 AM   #56
2008 16' Safari
The outside shell should only be done by a pro. It takes special tools and the panels have to be ordered from Airstream.
The inside is pop riveted into place. They can be removed by drilling out the rivets. That will allow you to see the insulation and some wireing. Unless you have a good reason, it's best to leave as much of this intact as you can.
You would be suprised at how well the inside will clean up. I'd hold off on removing the inner skin until the trailer is well cleaned.
If you do remove the inner skin, take lots of picture and make good notes.
Beatrice era frame experts if you please. Odd frame issue Kevin245 Repairing/Replacing Floor &/or Frame 5 08-25-2012 09:55 AM
HVAC Experts-Please Help tesstoaster Furnaces, Heaters, Fireplaces & Air Conditioning 1 07-03-2012 07:50 PM
Airstream Newbie Needing Advice Please StephenBell Jacks, Stabilizers, Lifting and Leveling 6 09-23-2010 01:21 PM
Bellypan Questions for the Experts - Need Advice dbj216 Belly Pans & Banana Wraps 13 07-01-2009 08:01 AM
New Guy Needing Flooring Advice trackbandit Floor Finishes 5 09-16-2008 04:52 AM
