07-11-2009, 06:39 PM
eagle river
, Alaska
looking for solid advice
we live in alaska and are looking for our first airstream. we are thinking about a 30'. our budget is 10k. we rarely find airstreams in alaska and search craigslist frequently in major cities. often by the time we call, the airstream is sold. there is a local one listed on craigslist for 12k. its a 31 1986 sovereign. it appears to be in good shape. no dents, leaks, etc. some overall fading and peeling on the outside. we have seen it. we want one in the next few months for living in during the winter in the south. looking for advice.
07-11-2009, 06:46 PM
Naysayer
1968 24' Tradewind
Russellville
, earth
Exactly what advice are you looking for?
07-11-2009, 08:04 PM
1984 29' Sovereign
Savannah
, Missouri
I have a 84 Sovereign , that's a 30'ter and,....you might want to grab it if it's in good condition..All of the good ones are gone on sight..
Tow it with a 3/4 and, at least 6.0 for over the mountain pass, etc..
Just be sure to check the sewer vents (for replacements of the rubber gaskets). Do your homework..for sure..
Good Luck!
WBCCI 5292 AIR 807
NEU #64
New England Unit
07-12-2009, 12:49 AM
eagle river
, Alaska
looking for advice on if this is a good price and what to look for in possible problems for this year/model. we read that this cannot be polished like older airstreams and are not sure how to get it looking good once we are that far. thanks for any advice!!
07-12-2009, 06:41 AM
2008 16' Safari
Destrehan
, Louisiana
It took me two years of looking to find the right size, condition and price for my trailer. Keep looking and be patient.
There are several factors in a trailer choice.
The first is the size. Get the smallest size that will work for you. That could be anything from 17' to 34'.
Next it the weight. Airstreams can weigh anything from 2000 lb for some of the smaller vintage trailers to over 10,000 lb for the larger curent model trailers. What are you willing to tow and what will the roads be like? I've got a 17' trailer that is 2850 lb. It's easy to tow but has low ground clearance. I have to be careful on dirt roads. You need to think about things like this.
Cold weather - Alaska can get very cold. Are you going to store the trailer all winter? Will you set it up for cold weather campng? Fitting the camper out for cold weather use will mean installing tank heaters and adding a lot of wiring. You could do this with any model year but getting a vintage trailer and restoring it with an eye to sub-zero camping is an idea.
Model-Age-Condition The golden three in trailer price. Firure out if you want new, used, restored, as found (read it as junk; you have to restore it) or salvage. From my experience, you will have to pay about $10K to $20K for a good solid trailer of any year. (cost of the trailer plus fixing it up) It will cost you a lot more for a luxury trailer or a show stopper. Get your price range in mind and stick to it.
Trailer inspection - Check the outside for dents or missing panels and trim. Check the underside for damage. Check the frame and the axels. Check the date code on the tires and look at tire condition. Check all the appliances for propper operation. Check the water and holding tanks. (fill them up and drain them out) Check the toilet and shower. Check for evidence of leakage on the walls and floor. Check the floor for soft spots (look near the door, under windows, near the bath and in hidden spots) Check the seats and the upolstery. It seams that almost every item that is broken will cost about $1000.00 to replace or repair. If the trailer finish needs to be restored, that's about $3000.00.
Let's say you got the 86 you were looking at. $12,000 for the trailer. $3000.00 to refinish, $2000.00 for new upholstery. $1000 for new tires. total -$18,000 That's within to price range for what you want only if everything else is perfect. Add in a new AC and replace the black water tank and you're over budget.
I hope this is what you were looking for.
07-12-2009, 07:09 AM
1955 22' Safari
Great Lake State
Get on the Airstream Forum and read, read and read...........toastie
07-12-2009, 07:24 AM
1977 25' Tradewind
Waskesiu Lake
, Saskatchewan
Another option if you can't find a good trailer locally is to rent a place to stay in the south next winter and take 2-3 months to look around for a trailer down there. With the internet, you can likely find a mobile home, condo or triler to affordably rent by the month. I'm sure you would find a good Airstream selection in Texas, Arizona, etc..
While you are in the south, run a "trailer wanted" ad and catch those people thinking of selling before they run an ad and you are competing with everyone else for the same trailer. Running your own want ad might even work from Alaska...
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
07-12-2009, 07:55 AM
1964 17' Bambi II
Schererville
, Indiana
I have a 1986 31' Sovereign. Look at the floor (or poke it with an awl) along the endcaps where the seam meets the floor. Mine had rotten floors at every one of the places where the seams met the flooring. I bought mine 2 years ago for $10K, but didn't see the bad floor. After repairs, it's a nice trailer & very comfortable for my family! I've probably put $3,000 into it so far.
