Old 04-13-2016, 04:23 PM   #15
I have read through that thread topic. It seems the problem came from CCD version due the design issue. Safari has different design. I think it should be fine. How long you have owned this unit? What do you think this AS? Thank you. Your hand-on experience will be very helpful.
Thank you.
Originally Posted by m rafferty View Post
Was the frame problem also in other models? I have a 2005 25. Tks
cztexas is offline   Reply With Quote
Old 04-14-2016, 10:41 AM   #16
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Thank you.
Read the thread that was in my first post. Problem was most severe with the front bed models, but did happen with some of the rear kitchen ones too. The frame was the same depth as the 16's and 19's - but flexed too much for a 22 footer. Analagous to using 2 x 6 for floor joists over a 20 foot span. might be FINE for a garden shed, but will make the floor a trampoline on anything bigger. Add the normal vibration of a moving trailer and hairline cracks will start.
The 25 had a frame an inch deeper and Airstream eventually started making everything over 19 with the deeper frame. The OSB floor also contributed to the problem. It lacked the resiliancy of real plywood... and OSB turns into moist Kleenex when wet!
Paula
First Airstream purchase... need purchase tips, please. movin-in Buyer Guidelines 8 06-03-2010 05:09 PM
Possible purchase need purchase/deposit/title forms LiLNomad Dollars & Cents 5 05-28-2010 12:59 PM
Need help with an Airstream Purchase gldwinghaulr Buyer Guidelines 9 01-04-2009 05:52 AM
Need Help first airstream purchase jay3919 General Repair Forum 5 07-07-2008 08:29 PM
Need to purchase 2 batteries by Friday...help Diesel Pusher Batteries, Univolts, Converters & Inverters 10 05-01-2004 09:53 AM
