Go Back   Airstream Forums > Airstream Community Forums > Dollars & Cents > Trailer Values
Old 03-08-2011, 10:54 AM   #1
1975 24' Argosy 24
Burlington , Ontario
'75 /22ft Argosy
What would be the value of a 22 ft Argosy.
Tires one year old. new
New gas regulator (automatic change over)
New gas water heater and controls.
New water intake port.
In good to moderate condition over all.
No surprizes.
Carpet two years old.
Rae
raebaker06 is offline   Reply With Quote
Old 03-08-2011, 12:41 PM   #2
Moderator Emeritus
overlander64's Avatar
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 194
75 /22ft Argosy
Greetings Rae!
No surprizes.
Rae
I haven't been following values for Vintage Argosy coaches very closely for a few months, but I can provide you with this information:
  • The floorplan of your coach can make a significant difference. If your Argosy 22 happens to be the comparatively rare Argosy 22 Rear Door floorplan, it should command a slightly higher price than the more prevelant front door floorplan.
  • Condition of the paint, particularly on the galvanized steel endcaps can be an important consideration to some prospective buyers.
  • Were the LP tanks recetified when regulator replaced and are the tanks steel or Worthington Aluminum -- Worthington Aluminum tanks with current certification will help to build the value of your coach on the market.
  • Has the furnace passed inspection or has it been replaced - - a known safe and operational furnace will help to build the value of your coach.
  • Are the axles in good condition -- axles in good condition will help to build the value of your coach.
I would suspect that the value range would be somewhere between $2,500 and $5,000.
Kevin
P.S.: You might find the Vintage Airstream Price vs. Condition Guide of value.
Kevin D. Allen
AIR #827
1964 Overlander International
Airstream Argosy 1977 22ft eBay Watch Airstreams on eBay 0 03-13-2012 12:20 PM
1975 airstream argosy 22ft. rare model great deal look! eBay Watch Airstreams on eBay 0 09-15-2011 05:50 PM
1975 airstream argosy 22ft. rare model great deal look! eBay Watch Airstreams on eBay 0 09-09-2011 12:50 AM
1975 airstream argosy 22ft. rare model great deal look! eBay Watch Airstreams on eBay 0 08-27-2011 10:30 PM
1975 airstream argosy 22ft. rare model great deal look! eBay Watch Airstreams on eBay 0 08-25-2011 02:30 AM
