Old 05-26-2015, 01:09 PM   #1
2015 30' Flying Cloud
Westport , Connecticut
Mouse fur removal with photos
Hi everyone:
I think I did what a lot of you have wondered about doing yourselves...so I am sharing photos that I hope you find helpful!
I spent the weekend updating my new airstream, getting it ready for our year long journey. We ripped out some cabinetry and will be building our own in the next two weeks. Stay tuned...I'll post lots of photos of that too!
In the meantime, here are photos of the mouse fur removed from the bunk room in a Safari 30'.
First, I did try to clean it. I used a Bizzell (?) professional model of carpet cleaner with oxyclean solution. It didn't do much. Then I vacuumed. (THAT was quite a workout!!) The vacuuming was more successful but still didn't return the mouseful to a consistent cleanliness. It was still mottled and black in spots. I'm OCD so I decided I didn't want to keep it. I want my 'bedroom' to be in perfect shape. Sleep is important to me!
I pulled off a corner and found the aluminum underneath, of course.
I'd LOVE to keep it aluminum BUT there are SO many holes in it from the previous owner who took down the bunk and put up window treatments. There's no way to smooth out the aluminum to its original beauty so I'm currently researching how to make the best changes.
ID:	239285   Click image for larger version
ID:	239287   Click image for larger version
KiraR is offline   Reply With Quote
Old 05-26-2015, 04:36 PM   #2
RangerJay's Avatar
2002 19' Bambi
Northwestern Ontario , - on the backside of the map and just above the big green spot
Images: 44
I'm just slightly ahead of you - and my job looks quite a bit smaller than yours - our trailer is a 2002 19' Bambi - we're just replacing the center portion of the ceiling and curved portion of the upper walls - not doing anything lower than that nor the ends. Taking out the cabinets, lights and removing the headliner was fairly easy - and enjoyable - but removing the glue was painful - got it done though and currently in the process of seeking out and then ordering the replacement headliner - we're not anxious to replace with the same mouse fur so are looking for something different.
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2009 (The Buggy)
"I'm not young enough to know everything ....."
(Oscar Wilde)
RangerJay is offline   Reply With Quote
Old 05-26-2015, 07:35 PM   #3
Jay, what are you going to replace the mouse fur with? I was considering wallpaper...but, that's not smart, I discovered. So...off I go to contemplate what material will be aesthetically pleasing AND provide insulation from noise and temperature.
I'd love to see photos of yours!
Kira
Old 05-26-2015, 08:20 PM   #4
mcair's Avatar
1988 29' Excella
Collinsville , Illinois
What about covering that area with quilt batting and a nice upholstery fabric?
mcair is offline   Reply With Quote
Old 05-26-2015, 09:05 PM   #5
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
I also had dirty mouse fur walls so I covered the fur with Aluminum, right over top. It has been a year and lots of use and still looks real good. The bedroom walls were stil clean so I left them. It's a challenge to get the corners right but lots of templates and It got done.
Name:	100_7862 (640x480).jpg
ID:	239337   Click image for larger version
Name:	100_7876 (640x480).jpg
Name:	100_7875 (640x480).jpg
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 05-27-2015, 08:12 AM   #6
RangerJay's Avatar
2002 19' Bambi
Images: 44
Kira
Not much to see so far - here are a couple pictures of the headliner removed and the glue in process of being removed.
A couple of other things that might be of interest:
  • I used lacquer thinner to remove the glue - got that suggestion from an older thread on this forum - works OK - but ventilation is important - and was careful to make sure there was no source of spark when using it. The job was slow and messy - dealt with about a foot square at a time - applied with sections of heavy towel and scrape off softened glue with a 3 or 4 inch putty knife - mine was metal and it does leave marks if you were wanting to leave exposed aluminum as the finished product - a plastic knife might be a better choice to save scuffing. Getting the glue off the putty knife onto a paper towel is the seriously messy part - think of Chevy Chase, Christmas Vacation and tree sap .... I ended up using close to 3 quarts of thinner which seemed a lot - and given how messy the job was I can't help but think there must be a better way .... I even questioned the need of doing it at all.
  • I was surprised at the number of sheered rivets - at least a dozen - really seems to speak to the importance of wheel balancing.
