Old 03-27-2010, 08:10 PM   #1
Richmond Hill , Georgia
Question convertion of Engine AC
I have a 93 Landyacht. I need to convert the main front AC. Can any one explain how that is done? South Ga is very hot and I must have cool air when I'm driving.
possummamma is offline   Reply With Quote
Old 03-27-2010, 08:43 PM   #2
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Convert from what to what?
If you mean the refrigerant, there is a discussion of retrofitting R12 systems with R134A here. It is a fairly good explanation.
Last time I did one was at least 10 years ago. There were kits available. They included instructions.
Vaughan
Old 03-27-2010, 09:09 PM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
Probably best to take it somewhere as you need a vacuum pump to do the job right and there aren't any cheap setups suitable for the shade tree mechanic.
Minimally you have to put converter caps on the high and low pressure service ports, evacuate, add ester oil, and charge. Sometimes there isn't enough clearance for the converter caps and so the service ports have to be moved. Many mechanics will replace the accumulator and filter/dryer (if present) during a conversion as these are inexpensive parts that can retain a fair amount of the mineral oil which is a contaminant in a r134a system.
One fact to consider is that you will lose about 10% of cooling capacity as a result of the conversion. Recycled R12 prices have come down so you may be better off finding a shop that will just recharge it with R12.
Old 03-27-2010, 10:32 PM   #4
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Dash air won't cool the cockpit on a hot day by itself. To be cool you'll need to run the generator and the overhead AC.
Some folks don't even bother with the dash air, they just use the overhead unit.
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
engine, land yacht, motorhome, air conditioning
Help on engine RonJudi Mechanics Corner - Engines, Transmission & More... 69 01-02-2010 11:13 PM
Engine: could I be lucky? Gypsy Jo Mechanics Corner - Engines, Transmission & More... 14 07-27-2009 01:09 AM
Engine length Versatile Mechanics Corner - Engines, Transmission & More... 1 01-21-2006 02:55 PM
Now this is an Engine TomW Mechanics Corner - Engines, Transmission & More... 2 05-10-2004 08:33 PM
