Old 12-06-2017, 11:01 PM   #1
1999 34' Cutter Bus w/slide
Lakeville , Indiana
Buying 1999 Cutter ...w problems advice needed
Hi my daughter and I Put a deposit at Mt Comfort in Indiana on a 99 Cutter 34 that's getting inspected tomorrow..parking brake not working..smell exhaust in cabin while driving...leak under bathroom sink..mold..could it be hot water heater issues?..any advice on this model / year?
We are newbies and I chose Airstream for a reason!
BrittaBella is offline   Reply With Quote
Old 12-07-2017, 12:34 PM   #2
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
On any RV that age it’s reasonable to expect to have to replace all the appliances.
Water intrusion is the big problem. A moisture meter and strong flashlight good tools. Ck around toilet and front door as well.
Rotted floors can be repaired, but it gets expensive in a hurry unless DIY.
Mohos are a good deal more expensive to own and operate than a tow vehicle and travel trailer. It’s msinly labor as access is more difficult. With that understood, be patient. Keep records. Ask for recommendations of service shops or mobile techs.
Hensley Arrow. 9-cpm solo, 15-cpm towing
slowmover is online now   Reply With Quote
Old 12-07-2017, 01:00 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Gas or diesel?
If gas the 454 engine is common to blow exhaust manifold gaskets. If not that a general exhaust leak.
Like above said take a flashlight and ice pick to inspect the floor around an area you suspect a water leak.
The emergency brake is likely just a rust issue of the cable. Inspect from below while someone applies the brake.
2004 Excursion 4x4
Old 12-08-2017, 12:38 AM   #4
Lakeville , Indiana
Yes it is gas..thanks I will confirm that.
99 cutter rv
1999 AirStream Cutter 35 Diesel pusher Huge slide out S1999 AirStream Cutter 35 Diese eBay Watch Airstreams on eBay 0 09-07-2011 02:40 PM
1999 AirStream Cutter 35 Diesel pusher Huge slide out S1999 AirStream Cutter 35 Diese eBay Watch Airstreams on eBay 0 08-22-2011 07:30 AM
1999 AirStream Cutter 35 Diesel pusher Huge slide out S1999 AirStream Cutter 35 Diese eBay Watch Airstreams on eBay 0 08-11-2011 11:10 AM
1999 AirStream Cutter 35 Diesel pusher Huge slide out S1999 AirStream Cutter 35 Diese eBay Watch Airstreams on eBay 0 08-01-2011 10:40 AM
Problems Problems Problems pjude General Motorhome Topics 6 09-03-2007 08:25 AM
