Old 03-08-2014, 04:17 AM   #1
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Question on Fasteners
Greetings
I have been reading about metal nobility and corrosion. Now after owning my Airstream for a few years, messing with it by replacing parts, checking for leaks, etc., I am wondering about fastener replacement. Airstream used steel screws in several places to attach items in addition to the panel rivets. These screws on my rig in most cases are rusted- even rotted under the rub rail trim piece.
BEFORE reading about nobility I replaced those screws with stainless screws. Now I am questioning my action. I am interested in getting some opinions from those who may have used stainless steel fasteners and have had them applied for some time. My concern is galvanic corrosion.
I did find a write-up about the two metals together:
Stainless steel fasteners in aluminium plates or sheets are normally considered safe, whereas aluminium rivets or bolts holding stainless steel parts together is an unwise combination, as there is a practical risk of corrosion.
An example of the safe use of stainless steel and aluminium together is where stainless steel fasteners and hold down bolts are used to secure aluminium roadway or bridge parapet guards.
Even with no insulation between the metals, there should be little risk of corrosion.
Any thoughts on this relating to Airstreams?
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Steel / Aluminum wheel question polarlyse Wheels, Hubs & Bearings 12 05-29-2011 07:49 PM
A question on selling awnings Airy Awnings 21 04-24-2011 10:37 AM
EVAP Canister? question 8rmesse Classic Motorhomes 23 04-24-2011 06:41 AM
Blasphemous question woytovich General Repair Forum 15 04-09-2011 08:36 AM
Trailering Question Cracker Jacks, Stabilizers, Lifting and Leveling 14 01-02-2011 02:55 PM
