Old 07-07-2016, 05:17 PM   #1
Franklin , New Hampshire
72 Airstream Sovereign for $8500
My wife and I have been dreaming about buying an Airstream for a while. Maybe do some moderate renovation, but not the entire thing.
We saw this as on Craigslist today. What would be a good price for it? What should we look out for when viewing it?
Any help would be greatly appreciated, thank you!
http://nh.craigslist.org/rvs/5667094240.html
NHdreamin is offline   Reply With Quote
Old 07-07-2016, 07:02 PM   #2
1979 23' Safari
Wayland , New York
Seems a bit high for an empty 72. The "new" floor covering the old floor, no telling what shape the subfloor was in before it was covered.
"New tires, ball bearings, brakes", it probably needs new axles so the money spent on brakes and bearings was sort of wasted. Plus they're not ball bearings.
It does look like it's in decent shape. Possibly missing a hatch cover on curb side aft.
Old 07-07-2016, 07:24 PM   #3
Thank you! How expensive are new axles and what would be a decent price for the state it's in right now? More like $5,000?
Old 07-07-2016, 07:50 PM   #4
cameront120's Avatar
1972 25' Tradewind
The long trailers of that era are, in my opinion, the least desirable and come up for sale the most frequently. The under built frame can present problems like rear sag. Here is some essential reading:
http://vintageairstream.com/airstream-price-guide/
North Vancouver, BC
Old 07-07-2016, 07:54 PM   #5
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Hmmm... I don't like new floors, they have the potential to hide things. You may be able to get photos from before the finish-floor, or you may be able to test with a pick or a moisture or density meter.
The shell looks pretty good, that's a plus.
It's a 32' trailer, that's a minus on $ value.
It's a '72, which means small black tank and NO gray tank, minus.
For a not-special year/size/plan, $8500 is a price for "let's go camping and fix minor things as we go along." I think it' s a bit high for "let's figure out what to do about furnishing the living/dining space."
My cynical nature notes that the photos don't seem to show propane cylinders or where the cylinders SHOULD be, so that's an open question. *IF* everything that's in it works (electrical OK on both 12V and 120V, water sewer and propane systems work without leaks, 2-way fridge still present and in decent working order, AC cools OK) then $6k-$7k may be an OK price. things that are wrong detract from that. A new fridge is a $1200 proposition, for example. I'm also more picky because I already have a trailer on which everything works, so I can be more selective about "The Deal." In the end your money is your decision of course.
David
Old 07-07-2016, 08:05 PM   #6
Thanks for the responses, very insightful!
The reason we personally are looking for a 32' is because we have two boys. Going camping with the four of us (and probably the dog) would be getting tight with a 24'? But a 27' or 28' might perhaps be a better choice?
Old 07-07-2016, 09:41 PM   #7
DKB_SATX's Avatar
1976 Argosy 28
If a 32' is the right size for you, that just means you get a bargain in terms of $/ft. People seem to pay more for smaller trailers, for whatever reason. Buy what fits you, but pay attention to the market in the process.
David
Old 07-07-2016, 09:58 PM   #8
Seattle , USA
Run away...screaming.
RareStream is offline   Reply With Quote
Old 07-08-2016, 12:13 PM   #9
SuzyHomemakr's Avatar
1972 29' Ambassador
Boynton Beach , Florida
I wouldn't consider it much of a bargain- you can get a ready-to-go Sovereign here in S. Florida for less, and it probably hasn't been driven on those salty roads up there. Having just paid out $1300 for new axles, make sure that the torsion arms point on a downward angle! And jump up and down on the rear bumper to check for separation. And step all over the bathroom floor, shouldn't be squishy. And...
(there's a complete checklist available here at airforums.com!)
SuzyHomemakr is offline   Reply With Quote
Old 07-08-2016, 12:31 PM   #10
1971 31' Sovereign
Temple , Texas
My wife and I bought a 1971 Sovereign in similar condition for $4000. It had just the bare subfloor, so we were able to see the needed repair in the rear bathroom area. The main thing that attracted me to our trailer was the fact that everything was there and worked. There were no missing pieces of window hardware, etc. Also, the frame was in excellent shape.
After fixing the subfloor, we updated the electrical stuff, as well as replacing all of the plumbing including the black water tank and toilet. We'll be adding a new fridge and air conditioner and intend to replace the axles. By the time we finish we will have a nice fully functional Airstream for a little under $10,000.
I'm a pretty skilled Mr. Fixit kind of guy and was able to do all of the work myself.
TxDave is offline   Reply With Quote
Old 07-08-2016, 03:01 PM   #11
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
If it's the size and layout that you want, make a list of all the things that it needs, or might need, along with the costs for each. Go and look at the trailer prepared to get the best price you can based on what it will need. If you can't see the floor or the frame then you should assume that there is some rot and that some of the frame will be rusted to the point of needing welding. That can be a big job because it often means gutting the trailer to get at the floor needing replacement. If the seller says the floor and frame are okay then ask to have the belly pan partially taken down so you can see it, or ask to see photos.
Assume that it needs new axles if they are the originals.
Check the date codes on the tires. Were they new this year, or new five years ago in which case they will need to be replaced soon.
As mentioned in other posts, add in the cost of an RV refrigerator and propane tanks.
Check all of the tambour doors to make sure they operate as they are commonly in need of repair in a trailer of this age. You can also use the lack of a grey water tank as a bargaining point. Trailers just a little newer (I think from '73 or '74 on) will have one. If you are unfamiliar with a lot of these items you might want to take someone with you who is familiar with them to get their opinion.
It seems to me that they're asking too much.
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is offline   Reply With Quote
Old 07-08-2016, 03:15 PM   #12
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
if you check the rear end separation issue alluded to above and it is not a problem, 5-5500 would be an ok deal. Then you maybe put 3000 in it and have nice Airstream for 8000+.
First see if-
appliances work, are they all there or available? Air Cond? Heater? Plumbing..etc
1966 Overlander
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
Our AIRSTREAM and TIN CAN TOURIST Rallys
Old 07-08-2016, 06:37 PM   #13
We would like to put in a composting toilet and then convert the black tank to a grey one. But good point for negotiating the price!
Old 07-31-2016, 12:15 AM   #14
nickclifford's Avatar
1972 31' Sovereign
felton , California
this guide doesn't really reflect much of a difference in the resale values ? only a few hundred bucks, did I read that wrong ? Listed sale prices on CL would certainly show that Bambi's go for a LOT more money ... !
nickclifford is offline   Reply With Quote
sovereign
Atwood hydro flame 8500-IV Furnace nickmeloy Furnaces, Heaters, Fireplaces & Air Conditioning 3 05-29-2014 08:40 PM
A&E 8500 awning up down lever came lose AustinAir General Repair Forum 0 09-20-2013 05:38 PM
My Atwood 8500 furnace will not light Pedecanada PanAmerica - all model years 3 01-16-2013 04:34 PM
Removing Excalibur 8500-III Furnace burobaaje Furnaces, Heaters, Fireplaces & Air Conditioning 10 10-11-2011 01:35 PM
