Old 08-24-2015, 03:15 PM   #15
BScott's Avatar
1972 23' Safari
Hereford , Arizona
Plates
My paper plates fell to the floor and would you believe not one broke...
BScott is offline   Reply With Quote
Old 08-24-2015, 03:33 PM   #16
twobikes's Avatar
1997 25' Safari
Montgomery , Alabama
Lots of extraneous stuff in this blog post, but there is a picture of our overhead using readily available ADJUSTABLE shelves from big box store. Stack dishes on edge...
http://airgo.blogspot.com/search?upd...max-results=35
Follow us at two bikes + an Airstream. Http://Airgo.blogspot.com
PAT & AL MEYER
TAC AL-26 WBCCI 2626
Montgomery, Alabama
follow the Two Bikes and an Airstream blog at http://airgo.blogspot.com
twobikes is offline   Reply With Quote
Old 08-24-2015, 05:25 PM   #17
My dish management solution...
Corelle plates of two sizes go in a check file I got from Staples (yes I did remove the tag) which slides neatly into the gap between the microwave and the cabinet wall. One plate per individual plastic pocket so that they do not rattle.
Bowls, glasses, and cutlery fit into this webbed basket I got at Michaels craft store. Each cutlery piece in its own slot so that they do not rattle on the road.
Total cost about ten bucks.
Old 08-24-2015, 06:03 PM   #18
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Twin Rocks , Oregon
Originally Posted by Lata de amor View Post
Hi All...we just came up with a good solution to our plates and glasses flying around in the cabinet. We had some shelves made of plexiglas at our local " Tap Plastics " location and they are terrific! I've attached a photo.
I spoke with you when you were getting the shelves made, and I agree, they look great! We are thinking about a set for our trailer.
Steve
Old 08-24-2015, 06:21 PM   #19
2015 25' Flying Cloud
Tappahannock , Virginia
This is what I made to deal with my dishes and in the same area we made a platform for cutouts for glass and mugs....
RivaHaven is offline   Reply With Quote
Old 08-24-2015, 06:26 PM   #20
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
My wife used some type of rubberized shelf liner cut to size between each plate.
No noise no movement.
I "think" this is it. Very flexible, thin with lots of little holes and feels like rubber.
http://www.homedepot.com/p/Con-Tact-...2-12/100388875
Garry
Old 08-24-2015, 08:20 PM   #21
Richard
2006 30' Classic S/O
Merced , California
That photo by AWCHIEF is worth a look. Why didn't I think about that years ago.
kleimanr is offline   Reply With Quote
Old 08-24-2015, 09:09 PM   #22
Silverbee's Avatar
2015 28' Flying Cloud
2012 25' Flying Cloud
2007 20' Safari SE
Fuquay Varina , North Carolina
Storage solution for dishes and glasses
I used off the shelf storage vinyl coated wire shelves from Home Depot and a bamboo plate holder from a home store.
In the first picture I used a wire shelf divider and turned a corner shelf on its side to keep the glasses in place. I used silicone pots holders (lime green in the photo) to keep bowls from sliding. I also use them as pot holders.
In the second picture I use another wire shelf and a bamboo plate holder for the plates, saucers and my folding silicone colander. The Corelle square plates are too tall for the bamboo plate holder so I stack them on the shelf.
Nothing really moves and no broken glasses or plates.
ID:	246263   Click image for larger version
Silverbee is offline   Reply With Quote
Old 08-24-2015, 09:45 PM   #23
79nTOW's Avatar
1979 29' Ambassador
Mobile , Alabama
To keep everything organized when on the road I simply put bed pillows in the cabinet. They hold everything quite well and it's something you already have on hand. Been doing this for years.
Predeta
79nTOW is offline   Reply With Quote
Old 08-24-2015, 11:03 PM   #24
St Paul , MN
I took a clear plastic shoebox type container - but larger - and with straight sides - plates get stacked front to back. It holds alot - more than I need! 2 large serving platters to the back, 6 dinner plates, 6 salad plates and more! They don't fall out and they don't shift - toss the cover and for less than $5 problem solved.
Seemore2006 is offline   Reply With Quote
Old 08-24-2015, 11:06 PM   #25
St Paul , MN
Best solution yet! So funny but seriously got to get to that point!
Old 08-25-2015, 03:20 AM   #26
carver 1's Avatar
2011 30' Classic
2007 25' International CCD
1993 32' Excella
Largo , Florida
Images: 30
All of my plates as well as cups came from a marine supply store. They come with rubber already built into the bottom and do not slide around. I also use wire holders similar to ones already posted. One of the advantages of the set up that my Classic has is the amount of upper cabinet space. All the cabinets are lined with non slip. Not the soft kind, but more like place mat consistency. Check out Defender Industries or West Marine for the plates, cups and saucers.
..ron<<
2015 GMC Denali 2500, 4x4, Duramax diesel, Topper, Pro Pride 3 P, Sendel 16" with Michelin LTs, one Yellow Labrador Retriever (AS security)
carver 1 is offline   Reply With Quote
Old 08-25-2015, 05:13 AM   #27
Lily&Me's Avatar
Normal , Illinois
Predeta
This is a great idea.....something to keep things from moving is important. Extra bath towels or dish towels would serve the same purpose.
Things just won't ride in something mobile as they set in your cabinet at home. If it can move, it will displace during travel.
I keep my Corelle dishes upright, in lid organizers from WalMart, in a lower cabinet, glasses and mugs in a small upper, cushioned by that rubbery shelf liner mentioned earlier.
Maggie
Old 08-25-2015, 05:49 AM   #28
2016 30' Classic
Maitland , Florida
David, are those plates ceramic or plastic? I want ones just like them.
FreshAirStmr is offline   Reply With Quote
Excella 500 Wine Glasses? MarkExc500 1978- 1979 Excella 500 6 03-09-2011 06:40 AM
Those pesky beds in the back or where did I put my glasses? Caryl 2005 and newer - Bambi all models 16 09-18-2010 08:27 PM
Storage for keys, glasses bolerama 2006 - 2010 International 6 08-16-2009 06:10 PM
