I need to add an additional sewer hose tube to the underbelly but unfamiliar with AS construction. Looking for some experienced advice on what my options might be (other than existing attachment points, of course). Thanks in advance for any & all comments!
Rich & Mary
Marana, AZ
2018 25’ FC/FB
I’ve attached two additional hose holders under my 23D. I found the rivet line of the belly pan and used that to attach one of the sides of the bracket. They run width ways with the trailers. That holds the weight of the tube and contents the other side of the tube is just screws to the belly pan. You need to make sure you attach the one side of the tube to something with some “meat” to it. The belly pan alone will not support it.
We installed a short tube holder to the curb side of our unit to hold fire poker and flamingo legs and stuff like that. I had to attach an aluminum spacer to allow for the propane line to travel under the tube.
