Go Back   Airstream Forums > Airstream Community Forums > Global 'streaming > Modifications
Old 10-03-2005, 09:12 AM   #1
kayamtom's Avatar
Profile:  1962 26' Overlander
Oxford , Oxon
bits 'n' bobs
Hello
I am currently looking to buy an empty shell for restoration. I will be shipping MY NICE SHINEY Airstream back to the UK to do the work.
What i need to know is where to buy the kitchen and water appliances, second hand or new. what to look for- tell tale signs of wear or poor performance etc.
Is it easy to buy axel and brake re-build kits and other servicing parts?
If there are any on-line shops and anyone has some links for me that would be super.
ta-ta.
kayamtom is offline   Reply With Quote
Old 10-03-2005, 12:45 PM   #2
Stefrobrts's Avatar
Profile:  1968 17' Caravel
. , Washington
Hi, and welcome to the forum. Do some searches and you will find much of what you need. There have been a lot of discussions about axels, but of course you won't know exactly what you need until you have a trailer located. Appliances can be bought new, which is probably much better than shipping used parts overseas. Everything you need is available. You will even find some members who have had their trailers shipped to Europe, if you need advice on how to do that. So poke around and see what you can find out
Stephanie
Old 10-03-2005, 12:53 PM   #3
Profile:
ta-ta.
Try http://www.inlandrv.com/ and you will find more than you thought you needed to know, and plenty you wished you didn't have to know!
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 10-03-2005, 02:28 PM   #4
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
I would imagine you could get new RV appliances in England that would fit and be a lot more economic than buying new ones here and having them shipped across the pond. If you want to stick with original vintage appliances, that's a different story...but harder to find/maintain.
Another thought...Propane appliances would probably be okay, but what kind of electrical modifications would need to be made if they are american-wired?
Good luck in whatever you decide to do ~
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
Old 10-03-2005, 03:21 PM   #5
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 62
Almost everything in the trailer is 12 Volt DC and runs off the battery / inverter. The inverter would have to be changed to match your power. The outlets would need to be changed. I would get the AC (cooler) where you live. The refrigerator also runs on shore power, so that would need to be converted also. I am not sure about the plug for shore power, but most likely that would need to be replaced also. The other way around it is to get a 230 V 50 Cycle to 110 V 60 Cycle convertor and install it where shore power comes into the unit.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 10-03-2005, 06:09 PM   #6
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Hello
Hit the Dometic site www.dometic.com they have all the appliances you could ever need for your domestic market. Also see if you can find a wrecking yard for Caravans I am sure there are some over there somewhere. The next time I chat with my friend's niece I will ask...they live some where near Durham and have a decent sized caravan. BTW I am going to have to order a gas oven from overseas via Dometic because they don't sell stand alone gas ovens in the USA for RV's anymore.
Good Luck with your adventures; keep us posted and post lots of pictures!!
Aaron
WBCCI #2449 AIR #2495
Old 10-03-2005, 06:23 PM   #7
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
Shari
It would be less cost in import duty fees if the appliances were used, and IIRC, European electric is 220v. Remember the Travelocity Gnome? ("Am I going to die?")
Converting a fridge may be fairly straightforward, as there are no electric motors, and only a couple of switches that would need to be changed, as well as the electric heating element. The A/C would be another story, as would the Univolt...
(No Longer at Inland RV)
I had a fun day (pictures) Old trailers and old stuff RichardT Off Topic Forum 11 03-13-2005 04:49 AM
Hensley Installation?? Kestrell Hitches 22 02-01-2005 09:27 PM
Rivet removal tool campcollector Ribs, Skins & Rivets 17 06-15-2004 11:13 PM
Drill Bits Inland RV Center, In Parts Archive 2 08-01-2003 09:20 AM
Bobs RV Salvage in High Springs Fl scootertrash The Vendor's Forum 11 04-18-2003 06:22 PM
