Old 03-15-2014, 07:22 PM   #1
moretown , Vermont
'66 Caravel 16' Value?
Hi Folks,
First time poster, long time reader. So I'm interested in a 66 Caravel AS trailer i found on ebay. 1965 Airstream Caravel 16ft | eBay
I'm new to the sport and not sure what is a fair value for this beauty. This is a restoration project. Basically, the owner has gutted the trailer except for leaving some of the interior skins up, removed the kitchen and appliances, furniture, all that jazz. Has no major dents, or scratches. He is telling me no major leaks and don't see any water damage in any of the photos.
Here's why i'm interested: New axle installed, frame is in good shape, exterior skins in good shape as well. For the age looks like in good condition other than the restoration part. The owner has also saved all the hardware and curved parts for templating, which is brilliant and shows good forethought.
so what is the benchmark price for a 66 caravel 16' in this condition and how much would it cost to restore? (Minus the labor since i would be doing the work. ) Would like to tastefully restore, but not go crazy and have a pretty small budget couple k to work with.
I'm tempted not to bid too high, but also know this is a sought after model considering the length, weight, and year. Your thoughts? please discuss....
thanks for the help and insight! BH
billhobo is offline   Reply With Quote
Old 03-17-2014, 02:18 PM   #2
Jewel65's Avatar
1965 17' Caravel
1965 17' Caravel
Memphis , Tennessee
Images: 21
Well, I can only tell you my thoughts. Looks like a nice trailer, but don't be fooled. Looks like the bathroom is still intact. That means you can't see the floor below the bath. I would want to see in person, no way to tell from photos if the floor is rotted. I suspect it is. The frame may look good, but I also suspect there are issues there too. That said it still could be a nice trailer to work on, but realize you would have to replace the floor and do some frame welding. If it has not been done previously, it will almost definitely need it. A new axle is a plus, but only about $600 plus. I can tell you that mine cost more than their current price, but I don't know what the reserve is. If it is under 6 or 7k it might be worth looking at. I think it will take more than 2k to restore it, however this is done over time, so you do as much as you can afford at a time. Total cost will probably be 12 to 14k. That is my guess based on what mine cost and what is going into restoration.
1965 Airstream Caravel, 2003 Ford F150 SuperCrew, 2003 Miata Special Edition, 1993 Miata Black & Tan
Jewel65 is offline   Reply With Quote
Old 03-17-2014, 03:25 PM   #3
Sprouty's Avatar
1972 23' Safari
1956 16' Bubble
1947 22' Liner
Hillpoint , Wisconsin
If it were me I would contact the airstream specialist that replaced the axle and see what he thought of the trailer. I would also make sure the title has the correct serial number on it.
2 Liners
2 Safaris
2 Flying Clouds
1 Bubble
and a partridge in a pear tree
Sprouty is offline   Reply With Quote
Old 03-17-2014, 05:08 PM   #4
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Depends on how bad you want it, doesn't it? You know it's a lot of work. There's a lot of expense there in appliances, cabinetry, electrical and plumbing. But you could use it like an aluminum tent and slowly build it into your dream trailer if that's what you want to do. Are you buying it to keep?
Stephanie
Old 03-17-2014, 05:40 PM   #5
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
First off, welcome to the Forums! I'm sure you will get lots of questions anwsered here if you decide to take on this project.
I would suggest spending some time at these two links:
Price vs Condition
Restoration Resources
They will really help you assess what this trailer is worth in it's current condition and what it will take to bring it back to roadworthy condition.
I believe you will find that the current eBay price of $4000 is already higher than it should be for a Caravel in "As Found" condition...and the reserve is not met yet. Although, if the work already that is done has been done by Colin Hyde, you can trust it has been done well....but there is still lots of work to be done and lots of $$$ to be spent!
New appliances alone would run more than a "couple k". Oufitting the whole interior will run $4-10k modestly IMO. It wouldn't be too hard to spend twice that.
Shari
Old 03-17-2014, 05:54 PM   #6
InsideOut's Avatar
1956 22' Safari
Images: 108
Saved hardware = good, that original stuff can be hard to find.
However, I can tell you from first hand experience that the "curved templates" are really not much help. If the shell has been removed fully or partially for floor replacement, then the overall geometry of the trailer has changed enough that the templates won't matter. They help, but by no means are they able to be used without verification & modifications.
Don't ask me how I know...
