Old 06-18-2007, 05:11 AM   #1
Very american 4 a french
brunoffrance's Avatar
1971 27' Overlander
DUNKERQUE / FRANCE , Nord
Images: 68
ARGOSY value / AIRSTREAM
As I plan to buy another travel trailer or motorhome for living more time in your country, what is the difference between an ARGOSY and an AIRSTREAM ?
I don't see why there is two names for what it seems to be the same model , exept the body in silver or painted...
Is the interiors different, cheaper, with less quality equipment ????
Apparently, the Argosy are better prices than Airstream in used ... Why ?
Bruno
My blog:The american dream in FRANCE:
My pictures in high quality: Pictures on FLICKR:
My videos are on YOU TUBE
My AIRSTREAMLIFE ning
brunoffrance is offline   Reply With Quote
Old 06-18-2007, 05:56 AM   #2
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Good Morning Bruno... The Argosys were prototypes for anything new that was tried for Airstreams.. silver ones that is.... The interiors are the same .. Personallly we like the Argosys better ... they are just painted versions for their silver cousins.... The outside endcaps are steel and the rest of the body is aluminum. We have had a silver one and this is our 2nd Argosy redo from top to bottom. We love them...
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 06-18-2007, 06:23 AM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Argoies have always been regarded by the public as less iconic and therefore they did not command as big a price tag. There were made at a separate factory from the Airstream and the years they were produced were more limited. Some ideas were tried out in the Argosy product line before they were addopted into the Airstream product line. If you do not mind the fact that they are painted rather than polished metal, they represent a better buy for your usage.
Old 06-18-2007, 06:54 AM   #4
1971 27' Overlander
Images: 68
is the only difference , the painting coat on aluminum instead of clear coat on aluminum ... and the name on the front & rear sides of the caravan ?
Inside, No difference ?
And for motorhomes ( I've seen used MH with really good prices... ) , sames rules than the travel trailers ?
Bruno.
Old 06-18-2007, 08:20 AM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Bruno.
Bruno, Argosy trailers and motor homes are considered more Spartan in appointments, and have fewer windows, and are one foot shorter than their Airstream counterparts. Argosy coaches also have galvanized steel single piece end caps, while Airstreams had multi-piece aluminum end caps.
Air conditioners were optional on Argosies for the most part, have a slightly thinner floor (1/2" vs 5/8'+), and don't have all the "gadgets" that comparable Airstream models do. The NuTone food center that was optional on Airstream models was not available on Argosy models, the "Airstream control center" was also not available on Argosy models, you have to be aware of your holding tank levels without the (usually incorrect anyway) gauges. The "Vista View" roof mounted windows were almost unheard of in an Argosy. They also had slightly smaller holding tanks, both for fresh and waste water.
The one foot difference in length was achieved by simply lopping off a foot from the back of the frame, which I think helped the towing characteristics. A foot shorter equates to higher tongue weight for trailer length, and a center of gravity that was moved forward as well.
Most Argosy trailers had 10" brakes, vs. 12" brakes on most Airstreams, and the wheels had a slightly lower capacity weight-wise. Later model Argosy trailers had wagon-spoke wheels, and cheap plastic center caps, rather than full hubcaps.
Later model Argosy trailers and motor homes even carry a small badge identifying them as Airstream products.
Old 06-03-2010, 08:31 AM   #6
1978 31' Excella 500
SOUTH ANHERST , Ohio
Question 1 am new to the airstream world and have just purchased a 1975 argosy and my wife and I will be doing a little remodle , question behind the couch their is a frest water take , can it be removed???
being new to camping world of Air Stream and never owning a trailer they say no question is a dum one , what is it for ??? and should I leave it be and not take it out ?????
Gosman is offline   Reply With Quote
Old 06-03-2010, 08:34 AM   #7
I am new to the airstream world and just have purchase a 1975 argosy it handle grate in the towing to my home , now I have a new 2010 F150 with THE TRAILER TOW PACKAGE SO ALL SHOULD OF BEEN WELL ,
but when hooked up to the trailer the back up lights on my truck will pop on and stay on untill I unplug the trailer plug any one know why this would be???? the truck has only 400 miles
Old 06-03-2010, 08:51 AM   #8
I have a 1975 argosy and in need of a replacement light cover on the rt. Rear top, does any one know were one could be purchased also a few of the bulbs need replaced , were can they be purchased as well.
