Old 09-29-2016, 09:51 PM   #15
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We have an early AM Solar 600 amp-hour lithium battery (168 pounds versus the 368 pounds of the four Lifeline 6Vdc 300-amp-hour batteries) in our 2014 31' Classic under the front sofa with a Magnum MS2812 inverter charger and eight 100 watt solar panels.
We have an AM Solar 300 amp-hour lithium battery in the 2015 23D under the sofa in front of the street side wheel well with a Magnum hybrid MSH-3012 inverter charger and five 100 watt solar panels. The battery weighs less than the two stock lead acid batteries we removed.
Both lithium batteries can provide up to 90% of their rated amp-hours and be charged with all the power one can provide from either solar, generator or shore power.
One is pushing their luck trying to get 50% of the amp-hour capacity out of lead-acid batteries as well as the Lifeline batteries we removed.
Old 10-03-2016, 07:38 PM   #16
2016 30' Classic
Erie , Colorado
Year and half with my 2015 Classic and solar/Lithium setup done by Marvin Braun of PrecisionRV.
System uses the cells/controllers from Elite Power Solutions. 2x200ah setup under one of the dining area benches. Allows for a compact install, great reporting through an LCD panel. Interfaced flawlessly with the Magnum 3000 Hybrid and BlueSky controllers with AMS panels on the roof.
Only one hiccup, user error, lost a panel mounting t handle on this last trip. Tightened them up, or so I thought, in the spring. Quick stop to buy a stainless cap screw and lock washer.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 10-03-2016, 07:57 PM   #17
switz's Avatar
2014 31' Classic
Images: 8
Currently adding the ninth 100 watt AM Solar panel to the roof of the Classic. That will load the Morningstar Tri-Star 60 MPPT solar charge controller to it's working capacity charging the 600 amp-hour lithium battery. This is a matching panel to the other eight AM Solar 100 watt panels already installed.
I have a complete set of spare 100 watt solar panels for each trailer in storage as this smaller size is no longer available.
Old 10-03-2016, 10:11 PM   #18
lewster's Avatar
Naples, FL , Hood River, OR
Lithium Ion Batteries
Lou,
Actually, AM Solar is now having their own versions of the GS-100 (now called the SP-100) with the same specifications, dimensions and Sun Power cells built for them with their own label.
You can buy all you want! Don't think they will be running out of stock anytime soon. 😁
Lew Farber
My Li-ion, 2kW, Battery Project sgschwend Batteries, Univolts, Converters & Inverters 72 04-20-2018 07:00 PM
Lithium Batteries for Solar ghaynes755 Generators & Solar Power 26 01-13-2015 09:02 AM
Electrical, Solar, Lithium Batteries on 28' International wbrown Electrical - Systems, Generators, Batteries & Solar 25 09-13-2014 06:44 PM
Lithium ion battery bearrand Batteries, Univolts, Converters & Inverters 9 04-04-2014 06:02 PM
Lithium ion battery sk8r29 Batteries, Univolts, Converters & Inverters 18 03-30-2011 01:33 AM