Shari
Old 03-17-2014, 06:40 PM   #7
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
Shari
Shari is right on with that. I only 'renewed' my trailer - half a new floor, new fridge, heater, charging system, new axle, new propane lines. When I got done it looked exactly the same, but everything worked, and I still managed to spend about $6k even though I did most of the work myself! It's surprising how fast it adds up
Stephanie
Old 03-17-2014, 07:03 PM   #8
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
That's my experience too, that you can dump a lot of money in these things. New appliances, electrics, pex plumbing, axle, water tank and it looks the same, but we use it and love it (new upholstery helps) It's true, the skins on the one in the pictures look good, the floor looks good- you can peek around the bath to see what the corners are like. The back of the trailer where the bumper-storage is is going to be a problem area for floor rot, but even with a flashlight and iPhone, you can make a first pass and see if it's just awful. The great thing about it is the size. I just towed my 19' Globetrotter 800 miles with my Pilot, and love how easy the small one is to tow. Those Caravel's had a very cool floorplan too, if you opt to put it back the way it was. If not, it's a manageable size to rebuild, and they have that cool curved glass. With the axle, find out who did it and how they sized it, to make sure it's not too big or too small, or at least so you know what you're getting. Appliances are a fortune. The templates I think, since the shell hasn't been removed, should be fine. I did a semi-shell off, and my cabinets went back just fine. I think you really have to screw up the geometry for stuff to not fit. As someone said, you can do bits of it and enjoy it as an aluminum tent on wheels, using it and adding to it. We did this, and it really makes the renovation a lot more fun- you can kind of dream and plan.... Haunt Craig's list and ebay, and whatever other sources you can find for parts, and some pieces can be rebuilt. If you're handy and patient, it could be great. On the other hand, what's the story of the seller? Did they get into it and burn out? Best of luck to you.
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 03-17-2014, 07:27 PM   #9
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
66 Caravel on ebay
It's been about 4 or 5 years since I installed the axle on this trailer. From what I can remember, this is in great restorable condition, however after he disassembled the interior, he stored the components in his basement that got flooded during Sandy. All of the woodwork was destroyed along with the appliances, so sad. Unfortunately I can't remember how the floor was, however in the photos, it appears solid. Assume that it'll require some floor work in the rear though. All in all, this is a great starting point. Hopefully this helps out.
Colin
Colin H is offline   Reply With Quote
Old 03-19-2014, 08:20 PM   #10
moretown , Vermont
Dear airstream community,
Thanks for your words of wisdom on this topic. I apologize for the delayed response! been real swamped at work the past couple of days and haven't checked the forum since the last time i posted. Anyways, you all make valid points and i think it all comes down to how bad i want it. The only problem is i can't "kick the tires" so to speak because of the location. buying a trailer on ebay encourages one to over spend, and at this point the reserve hasn't been met so who knows. Can anyone out there have some advice on buying a trailer sight unseen? i only have a few days until the end of auction.
I know appliances and such are expensive, have folks in the AS world had any luck finding used ones at a lower prince? I also had this crazy idea of spray foaming the inside and then hanging the skins on the interior back up, or using wood paneling instead of the skins. kinda like the inside of a sailboat. the only down fall might be the added weight.
Thanks again for the help, BH
Old 03-19-2014, 08:28 PM   #11
moretown , Vermont
Hello Colin
Thanks for the heads up on the trailer you worked on a couple years back. my only fear is the whole darn thing got swamped in sandy, more than just the wood work and appliances. any thoughts on the matter? how much is the trailer worth in your opinion considering you're the man from what i hear when is comes to this stuff and you also have done work on this guys trailer??
Happy shoveling, BH
Old 03-19-2014, 08:51 PM   #12
Colin H's Avatar
1959 28' Ambassador
1949 24' Limited
Peru , New York
Hello Colin
Happy shoveling, BH
I spoke to the owner several months ago about finishing it for him, however the project didn't move forward. I was also concerned about the trailer being flooded, however he said it only affected the parts he had taken out of the trailer & stored in the basement. I have seen, & worked on much worse trailers than this one.
As far as value is concerned, I'm not really sure. Prices for restoration candidates are certainly going up these days, so I guess we'll see by the end of the auction. Keep in mind that smaller vintage Airstream's have always been worth more than the larger ones, due largely to their "cute" factor & the ease to tow them.
Colin
Old 03-20-2014, 06:54 AM   #13
Sprouty's Avatar
1972 23' Safari
1956 16' Bubble
1947 22' Liner
I have spent a huge amount of time and plenty of gas money over the years looking at muscle cars and more recently vintage trailers. I have come to a conclusion for my own use that I will NEVER bid on a large investment unless I can physically put my hands on it. I might buy something that someone else looked at for me but even then I would be nervous about it. The one exception to that rule would be if the item was way undervalued but that doesn't happen very often with muscle cars or Airstreams.
2 Liners
2 Safaris
2 Flying Clouds
1 Bubble
caravel
1969 Airstream Caravel 18 - Georgia disherb Airstream Classifieds 1 02-27-2014 08:49 AM
Caravel :: 1967 Airstream Caravel youngestmeyn Airstream Registry Discussions 0 11-29-2011 09:31 AM
Caravel :: 1967 Airstream Caravel C Johnson Airstream Registry Discussions 0 08-19-2011 08:31 AM