Becky
1964 Bambi II
1988 Avion 32S
07-12-2009, 10:17 AM
1984 29' Sovereign
Savannah
, Missouri
Well..
wn2fly,
They can be polished.
Whether it will polish as well as the older ones or not is an open question.
More like, beauty in the beholder's eyes..
There is no doubt that, afterwards, the polished Airstreams (that I have seen) all looked much better than it's original appearances.
WBCCI 5292 AIR 807
NEU #64
New England Unit
07-12-2009, 11:58 AM
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
Good Advice! Paula
07-12-2009, 01:34 PM
Master of Universe
2008 25' Safari FB SE
Grand Junction
As you must know, everything costs more in Alaska. Getting parts can be a challenge if there's no dealer in Alaska, but everything can be mailed or FedExed, but the shipping costs may be greater than in the lower 48. If you buy it and then take it south, make sure all the running gear and tires are in very good condition. It's a long way to Edmonton, the first big city. That you live near Anchorage is helpful.
Airstreams are considered a 3 season trailer, so taking it south is a good idea. I don't know how the tanks were heated, if at all, on that model. Electric tank heaters need 120 v. to work (if they have a 12 v. option, the batteries won't last long) and more effective is having a heat duct from the furnace run through the tank area. If you were to stay in Alaska's interior, you would use up a propane tank every day.
If I lived in Alaska, I'd look into 4 season trailers—one is Arctic Fox. Or if you want to spend the winter in the lower 48, buying an Airstream here and storing it here during the summer is an alternative. A lot of people in Colorado have short summers and it can be a pain winterizing and summerizing the trailer several times a year, or keeping it heated for long periods of time can be expensive.
There are some Alaska residents who are Forum members, so maybe they'll see this thread and give you advice. And if you find a good one, there are Forum members who will inspect it for you. On the Forum page, look to the right side for inspectors.
Gene
07-12-2009, 11:45 PM
eagle river
, Alaska
this is exactly the kind of advice i am looking for you. i appreciate all of this. thank you.
07-13-2009, 12:26 AM
eagle river
, Alaska
we had originally thought we would buy here and travel to the lower 48 before winter, knowing that the road conditions are not great. we have 4 pets to bring with us. storing it in the lower 48 would be great. but because we are not finding a good selection to choose from, maybe coming down there to buy is better. we have been trying to look around cities where we know people so they can take a peek at it before we make airline arrangements. are you saying that if we found something we were interested in, an inspector could take a look and give us an honest opinion? that would be ideal. has anyone used this service and had experience with this? our friends that live in the lower 48 are not airstream fanatics like us so they would not be looking for the nuts/bolts.
07-13-2009, 07:14 AM
1977 25' Tradewind
Waskesiu Lake
, Saskatchewan
Even if you don't know somebody in particular city, you could alway call the Airstream dealer (or a general RV dealership) and have it professionally inspected - probably around $300.00. They would have a standard checklist and you could add specific things for them to check as well (floor rot, tail sag...). If it checks out well you could then go to look at it and possibly confirm the deal.
07-18-2009, 03:38 PM
eagle river
, Alaska
just an update here: we have not been able to contact the owner of the airstream up here that we looked at and are looking elsewhere. Our biggest concern is that some we are looking at are quite a distance from where we thought we would spend the winter -which is the southwest. Has anyone ever bought one sight unseen? we have a list of questions that we are asking from the fedback we got on this forum. Its been very helpful. Thanks
07-18-2009, 04:04 PM
Master of Universe
Grand Junction
You can ask inspector to look at it, but I'd want to look at it myself too. It's harder to sell them in the winter (except maybe in SoCal and Arizona), so the prices should be lower. Once I make a decision, I want to act on it right away, but sometimes it's better to be patient. If you miss one, there will be others coming along soon enough.
Gene
07-18-2009, 04:21 PM
1988 32' Excella
West Palm Beach
Don't buy anything sight unseen. We looked at one from Craigslist and bought it. We also looked at one that was on Ebay that seemed a possibility from the description and pictures. What a difference between that and the reality. The trailer was trash and unusable without major work. It was overpriced for its condition. Nothing in the photos would have suggested how much work would be required. This is our second Airstream. The first one we bought in the mid-70s by placing a want-to-buy ad in the local paper. Don't know if something similar would be as feasible today.We pulled it to Alaska and back before the Alcan was improved. What a trip!
08-03-2009, 04:47 PM
1976 31' Sovereign
Dallas
On rare occasions I've found Airstream with factory installed thermal windows.
You might want to put out a hunt and see if you can turn one up.
With the price now and future price of LP fuel it might be well worth waiting.
Stan Wilder
Dallas TX
