Old 11-04-2010, 05:53 PM   #1
1969 23' Safari
South Lyon , Michigan
Has anyone ever shortened a A/S awning tube
I have access to a 17 foot wide awning, but my trailer needs 13 foot, can I cut the tube the awning roll up on down 4'? What is inside that tube?
Protosport is offline   Reply With Quote
Old 11-04-2010, 06:01 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
It has been done by several.
The roll looks like this:
Awnings By ZipDee
Richard
Old 11-04-2010, 06:03 PM   #3
Kevin245's Avatar
I've cut down a Carefree awning with no trouble at all.
What brand of awning are you dealing with?
Kevin
William C. Swinney
Old 11-04-2010, 06:56 PM   #4
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
I needed a 12.5 ft roller for my pool cover, friend had an old awning reel, cut it down, only problem was making sure a 90 degree cut was even so I used a marker all the way around and hacksawed around rather than straight thru keeping to the line. Measured twice for single cut, final size increases .25 by the insert. 20 yrs later still using it. It didn't have a spring in the center as some do.
Old 11-04-2010, 07:53 PM   #5
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I cut a Zip Dee down without a problem.
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
My awning tube is bent- question . . . Splitrock Our Community 13 07-17-2010 04:21 PM
New roller tube for old Carefree awning maccamper Awnings 7 06-09-2009 05:49 PM
Shortened Gasket - what to do?? Pschoerrn Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 09-18-2006 10:45 AM
? carter shade awning roller tube retro-active-couple Awnings 3 06-23-2004 03:56 PM
