Old 08-01-2015, 12:00 PM   #1
1974 Argosy 26
Pensacola , Florida
Advice on Craiglist Argosy listing
Hi all! What do you think of this Argosy listing?
After talking with the seller, there is some floor rot near the front windows (which makes me think there's some near the rear bath, too). She says the back bumper/shell connection seems solid, though. The appliances are functional, but a new A/C unit may be around the corner. The tires are drivable, but will need replacing. She doesn't know if the axles have been replaced, so might as well factor that cost in as well.
I think this would be a lottt of work, but I think that will be manageable (with much advice from the forums, obviously ). My concern is whether the cost makes sense. She did state she'd be willing to come down in price. What's a good goal?
(I haven't seen this in person yet, because it's about 5 hours away... But I love the wraparound windows in the Argosy's, which is proving tough to find closer and in my price range).
http://centralmich.craigslist.org/rvs/5141676124.html
sospeso is offline   Reply With Quote
Old 08-01-2015, 01:43 PM   #2
aquinob's Avatar
Portsmouth , Virginia
It's fair. 3k is a good start, but from the pictures its really hard to tell exactly what it will need, that will take a good pre-purchase inspection on your part.
I would expect axles and maybe tires. Probably has all the original weather stripping, so count on going over all the windows and doors. Flooring and the frame will probably need some help, again that is what you need to figure out when you go inspect it. Check the operation of all the appliances and have water hooked up to check for leaks and to see if the water heater works. Check the fridge for operation on ac as well as gas. If you can fill the tank, check for pump operation as well.
Good luck, post back with some pictures.
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 08-01-2015, 02:00 PM   #3
Mission , Texas
Even if it needs a new furnace, fridge, range top/oven, water heater, AC, axles, tires, new plumbing, battery and three stage charger along with sub-floor repair, you'd still have less in it than a new white box of smaller size - IF you did the work yourself.
nrgtrakr is offline   Reply With Quote
Old 08-01-2015, 03:12 PM   #4
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
What you are looking at is pretty typical of a trailer that has not had any heavy-lifting restoration work done to it, but might have been used somewhat regularly in the last few years. The price is fair. As you have observed, rot at the front windows likely means rot around most of the perimeter, especially in the back. So with this in mind, you know you have a lot of work ahead of you with either an entire floor replacement or at least extensive patch work. Note also, that it looks like someone has built some kind of cargo shelf extension onto the rear bumper. Depending on what kinds of loads have been on it, and how much it has been used, this could really exaggerate the potential rear-end separation.
good luck!
Old 08-02-2015, 01:17 PM   #5
1972 27' Overlander
Woodburn , Oregon
Get ready to spend lots of money and time if your buying a vintage trailer , if you enjoy that then go for it .
shineybullet is offline   Reply With Quote
Old 08-02-2015, 03:41 PM   #6
1952 25' Cruiser
1967 22' Safari
1969 18' Caravel
Palo Alto , California
I think the price is great but then I live in CA where this argosy would be at least 6k if not more even in it's current condition. You will probably need to put 10k into it, if you are doing the work yourself. So, the question is, what would it be worth if it where all fixed up ? it would need to be worth 13k or more to make the deal make sense from a financial point of view. Do a search for fixed up Argosys and see what they are selling for to see if you would get enough money to make it worth it. So, that is the financial side-from a personal enjoyment side-if you like fixing things up and you will enjoy the process-then you will have a really sweet, special trailer when you are done. Almost all trailers of this age need floor repairs,new tires and new axles. So be aware of that.
markdenise is offline   Reply With Quote
Old 08-04-2015, 10:10 AM   #7
1974 Argosy 26
Pensacola , Florida
Thanks for the input, everyone! I took the plunge! It hasn't sunk in just yet, but I am excited about learning some new skills and building on the ones I've got... and of course, to see the finished product many hours of work later.
craiglist scams going crazy Sprouty Off Topic Forum 30 10-08-2014 02:34 PM
When gas goes up More RVs On Craiglist Lothlorian Off Topic Forum 0 02-23-2012 10:22 AM
Yet another Craiglist scammer DKB_SATX Our Community 12 03-27-2011 12:39 PM
Legit or Scam? Craiglist Listing ts8501 Off Topic Forum 40 09-12-2010 09:20 PM
