04-04-2018, 10:34 PM
#21
Stay CazuaL
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda
Originally Posted by kendrick.l.j
As I sit here and read about having to add extra locks, chains, etc, i’m wondering if I am totally naive or y’all are all hanging out in some really bad areas. Unless I am out site seeing or hiking or otherwise having fun, I am only a few feet from my propane tanks and batteries. Are tanks and batteries really stolen a lot? When I am not using my Airstream it is parked in the back yard in a reasonably safe neighborhood. So should I be that concerned?
It's insurance.
Better have it and not need it than needing it and not having it.
04-05-2018, 05:42 AM
#22
2017 25' International
Niagara-on-the-Lake
, ON Canada
Originally Posted by tjdonahoe
Not good.....just turn the wing nut and the long all thread will screw out of the bottom nut....
But as the padlock goes through the cross member too, the propane box won't be able to turn.
Ray B.
04-05-2018, 07:32 AM
#23
1964 19' Globetrotter
Ventura
Attachment 1
This has worked so far for me picked up the hitch lock at Harbor Freight, change the pin to a stainless steel bolt (Harder to cut through then steel) also added 2 rod collars with Alan set screws below the wing nut both to space wing-nut up to clear above gas regulator and to slow them down, needing an allen wrench to get the 2 rod collars off.
04-05-2018, 08:44 AM
#24
2015 23' FB International
2007 19' International CCD
Steamboat Springs
You could just drill a hole through the battery box lid and the box lip and use a padlock or use tamper resistant bolts on both sides.
Not theft proof but would be a deterrent.
04-05-2018, 09:02 AM
#25
2008 22' Safari
Spicewood (W of Austin)
The only reason I can figure Airstream placed a lock on the outside shower is to remind owners to require others to ask permission to use it....since the lock is securing a plastic cover!
Same thing with the Sport batt-box (but FCs and up/grades are certainly different..... if anyone breaks into the expensive metal batt-boxes....it'll be.. expensive. It's why insurance is sold.
The best reason to lock things up is to remind relatively honest people to remain honest and not provide temptation. I drilled a hole thru the bracket and the wing-nut and use a Ruger bicycle lock (which Ruger intended to lock the action open...) thereby rendering the propane tanks difficult to steal and reminding the thief a mini 14 is another good reason to move-on.
Sports also came with a cheap, plastic propane cover and I've thought of tossing it and either replacing it with an expensive metal cover...or simply allowing the tanks to sit in view.... but that encourages theft and exposes the tanks, regulator, hoses, etc. to road-blasting debris. Soo...any cover is helpful,...even a cheap one.... IMO.
04-05-2018, 10:23 AM
#26
Tampa
Originally Posted by cazual6
This is how I lock my propane. I drilled through the wing nut with a 3/8 bit.
To me, that's a good and elegant solution. Why pay $80 for a piece of sheet steel that does the same thing?
03-14-2019, 01:20 PM
#27
Bruce
2017 16' Sport
Huntington Beach
After much research....I came up with the following security upgrades:
For my Airstream 16' Sport: These are what I feel are the simplest, most secure, most cost effective approach to secure propane tanks (Master Lock 175DLH Set-Your-Own Combination Lock, 2-1/4-Inch Shackle, 2-Inch Body), batteries (B & D RV Battery Lock), and the Airstream hitch receiver itself (Atwood 89005). See photos.
05-21-2019, 08:41 AM
#28
2016 16' Sport
Truckee
, CA
Simple cheap propane tank lock
I used 3 links from an Ace Hardware chain and a Master combination lock to create a simple lock for my new aluminum propane tanks. See the accompanying photo.
06-18-2022, 06:41 PM
#29
2022 28' Pottery Barn
¯\_(ツ)_/¯
Raising this topic from the dead as I just heard about some propane tank thefts along with catalytic converters at a storage yard. Decided to make sure my tank cover and tanks were secured as well.
Like the posts show at #17 and #27, a big enough Master lock (or other brand) will lock down the wing and keep it from turning so the tanks and the tank cover can’t be stolen. Velcro the lock tightly to the tank crossbar as well so it can’t move, spark, etc.
The nut on the top is soldered to the wing also.
06-19-2022, 05:12 AM
#30
2022 23' Flying Cloud
Seattle
Originally Posted by Rocinante
We’ve decided that if someone steals our propane tanks, that will be our excuse to upgrade to aluminum tanks and buy one of those locks.
My concern wasn’t the tanks, but the $800 aluminum cover.
06-19-2022, 06:32 AM
#31
2022 27' Globetrotter
DALLAS
, TX
Aluminum tanks are not available anywhere last time I looked (about a month ago). If you know where 30lb aluminum tanks can be found, please send me a private message :-)
06-19-2022, 07:06 AM
#32
1994 25' Excella
Waukesha
, Wisconsin
Not sure where you're looking, but my local propane dealer was able to order aluminum tanks last I asked. I also see them listed as in stock on a few online stores.
Richard
11018
06-19-2022, 08:48 AM
#33
2021 30' Flying Cloud
2020 25' International
minneapolis
Originally Posted by DaveP
I purchased one of these 2 years ago and works great. It’s expensive, though easy to manage.
- Stewart
06-19-2022, 08:54 AM
#34
Sag Harbor
, New York
Originally Posted by Cdn Camper
Any ideas on securing the battery cabinet and propane tanks?
Good fences make for good neighbors IMO.
Peter
06-19-2022, 08:55 AM
#35
Seattle
Yeah, I just got that. Before I got a much cheaper lock before realizing it wouldn’t work. My only concern is that it barely threads the top of the post, and there isn’t much thread at the bottom to be able to move it up further. I think I need to replace the post. I can’t current use the washer they say to use.
06-19-2022, 08:59 AM
#36
¯\_(ツ)_/¯
If you lock the wing the way that I did (along with the other posts), they can't get the aluminum cover off (easily) as well.
You don't need to spend +/- $100 for the Fortress lock (which looks to be a good product) or worry about the thread length available for it if you just use a large lock as shown. The large lock (w/ correct shackle size) is also way cheaper.
06-19-2022, 09:52 AM
#37
2017 16' Sport
N/A
, N/A
Yes, X2
06-19-2022, 10:37 AM
#38
Seattle
If you lock the wing the way that I did (along with the other posts), they can't get the aluminum cover off (easily) as well. You don't need to spend +/- $100 for the Fortress lock (which looks to be a good product) or worry about the thread length available for it if you just use a large lock as shown. The large lock (w/ correct shackle size) is also way cheaper.
Oh I agree 100%. I wish I’d read this forum before I bought that lock. If I can find the original packaging, I’m going to try to return it.
06-19-2022, 11:22 AM
#39
Living Riveted since 2013
2016 Interstate Lounge Ext
Green Cove Springs
This is hilarious to me, because this thread and our posts are so old that we don't even own our 27FB trailer anymore. BTW, never lost a tank or an aluminum cover in seven years. Now we're in an AI with the tank built into the van.
06-19-2022, 11:24 AM
#40
DALLAS
, TX
Really? Please PM me the contact information for your propane dealer and the websites. I would really appreciate it.
