Old 05-31-2016, 11:27 PM   #1
Hattiesburg , Mississippi
Is solar really worth it?
I am in the planning stages of getting my own Airstream. I've seen some stuff about using solar panels to generate energy for the batteries. Is this worth the time and money? How much energy is actually generated?
Jjarman is offline   Reply With Quote
Old 06-01-2016, 06:10 AM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Welcome Aboard....
YES & KNOW
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 06-01-2016, 06:12 AM   #3
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
The answer is: it depends.
As to whether solar is "worth it," it depends on how you camp. If you go from one full hookup campground to the next then NO it does not pay to get solar. If on the other hand you regularly go to campgrounds that do not have electrical hookups (many state and federal campgrounds fall into this category) or like to camp in the middle of nowhere (i.e., boondocking) then yes, solar AND a good set of healthy batteries can be indispensable and way more pleasant that using a generator.
As to how much power you really get out of solar, it depends on how much you want to spend. You can get a perfectly functional solar system with panels that sit on the ground that you can aim towards the sun for $400 to $600 and that will keep your batteries charged assuming modest use. Or you can spend upwards of $15,000 for a full blown system and Lithium Iron Phosphate batteries and be able to run your air conditioner for several hours off the batteries alone. A good basic, typical solar system will cost between $2,000 and $4,000 (installed) plus the cost of new/upgraded batteries.
I would suggest that you get some camping under your belt before you make any significant investment. Also, while it's fine to ask a broad questions such as you have on this forum, I would encourage you to do some research on your own. Here are two excellent sites to start:
http://www.amsolarrv.com/rveducation/
http://www.technomadia.com/solar/
Bob Martel
WBCCI# 5766
Old 06-01-2016, 06:15 AM   #4
FCStreamer's Avatar
2014 30' Flying Cloud
It may be worth it to you depending on how you intend to use it. And how much energy is actually generated depends on what system you install. This is a very open ended question.
You can install a very small system that will essentially trickle charge your batteries. Or you can install a large battery bank and install enough panels to run an AC. I've seen them both. I would say they are the both extremes. And there are all sorts of options in between.
In essence, you want solar because you want to camp where an electrical hookup is not available. So you will use your batteries instead of 120V from the electrical hookup. This usually means you can't use your 120V appliances, like microwave and AC, unless you have an inverter that converts 12V to 120V. A big enough inverter can even run an AC. A big inverter. But it will suck the two batteries dry in minutes. So you would also need additional batteries to create a large enough bank.
So how much do you want to spend? And what do you want to be able to run while you are disconnected? Decide that, and you can narrow down your options.
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 06-01-2016, 06:23 AM   #5
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
The short answer is heck yes its worth it! After a small initial investment of not much...... you're free as a bird. Everything works for free for a very long time! Buy the best equipment you can and reap the reward. I haven't plugged in for a long long time. Live like a king!
Old 06-01-2016, 06:28 AM   #6
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I have been spending about 7 months a year in our 2 Airstreams for the last 8 years. We do not have solar and I have no plans to add it. One trailer is plugged in all the time. I carry a generator for when we camp without electricity for a week or so at the time. My suggestion is to get the Airstream and go camping and then figure out what you need. I would go without the generator at first also to see if I thought it was needed. And you can buy one almost anywhere if you find yourself wet, cold, and out of electricity and want one. So for me I have not thought solar would be "worth it" A good solar rig is pretty expensive by my standards.
Bill M. is online now   Reply With Quote
Old 06-01-2016, 06:48 AM   #7
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
If you camp in locations where you can remove AC from the equation you are fully equipped to handle several days " off the grid". Try it out. We went 4 days in Glacier NP. Yes, we were stingy with the battery usage and showers but we did this easily on our batteries. Could have gone longer too but we were only there 4 days. So try it out and see if you enjoy that style of camping before you take a plunge into a solar setup. Don't forget though, your refrigerator will take a small amount of battery even when on propane.
Get out and enjoy it then you can make these $$$$ decisions later.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 06-01-2016, 07:59 AM   #8
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We get along with the factory solar except when traveling east, more clouds and more shade trees. Think of getting a Zamp portable suitcase solar (up to 200 watts, 47 lbs) to take along to supplement our factory system (106 watts). We can move it into or aim it to the sun as needed for best results.
However, I don't know if these are compatible, portable to supplement factory installed system?
Doug and Cheryl
Old 06-01-2016, 08:28 AM   #9
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
I just camped/boondocked for three days with a 100 watt solar panel system and got along fine. I use a solar lantern for the evenings and save even more power by not using the lights. I was able to run the furnace to take the chill off in the morning and kept everything charged up just fine. It all depends on how much you want to use in electricity and your style of camping. I did cheat one morning and used the generator because I had to use the electric feature on the hot water heater. I was having challenges with the gas burner.
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 06-01-2016, 08:37 AM   #10
field & stream's Avatar
2008 23' Safari SE
2007 Base Camp
Santa Ynez , California
It is definitely worth it to us, but as others have pointed out your answer relates to how you plan to use your trailer. If you will be plugged in, you don't need anything.
Ninety percent of our use (about 50 nights per year) is unplugged in state and national parks so the stock batteries-only system will not do the job. Also, we dislike generators for both the noise and the problems associated with transporting them.
Our solution was two 100 watt rooftop solar panels and conversion to two 6-volt golf kart batteries. So far, batteries fully recharged every day.
field & stream is offline   Reply With Quote
Old 06-01-2016, 10:36 AM   #11
I can tell y'all are a wealth of knowledge. I am probably not getting the camper for at least 4-5 years from now so will investigate and think on it more. I am supposing there are different size and capacities of batteries to have on the camper, even if not solar. I need to look into that. If not able to plug in I want to be able to use the fridge, tv at night, water heater, ac if we are in a hot area.
Old 06-01-2016, 10:47 AM   #12
2016 22' Sport
Concord , California
I use my solar primarily to keep my battery charged when my AS seats idle.
Happy Days is offline   Reply With Quote
Old 06-01-2016, 11:09 AM   #13
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
Reseda , California
I have a single panel for the purpose of keeping my Maintenance Free AGM charged while parked. A single panel is not enough for a full time use. I have a generator when I need to charge the batteries or for anything else. My friend uses a wall timer once a week for 24 hrs to charge his battery. But also has to maintain his battery. I kept my OEM battery for a year before changing it to Maintenance free, only because I am too lazy to have to remind myself to put water in the battery. I did the solar for the same lazy reason, I don't want to have to disconnect a power to charge it when I have to leave. Is it expensive? That is a relative term. I pay for convenience, depending how lazy I am, I will pay the price.
cazual6 is offline   Reply With Quote
Old 06-01-2016, 11:19 AM   #14
kdickinson's Avatar
1969 23' Safari
Palmer Lake , Colorado
after seeing people use their generators because their solar panels did not charge their batteries I say - 30 amp shore power for electric, limited battery in between, good old gas powered generator for dry camping, and always have sunscreen on hand for solar ...
kdickinson is offline   Reply With Quote
Really, really new Bambi! Pahaska Off Topic Forum 3 05-12-2009 08:20 AM
Really, really new!! Globeville Member Introductions 6 08-20-2007 03:33 PM
Really, Really, Really Hot swebster Airstream Motorhome Forums 8 11-16-2003 08:46 PM
Really really great site and Airstream FrankR On The Road... 5 07-14-2002 02:10 PM
