Originally Posted by anna.kerwin
... Our biggest reason for wanting an airstream is because we could end up in snow country and regular trailers don't have snow worthy roofs like airstreams.
hi anna
we love our argo'streams...
but you may be under the mistaken assumption that a/s are better winter trailers than other brands...
that simply isn't true.
an a/s can be used in the cold and snow but there are LOTS of issues...
they are thin walled and conduct cold through the walls...
so to keep warm inside a LOT of lp gas is gonna be used...
that also means you need a reliable furnace that can go the distance.
in addition u will likely need a LARGE external lp gas tank next to the trailer...
the 2 small tanks on most trailers will only last a few days in the cold...
unless your water line is heat taped you'll need to fill the fresh tank and stow the hose...
that means a tank large enough for the family needs...
same issue on holding tanks.
freezing pipes or external lines can happen.
with 3-4 people living inside moisture (condensation) is gonna be an issue.
venting the trailer daily AND using the furnace, just to keep it warm and dry inside.
a/s can be skirted but it's not as easy as some other brands.
many modern 5th wheels have larger water tanks, better/more insulation AND more living space...
many 5th wheel models are MADE to full time and withstand winter conditions
also your buying dollar will go much further for a 5er with 2-4 slides than for a pretty silver twink.
sure a/s have a curved roof but they still collect snow and it will need to be removed to use the vents regardless...
my intention isn't to discourage shopping for an a/s but just to suggest expanding your search to other better winter options....
here are a couple of threads to start with but read up on the 'winter living' section...
http://www.airforums.com/forums/f462...ving-2738.html
http://www.airforums.com/forums/f462...eam-20597.html
best of luck...
cheers
2air'
