Old 04-03-2018, 07:24 PM   #1
2018 23' Flying Cloud
Sammamish , Washington
Any ideas on locking batteries and propane tanks?
We recently purchased an Airstream travel trailer and store this at a RV / Boat storage place. While it is secured I have noticed that a few trailers have chain locks around their outside battery compartments.
I would hate to pick up the trailer and find the batteries gone and tanks removed - all very easy at this big site.
Any ideas on securing the battery cabinet and propane tanks?
Cdn Camper is offline   Reply With Quote
Old 04-03-2018, 07:29 PM   #2
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
The battery box latch can be changed out to a key lock pretty easy and tank locks are available for purchase online.
For my tanks I just drilled a hole in through the large wing nut and the aluminum cross brace and put a padlock through the hole on both preventing the wing nut from being able to spin, thus locking the tanks in place
Old 04-03-2018, 07:43 PM   #3
Ariz-Pacer's Avatar
1958 17' Pacer
Phoenix , Arizona
Thumbs up Locking batteries and propane tanks?
I have always locked my safety chains through the propane tanks collars.
That solves any problem.
AZP
Ariz-Pacer is offline   Reply With Quote
Old 04-03-2018, 08:00 PM   #4
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Try this product from Tork Lift for the propane tanks.
https://www.etrailer.com/RV-Locks/To...kaAkV3EALw_wcB
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Old 04-03-2018, 08:07 PM   #5
TSchleff's Avatar
2005 30' Classic
Omaha , Nebraska
I don't know how long of time you leave your Airstream at the storage lot, but when I know I'm not going to be using the trailer for any extended period of time I remove the batteries so I can trickle charge them every 6 weeks.
TSchleff is offline   Reply With Quote
Old 04-03-2018, 08:27 PM   #6
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
If your storage lot is not secure, you may need to continue searching for a better solution. There is always a way to add a lock or at least make everything look more secure, but as mentioned here numerous times, a determined thief with a battery operated grinder makes quick work of locks, chains, and heavy metal devices.
There is a philosophy that car convertible owners develop. Leave it unlocked so the thief does not ruin an expensive top to access something of much less value. Never believed that approach, but understand it.
Fellow who sold me a boat had painted the outboard with primer and a splotchy pattern to make it look old. That too seems wrong for a nice shiny Airstream trailer.
Best idea may be to add a decent looking padlock, worry less, and replace what gets removed if such does happen. A good reason to use Walmart flooded cells or move your high priced spread inside the coach.
The really smart folks never park the rig long enough for bad people to find it. You are looking for a solution. That sounds smart. Travel safe. Pat
Old 04-04-2018, 09:19 AM   #7
2018 23' International
Diamond Bar , California
Check out immobilize.com They make a nice battery box lock and an Airstream-specific hitch lock.
David R. Busse
DRBusse@roadrunner.com
2018 Airstream International 23CB
2018 GMC Sierra 1500 4x4
DRBusse is offline   Reply With Quote
Old 04-04-2018, 09:34 AM   #8
kdinnar's Avatar
2019 27' Flying Cloud
Boothbay Harbor , Maine
Torklift Fortress
We got ours like DaveP said from eTrailer. Just make sure you get the version made for Airstreams. (Torklift Fortress Gaslock For Propane Tanks On Airstream) Easy to install and looks pretty solid.
Joyce and Ken
2019 Flying Cloud 27FB
2017 Ram 2500 Limited
kdinnar is offline   Reply With Quote
Old 04-04-2018, 09:36 AM   #9
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
We’ve decided that if someone steals our propane tanks, that will be our excuse to upgrade to aluminum tanks and buy one of those locks.
Rocinante is our 2014 International Signature 27FB
Old 04-04-2018, 10:50 AM   #10
2014 27' Flying Cloud
Stowe , Vermont
After having 2 tanks stolen while in a storage facility a number of years ago, I purchased a Fortress Propane Tank Lock. I am very pleased with the way it works. As for the batteries, our AS's battery compartment came with a lock. My theory is: the locks are not fool-proof, but they may be an annoyance to a thief, and he/she may just choose to move on to an easier target.
PS the tank replacements were not cheap. There's the cost of the 2 tanks - the initial purging process - and then the fill.
VT Wanderer is offline   Reply With Quote
Old 04-04-2018, 12:22 PM   #11
Obviously-NOT
james.mileur's Avatar
Kalispell , Montana
Double nut x2, double big-o washer, chunk-o chain, UHaul lock. Done with gas bottles.
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 04-04-2018, 12:52 PM   #12
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
If you chain secure propane tanks be sure and use a plastic covered chain. Quite often there is gas escaping due to pressure vent off or leaks. Any chain can produce sparks when moved. Adios!
guskmg
Old 04-04-2018, 12:56 PM   #13
PKI
PKI's Avatar
Is that another Pro for replacing the steel with an aluminum tank? Really must get some aversion theropy for these thoughts. Pat
Old 04-04-2018, 02:24 PM   #14
Mollysdad's Avatar
I hear the key lock for the outside shower can directly swap with the turn screw on the battery door.
My concern with any lock is it faces up into rain and road debris.
Southwest Locking the Propane Cover Steve_M Boondocking 27 02-28-2015 07:24 AM
Locking Aluminum LP tanks on a "Classic" brownm3 LP Gas, Piping, Tanks & Regulators 16 03-24-2013 11:12 AM
Propane Tanks - Locking Down RVGuyRaleigh LP Gas, Piping, Tanks & Regulators 7 02-22-2011 05:59 PM
Any ideas for vintage look propane rack? cloud55 LP Gas, Piping, Tanks & Regulators 4 11-05-2006 12:46 AM