The 1975 argosy we justed purchased has what appears to look like back up lights ?
Old 06-03-2010, 10:09 AM   #9
memgrove2000's Avatar
Elkhart , Indiana
Send a message via AIM to memgrove2000
First things first.... Welcome to the forums. You will be better answered if you put questions in a better place. You have posted theese in a very old thread that wont get much traffic.... Also use the search feature in the upper right corner of the page (I like the google search). The people here are great and willing to help the new guy!!
Now for your lights... The Umbilical cord might need to be rewired. The new plug on the truck and the old wires in the trailer plug are not in the same order OR color scheme. (this is not just your trailer it was all of them that old)... you will need to search around for the right diagram to show just how they need to go ... Me... I used a test light, and found the wires by function... Brake light, turn signals, trailer brakes, charge line, running lights.... on the trailer... then matched them to the truck (DO NOT CHANGE THE TRUCK SIDE)
good luck and dont give up .... people here ARE the best!!!
Mike
Have a great day!
TAC # IN 1 Air#27922
memgrove2000 is offline   Reply With Quote
Old 06-03-2010, 10:44 AM   #10
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Jett!
Welcome to the Forums and the world of Vintage Argosy Ownership!
I have a 1975 argosy and in need of a replacement light cover on the rt. Rear top, does any one know were one could be purchased . . .
The clearance marker light lenses should be readily available from several sources. I suspect that you will be able to find replacement lenses for any exterior lamps on your Argosy from Vintage Trailer Supply.
You can purchase replacement bulbs from most larger auto supply stores. The easiest method is to take the defective bulb into the store for matching. If you need help identifying the correct bulb, you can find the information on replacement bulb numbers in your coach's owners' manual. If you find that you need an owners' manual, reproductions can be purchased from the Airstream Corporate Store.
Most Airstream and Argosy trailers of the 1970s came equipped with backup lights. The wire is in the trailer's umbilical cord, but isn't always connected. You can solve the mystery of your coach's umbilical cord with the wiring diagram found at this link.
. . . but when hooked up to the trailer the back up lights on my truck will pop on and stay on untill I unplug the trailer plug any one know why this would be????
You will likely find that your coach's trailer plug (Bargman 7-pole) is still wired to the original (non-industry-standard) Argosy schematic. This could explain the reason that your truck's backup lights are on constantly when hooked to the trailer -- in the Argosy's original wiring schematic, the charge line is where the backup light feed is on the current industry standard wiring schematic -- so the trailer is constantly feeding current to your tuck's backup light circuit.
I would suggest that you retain the fresh water tank for several reasons, including the following:
  • The fresh water tank is placed in that location to insure that at least 12% to 15% of the coach's weight rests on the hitch to help insure stable towing. I have towed my Argosy all over the US and have always had better handling in adverse conditions if the fresh water tank is full or nearly full.
  • It is always nice to have potable water for stops where there are no utility connections available. Lunch stops in parks are always nicer when you have water available for your coach's kitchen and bathroom.
  • The resale value of your coach will be adversely impacted if it doesn't have the original self-containment features including the demand fresh water system.
If the problem is dirt in the tank or leaks, replacement tanks are available from Airstream dealers or other independent suppliers. If the tank just needs cleaning, you can try the process identified at this link.
Good luck with your Argosy, I am sure that you will enjoy your coach!
Kevin
Kevin D. Allen
AIR #827
Old 06-18-2010, 08:32 AM   #11
Bex
1976 Argosy 28
Eckville, Lacombe County , Alberta
Send a message via Skype™ to Bex
I am in the process of trying to get the Argosy I have bought (but not yet paid for or placed a deposit) collected, and this info is very useful.
Thanks Overlander64
Bex
Bex is offline   Reply With Quote
Cost to restore a gutted Airstream Draco General Interior Topics 28 02-19-2013 12:17 AM
future airstream motorhome betteleal Airstream Motorhome Forums 11 02-12-2005 02:39 PM
Late '80s Airstream Aluminum Fifth-wheel acwdgw Integrity 5th Wheel (all Years) 17 01-09-2004 11:20 PM
Airstream Related List Servers Andy R Link Archive 0 02-22-2002 03:05 PM
AirstreamTrailers.com - Airstream Link Library Andy R Link Archive 0 02-22-2002 02:31 PM
