Old 12-14-2015, 03:16 PM   #1
Plasma800's Avatar
houston , Texas
backyard storage: Building or RV Port
I moved out to a couple of acres. I love having my airstream on property and out of storage, but now it presents a problem....
I HATE leaving it out in the open.
So I could build a metal building, but they aren't cheap... or I could install an RV port, but then there's exposure.
Concrete pad? Gravel?
What do you do for your backyard storage??
'15 27fb Signature
'12 Chevy 2500HD Gasser
Plasma800 is offline   Reply With Quote
Old 12-14-2015, 03:37 PM   #2
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
Unfortunately I don't have the availability to store onsite, but if I did it would be either the metal bldg with hook ups, overhead doors front & back for pull through convience & big windows on both sides for light so when family visits & doors are open they won't feel like they are in a warehouse. Second choice would be an attached carport with hookups.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2016 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 12-14-2015, 03:48 PM   #3
CRH
1995 25' Excella
xxxxx , xxxxxx
I would build a post/steel pole barn style building with a concrete floor.
CRH is offline   Reply With Quote
Old 12-14-2015, 04:18 PM   #4
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Generally, I wish a lot.
Maybe, build a gravel pad. Use it as the AS parking for now and configure it to be the drive for the concrete floored garage you will build later when you can afford it.
Might consider using the house/garage as a wind break.
If you have a hill on the property and it's not too rocky, you might be able to cut in a bunker that could be configured like a walk out basement. You might even be able to build a guest house on top later. That is, if you weren't always traveling in the AS.
Oh, and that gravel drive, might be a good pad to loan out to some poor lost AS traveler too. The country life is good. Lots of options.
Congrats on the new place. Pat
PKI is online now   Reply With Quote
Old 12-14-2015, 04:23 PM   #5
Mission , Texas
We like concrete pad with full hook ups, a car port topper and storage shed.
nrgtrakr is offline   Reply With Quote
Old 12-14-2015, 04:23 PM   #6
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
There are a couple of really good threads on this topic here......someplace. Let me see if i can find them.......back in a few.......
www.nesa.org
Air No. 6427
Old 12-14-2015, 04:31 PM   #7
Got gandkids?
Here's one: http://www.airforums.com/forums/f415...ads-98377.html
Not the one I was thinking of, but a few ideas.
www.nesa.org
Air No. 6427
Old 12-14-2015, 04:33 PM   #8
Plasma800's Avatar
houston , Texas
local building guys quoted my 25k for a 18 x 35 insulated space with a lean to (for the bass boat), a single 14x12 door, a single ped. door and 2 windows.... and I'm thinking..... 25k??!!! ugh
and I'm sure the price is worth it, but after the cost of moving, plus I dunked all of the cash from the sale of our old house into the mortgage of this new one, plus bought a new truck in mostly cash... it's like... i feel tapped for a second..
'15 27fb Signature
Old 12-14-2015, 04:35 PM   #9
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
Keep em dry with an outside cover.
Using a pole building is good for snow country, but as a backup guest quarters is not to good to have folks inside a building. The outside carport type cover still provides some natural light and views, easier to have black water hook-ups.
sgschwend is offline   Reply With Quote
Old 12-14-2015, 04:37 PM   #10
mandolindave's Avatar
there are other options as well
If you used 4 by 4 posts, you could close it in later, if it suited your life style.
In Texas you might want the south wall closed in
No walls might make a nice BBQ/picnic area,
mandolindave is offline   Reply With Quote
Old 12-14-2015, 04:55 PM   #11
CRH
1995 25' Excella
xxxxx , xxxxxx
I would use 6 x 6 posts for a structure that size.
Old 12-14-2015, 04:55 PM   #12
Got gandkids?
Here's the sub-forum I was thinking of: Winterizing, Storage, Carports & Covers - Airstream Forums
Lot's o'good ideas in there.
www.nesa.org
Air No. 6427
Old 12-14-2015, 05:43 PM   #13
remphoto's Avatar
2015 16' Sport
Upper Sandusky , Ohio
You could probably cost-jutify that expense if you are paying a couple grand a year for rental storage like some of us. I wish we could do a pole building at our house but the HOA would frown on that. We have considered buying a cheap building lot or a couple acres in the country to erect a building.
2015 Airstream Bambi Sport 16J
Past Travel Trailers:
*1992 Dutchmen 30' Bunk
*2003 Jayco Designer Series 32' Rear Living
*2015 T@B Sofitel S (exchanged after 3 days for Bambi)
remphoto is offline   Reply With Quote
Old 12-15-2015, 10:24 AM   #14
2013 Interstate Coach
La Center , Washington
Some options for the do-it yourself guys and gals.
I have the exact same issue with my AI, my former coach I had a nice cover and although was not a fan of leaving it out, it fared really well for 4 winter seasons.
Now, with my AI, I am not wanting to cover it or leave it out in the rain or baking in the sun when not in use, so I began a search both locally and on the web for solutions I could do myself. I like post and beam structures as they are easy to construct and you can make whatever size you need.. After comparing local material costs (I am in SW Washington) to this site's building packages, it is nearly a wash with the online site having a bit more choices in colors and frame materials used.
So, if you have the skill set and want to save money, I say build your own!..
If not, then i believe that Absolute can coordinate with local installers which most likely will still be less than a local builder starting from scratch..
Retired Air Force
Drewsome is offline   Reply With Quote
any residents of Sequim ,Port Townsend or Port Angeles kingfisher24 On The Road... 6 10-15-2013 08:57 AM
What's in my backyard this morning??? tinbender Member Introductions 20 11-06-2010 07:34 PM
Extended Stay in my Backyard salmaas Full-Timing 4 07-15-2009 07:22 AM
Great Backyard Bird Count Barbara Peerenboom Off Topic Forum 8 03-04-2005 09:10 PM
i saw this '69 airstream in a local backyard.... leefields 1966 - 1969 Ambassador 8 02-14-2005 05:06 PM
