Old 02-11-2013, 10:06 AM   #1
Jenaz, Switzerland , Graubunden
Post Calling All Experts!
So Heres the Dilemma.
Have a 62 safari single axle, and need to have the GVM for a new registration Document here in Europe.
Dry weight, empty weight is Given on the specs as 3050lbs. Great!
Registration documents from USA have no weight listed. OMG.
But the authorties here need the total weight or GWM to reregister
Has anyone got this infomation? Or any tips on how to obtain it?
rgds
UP
Uppla is offline   Reply With Quote
Old 02-11-2013, 10:57 AM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
You might look for a truck scale. I am sure that there is such a thing in Europe. A building material dealer, or sand/gravel outfit will have these as drive-over type installations. That will give you the actual dry weight.
A 62 will have na early version of the torsion axle, if it still original. If you crawl under, you might find a rusty tag welded to it with specs on it. Careful rust removal will reveal the axle's weight rating. This, plus about 500 or so US lbs on the tongue, will give you the trailer's gross weight rating.
I hope this helps.
Uwe
Uwe
www.area63productions.com
Old 02-12-2013, 04:49 AM   #3
gvm
Thanks Uwe
It kinda helps...but the local registration dept...won't add about 500lbs..they want me to provide details..ie paperwork.. for GVM. Seems nobody knows anything...
Old 03-08-2013, 04:54 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Check this link
http://www.airstream.com/files/libra...7d753366ab.pdf
Peace and Blessings..
Channing
WBCCI# 30676
Old 03-08-2013, 04:56 PM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Remember definition of expert.. "Ex " is a has been... "Spurt" is a drip under pressure.
Channing
WBCCI# 30676
