Old 05-31-2007, 04:09 PM   #1
30' 1999 Excella
Tin Diesel's Avatar
Kingwood , Texas
Send a message via Yahoo to Tin Diesel
Cost to repack bearings?
I'm just curious... what is the normal cost range for repacking bearings on a 2-axel (30') trailer?
I did a search on 'repack bearings cost' but didn't come up with much.
I normally do this myself, but time constraints are requiring that I have it done.
Hey, its the only way to be sure!
Tin Diesel is offline   Reply With Quote
Old 05-31-2007, 04:13 PM   #2
yukionna's Avatar
Massachusetts
Images: 18
Send a message via Yahoo to yukionna
I'm not sure as we always do the work ourselves. Have you tried calling your local Airstream dealer? I'm sure they will give you a quote over the phone.
WBCCI Region One
Attitude is the only difference between ordeal and adventure
yukionna is offline   Reply With Quote
Old 05-31-2007, 04:18 PM   #3
AgZep's Avatar
2005 28' International CCD
Las Cruces , New Mexico
Our local dealer (TX/NM border) quoted 1 hour labor/axel. Thus it was about $200. Not cheap, but we were under a time crunch as well.
AgZep is offline   Reply With Quote
Old 05-31-2007, 04:23 PM   #4
30' 1999 Excella
Tin Diesel's Avatar
Kingwood , Texas
They just called and told me my bill was $350 for labor. Seemed high. (We're in Houston)
Old 05-31-2007, 04:30 PM   #5
CanoeStream's Avatar
St. Cloud , Minnesota
I was in to my dealer in Iowa last month. Their bill for two axles, 1.25 hours -- $150.
5 meter Langford Nahanni
Old 05-31-2007, 04:55 PM   #6
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
THat sounds about right 1.25 hours, times the shop rate.
But $200 or worse yet $350 is a rip off. Did they ask for that much money without a gun?
'77 Sovereign Intl 31' CB
Old 05-31-2007, 05:07 PM   #7
flyfisher's Avatar
2004 30' Classic
Field and Stream , PA & MT
I just got mine repacked yesterday.
I paid $110 for 2 hours of labor to repack 4 trailer wheel bearings, replace the seals, clean and adjust the trailer brakes, and to replace the fuel filter in my truck. I was charged another $33.12 for the seals, and the fuel filter cost $56.52. (with 6% PA tax added to all)
I believe it would have been well under $150 total if they had only repacked the bearings and replaced the seals.
Incidentally, they repacked my bearings 2 years ago at this time, and when I took it in last year for repacking they told me it was fine and didn't need to be done. (I put about 5000 interstate highway miles on my trailer each summer, and store it inside for 8 months during the winter.)
John
Flyfisher
flyfisher is offline   Reply With Quote
Old 05-31-2007, 05:32 PM   #8
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
I need to go into the repacking of bearing business. I just did mine on the CCD in less than 2 hours, I recognize that you have a time constraint.
$4.89 for good bearing grease and a tub of hand cleaner (yes, I used gloves but they don't stop everything). 4 seals were $3.50 each and the bearings were in great shape. But, I did have a dealership replace all 4 rotors and brake pads on the F250 yesterday for $850, I felt taken but I also am up against a hard deadline for a trip so I did not want to have a truck in limbo for parts.
$150 seems like an upper limit on what I would pay for packing bearings if that included new seals.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 05-31-2007, 05:40 PM   #9
yukionna's Avatar
Massachusetts
Images: 18
$850 seems within reason. We just did the same work to our GMC 2500 HD and the parts cost us $350 and about 4 hours of labor. So if labor costs $100/hr and you add in parts, it would have cost us about $750 if we took it to the dealer. Keep in mind, our parts costs are lower because we bought after market parts at Napa. Dealer parts are always more expensive. Also, we had trouble with getting the rims off the front of the truck because of rusted bolts. Perhaps your dealership needed extra time for something like that.
WBCCI Region One
Old 05-31-2007, 05:42 PM   #10
Excella CM's Avatar
1978 31' Excella 500
Venice , California
At some of those prices, it sounds as if more than the bearings were getting "packed"
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 05-31-2007, 05:48 PM   #11
Dwight's Avatar
1999 34' Excella
Joshua , Texas
cost...
Most of the dealers in our area charge $100 to $150 per axle for labor PLUS the cost for the grease seals. They also adjust the electric drum brakes which do not self adjust like automobile drum brakes. I usually do our own bearings/brakes and plan on taking a whole Saturday to do it, 3 tires in the morning and the other 3 in the afternoon.
Dwight
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Old 05-31-2007, 06:01 PM   #12
B4WEDI's Avatar
2006 19' Safari SE
Nawthin' , Hemisphere
Had my single axle done at A/S in Jackson Center earlier this month :
@ $85. / hr $122.40
2 Seals $ 13.28
2 Cotter Pins $ .36
*** KEEP LOOKING UP ***
T & K
B4WEDI is offline   Reply With Quote
Old 05-31-2007, 06:02 PM   #13
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Our local trailer shop charges $200 for 4 wheel repack, including seals, not including new bearings or brake parts.
Old 05-31-2007, 07:35 PM   #14
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
We just paid:
4 seals and brake adjust kit = 23.59
bearing repack labor 3 hours = 195.00
Total $218.59
Whats Does It Cost You For Plates On Your RV? 68 Suburban Our Community 32 10-14-2015 11:54 PM
Polishing...approx cost? Drew Cleaning, Stripping & Polishing 10 03-31-2014 10:37 PM
Cost to restore a gutted Airstream Draco General Interior Topics 28 02-18-2013 11:17 PM
repacking the Wheel Bearings Chuck Axles 26 04-27-2003 08:59 PM
cost of '81 Excella new? jaiman General Motorhome Topics 7 11-09-2002 05:49 AM