  • Looking to replace with standard foam-backed headliner but haven't finished the search. Have asked for a quote on the leatherette type of headliner Airstream has used in the past. Most automotive or marine type headliners seem to come in only 54 or 60 inch widths. Other RV headliner comes in 8 foot widths but seems limited in selection.
I'll be really interested in following your own progress as you move along.
Jay
ID:	239371   Click image for larger version
(Oscar Wilde)
Old 05-27-2015, 12:41 PM   #7
1995 28' Excella
Flemington , New Jersey
Headliner removal
We too had a falling-down headliner and decided to pull it down, remove the adhesive and just paint the newly exposed aluminum. We love the result. I would think this would work for mouse fur removal as well but if the aluminum isn't in good shape then painting wouldn't look so great. I was considering covering some particularly bad mouse fur with burlap. Sort of "cottage-y" I guess.
We used Citristrip Stripping gel, acetone and lots of rags with over-your-head scrubbing! It worked and we like the clean lines. But...not a job you want to do more than once!
ID:	239379   Click image for larger version
ID:	239381   Click image for larger version
hollisturner is offline   Reply With Quote
Old 05-27-2015, 12:43 PM   #8
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Great renovation ideas for my trailer with unwanted mouse fur and headliner-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
m.hony is online now   Reply With Quote
Old 05-27-2015, 01:40 PM   #9
Skater's Avatar
1995 30' Excella
Bowie , Maryland
I'm working on removing the headliner, too, and have a thread around here somewhere about it. I recently got a heat gun, so I intend to try that on removing the headliner glue.
My wife wants to remove the mouse fur...I kinda want that to be HER project. I like the idea of putting aluminum over it, though...
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 05-27-2015, 04:54 PM   #10
1996 25' Excella
Tillsonburg , Ontario
I have noted on a previous post that I glued a rubber backed upholstery fabric to the underside of a deck on my boat. Since the fabric was a woven polyester I had no problem with mold or water leaks. The latex rubber backing was to stabilize the fabric but it worked really well with contact cement.
JCW
JCWDCW is offline   Reply With Quote
Old 05-27-2015, 10:32 PM   #11
1973 25' Tradewind
Toronto , Ontario
What the heck is "mouse fur"?
Maryelia is offline   Reply With Quote
Old 05-28-2015, 05:40 AM   #12
m.hony's Avatar
2013 30' Classic
Mouse fur is the white (or off white) fuzzy carpet-like stuff on the interior walls of some Airstream trailers. Airstream may have discontinued its use altogether. The last trailers I am aware that had it are the 2014 Classics. It was used in many models for many years.
TAC #MS-10
Airforums #70955
Old 05-31-2015, 02:19 PM   #13
2008 22' Sport
Arcadia , California
Mouse fur removal
Hi, This is a great thread! We are in the process of mouse fur removal right now on a 22' safari. I'm planning to finish the walls with zolatone texture paint, which apparently was used by AS at one time. My question - I've got a fair number of rivet holes to patch, some to drill out, and obviously the seams between the interior aluminum sheets. I've noticed that the factory used something that looks almost like masking tape at the seams. Does anyone have a suggestion for these plugs/seams that I can then prime and eventually spray over? The zolatone has enough thickness to hide the irregularities, but I need at least a continuous substrate below.
Thanks so much
PerkOL8 is offline   Reply With Quote
Old 06-07-2015, 01:16 PM   #14
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
We like our old Mouse Fur, and it's still performing. I AM interested in the options for headliner renewal, removal, replacement if/when that becomes an issue.
Greg and Linda Heuer
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
https://www.linkedin.com/in/gheuer
Silver Otter is offline   Reply With Quote
And the mouse fur flew... 3 Dog Nite Upholstery, Blinds, Walls & Interior Finishes 15 06-30-2016 11:38 AM
cleaning mouse fur MontyV Upholstery, Blinds, Walls & Interior Finishes 2 07-12-2013 08:11 PM
Spot cleaning or replacing mouse fur flyslinger Upholstery, Blinds, Walls & Interior Finishes 6 07-08-2012 09:30 AM
Zolatone, mouse fur, and padded cell ceiling (pcc) wmarsha 1997 -2001 Excella 2 05-28-2012 02:52 PM
Covering uncleanable mouse fur walls and ceiling 3 Dog Nite Upholstery, Blinds, Walls & Interior Finishes 15 11-10-2010 01:13 PM
