Old 11-16-2007, 10:31 PM   #29
Ocean Park , Washington
I also saw it the problem is that my bank will not lend for RVs that don't have a value on nada and 1989 is the oldest year on nada for airstream. So it is just one year out of my reach. Money is a big factor in what I can do.
anna.kerwin is offline   Reply With Quote
Old 11-16-2007, 10:47 PM   #30
wayne.yl's Avatar
1977 31' Sovereign
1992 34' Excella
Salem , Oregon
I feel your pain
I will keep looking for ya....If I see something down this way, I will let you know. I remember how much fun it was to pull my first AS home...Even though the brakes didn't work and I almost found out too late. Man those were the good ol' days.
wayne.yl is offline   Reply With Quote
Old 11-16-2007, 11:13 PM   #31
Thanks although I have to get one already road worthy thats for sure.
Old 11-17-2007, 10:25 AM   #32
Crusty's Avatar
1992 34' Excella
Before you start tearing stuff apart looking for the leak, open that window and clean the gasket and it's sealing surface and then close it and maybe even adjust the latches to pull it a little tighter and check with a water hose to see if it's still there.
Crusty
"If you come to a fork in the road, take it."
Lake Travis, TX
"Rancho Deluxe"
Crusty is offline   Reply With Quote
Old 11-17-2007, 11:37 AM   #33
Elgin , Texas
Images: 164
Agreed. Also, you probably don't want a dealer unaccustomed to working on Airstreams trying to fix yours (they're liable to try glopping silicone hither and yon, creating an even larger problem down the road). You can get window gasket material as well as the compartment gasket material by the foot from your local Airstream dealer. Had to re-do all the compartments on my '94 - they were pretty well shot.
bake315 is offline   Reply With Quote
Old 11-17-2007, 01:50 PM   #34
1990 34' Excella
Windcrest , Texas
Congrats
Originally Posted by wayne.yl
Yes I am the new owner and I hope it was a good purchase.
I am still working with them on fixing the leak in the rear storage compartment. They seem cooperative but not very knowledgable.
WE will see how it goes.
Wayne
In San Antonio I quit using our 'Airstream dealer' a couple of years ago because they didn't seem to know what they were doing. I now have a RV repair mechanic who is just awesome! Even though they don't sell Airstreams I usually see 3-4 of them in their lot.
We went from a '75 31ft Excella to our '90 34ft Excella 1000. Wow what a difference. No more veneer but real wood. We've put in a new AC, new fridge and I've had a couple of water leaks that were easily fixed.
One thing you will note about the 34 is that AS put in a 13.5 BTU AC unit, which doesn't quite do the job on our hot Texas summer days. We replaced the unit with a 15k Carrier low profile unit and its night and day differnt (cooler).
Good luck!
Swanny is offline   Reply With Quote
Old 11-17-2007, 04:23 PM   #35
rceptex's Avatar
1984 34' Excella
Farmington , New Mexico
Images: 16
Wayne,
Dave's right about getting new gaskets for the windows and the compartment doors. Tip you might try after cleaning the existing gaskets is to rub baby oil on them. It reenergizes them if they are not completely dried out and falling apart. I use it one my old cars as well as the coach and it does help keep them pliable.
Ross
rceptex is offline   Reply With Quote
Old 11-18-2007, 12:50 AM   #36
wayne.yl's Avatar
1977 31' Sovereign
1992 34' Excella
Salem , Oregon
silicone and gaskets
Thanks fellas,
I called the dealer to confirm what their approach was toward fixing the leak.
I too had misgivings about silicone globbed all over the rear of the coach.
He assured me that they were going to inspect the gaskets on the compartment door and the rear window first before they looked elsewhere for the leak. I told him I didn't want any silicone on the trailer anywhere and he said fine. He said they would let me know when they found the leak.
I hope they find it and its an easy fix.
Thanks again for the helpful advice.
I will keep you posted.
Wayne
Old 12-09-2007, 02:07 AM   #37
wayne.yl's Avatar
1977 31' Sovereign
1992 34' Excella
Salem , Oregon
update on the "New" 34fter rear trunk leak
I guess this really should be a question for flooring or leaks. Please forgive me for posting it in the wrong place.
Attached are pictures of the rear trunk and the water stained flooring I refered to earlier in this thread. I am quite disappointed that a 2-3inch piece of OSB flooring is spliced in at the rear of this trailer. I can't imagine why a whole piece is not used. I assume one piece would aid in stability. My question is whether this spliced piece of flooring could be part of the reason there is a leak back there?
Thanks for any help,
Wayne
ID:	50528   Click image for larger version
Old 12-09-2007, 09:21 AM   #38
HowieE's Avatar
Princeton , New Jersey
Images: 12
While the first assumption would be the rear compartment door look at the piece of sheet metal that goes under the banana strip from the top of the rear bumper compartment. That metal goes into the trailer directly onto the top of the floor. Design stupidity feature. If the sealant between it and the banana strip has failed water will run directly in and on the floor. It is common to find the factor construction plastic still over the rug in areas under cabinets and the bed. That plastic keeps any water that comes in as noted above from ever evaporating and the strand board that is used for the floor will soften once wetted.
I would not let a SOB dealer repair this because of the way the floor is fitted into the floor channel. The floor is a strutural part of the trailer. A quick fix could be worst than no fix.
2004 Excursion 4x4
Old 03-06-2012, 09:42 AM   #39
ALUMINUM OBSSESSION
1993 34' Limited
Hamilton , Ontario
You will want to repair the 2 exhaust vent at the top of the trailer.
The rubber gaskets inside should be replaced every 3yrs approx.
If you don't ,water will run inside the trailer.
Andy has emphasized this many times before!!!
william Haym is offline   Reply With Quote
Old 03-06-2012, 09:49 AM   #40
ALUMINUM OBSSESSION
1993 34' Limited
Hamilton , Ontario
You might want to have that trailer checked with the Seal tech 430r
water leak test unit. This unit is awesome to find water leaks.
It pressurizes the cabin and after applying a soapy solution will
find the leak. Most reputable rv repair shops will have this unit!!
Old 02-10-2019, 11:43 AM   #41
2002 34' Classic S/O
Monmouth , Illinois
34 ft
I have one for sale, 2001 excella, excellent condition. dschonfelder@frontiernet.net.
Dschonfelder is offline   Reply With Quote
Buying a trailer on eBay yukionna Buyer Guidelines 41 05-22-2017 12:25 AM
Buying a trailer that has sat for 10 years sectionc Buyer Guidelines 17 07-17-2014 06:14 AM
buying a parts trailer camperski 1965 - 1969 Overlander 5 07-20-2006 06:30 PM
A/C Cooling performance in a 34ft trlr. Davis Furnaces, Heaters, Fireplaces & Air Conditioning 22 07-11-2006 02:56 AM
Torn between buying a houseboat or a travel trailer? Rog0525 Our Community 15 12-14-2002 03:04 AM
